    modules
    24 Posts 4 Posters 429 Views 4 Watching
      pat59
      ![text alternatif](url de l’image)Hello, I installed MMM-RTSPtream and I’m having the following problem: my camera works perfectly; I can see the video when the taskbar is present. However, once I click on Magic Mirror to go into full-screen mode, my video disappears. What should I do? Thank you.MMM-RTSP.jpg MMM-RTSPs.jpg
      • KristjanESPERANTOK Offline
        KristjanESPERANTO Module Developer @pat59
        Hi @pat59,
        why doesn’t Magic Mirror start in full screen mode? Can you show me the module config?
          pat59 @KristjanESPERANTO
          Hello and thank you for your feedback.
          @KristjanESPERANTO
          module: "MMM-RTSPStream",
          position: "top_center",
              autoStart: true,
              localPlayer: "vlc",
              remotePlayer: false,
              stream1: {
                  url: "rtsp://admin:cxxxxxxxxx.:554/h264Preview_01_sub",
                  snapshotUrl: "http:///cgi-bin/api.cgi?cmd=Snap&channel=0&rs=abc123&user=admin&password=Sis1058!",
                  snapshotRefresh: 10, // Seconds
                  frameRate: 30,
          width: 640,
          height: 360
            rkorell @pat59
            @pat59 You may should remove your credentials from the urls ….
            Regards,
            Ralf
              sdetweil @rkorell
              @rkorell edited
                pat59 @sdetweil
                @sdetweil Hello, have you found anything unusual in JavaScript? Thank you
                S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
                  sdetweil @pat59
                  @pat59 no… but there have been many changes in the UI and tasking by the OS…
                  and MMM-RTSPtream has had trouble in the past…
                  as the background pgm used doesn’t blend well…
                  maybe try https://github.com/evroom/MMM-MPlayer
                    @pat59 Again my question: Why doesn’t Magic Mirror start in full screen mode? I think the problem is that neither VLC nor mplayer are inline in the Electron window. They are a separate window. And when you click on the Electron window the player window gets in the background.
                      sdetweil @KristjanESPERANTO
                      @KristjanESPERANTO correct, the task keeps getting surfaced even tho the module said background.
                      Just another fun day in we only changed a few lines of code somewhere (not MagicMirror)
                        pat59 @sdetweil
                        @sdetweil Hello, thank you. I will try it and get back to you. Thank you in advance. Sincerely.
                        P 2 Replies Last reply Reply Quote 0
