    modules
    24 Posts 4 Posters 6.1k Views 4 Watching
      pat59 @sdetweil
      @sdetweil Hello, have you found anything unusual in JavaScript? Thank you
      S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
        sdetweil @pat59
        @pat59 no… but there have been many changes in the UI and tasking by the OS…
        and MMM-RTSPtream has had trouble in the past…
        as the background pgm used doesn’t blend well…
        maybe try https://github.com/evroom/MMM-MPlayer
        • KristjanESPERANTOK
          KristjanESPERANTO Module Developer @pat59
          @pat59 Again my question: Why doesn’t Magic Mirror start in full screen mode? I think the problem is that neither VLC nor mplayer are inline in the Electron window. They are a separate window. And when you click on the Electron window the player window gets in the background.
            sdetweil @KristjanESPERANTO
            @KristjanESPERANTO correct, the task keeps getting surfaced even tho the module said background.
            Just another fun day in we only changed a few lines of code somewhere (not MagicMirror)
              pat59 @sdetweil
              @sdetweil Hello, thank you. I will try it and get back to you. Thank you in advance. Sincerely.
              P 2 Replies Last reply Reply Quote 0
                pat59 @pat59
                Quick question: I installed MMM-MPlayer. Do I need to disable RTSPstream for the MPlayer module to work?
                  sdetweil @pat59
                  @pat59 yes, one or the other
                    pat59 @sdetweil
                    @sdetweil Hello, I installed MPlayer but it doesn’t work; the screen is black.
                    P S 2 Replies Last reply Reply Quote 0
                      pat59 @pat59
                      I uninstalled MPlayer and reinstalled RTSPTream, it works except that I still encounter the same problem
                        sdetweil @pat59
                        @pat59 black screen, what were the messages at MagicMirror startup time?
                          pat59 @sdetweil
                          @sdetweil Good evening, no message, normal startup for the Raspberry Pi, normal startup for MagicMirrorr2, and a black screen, no message.
                            sdetweil @pat59
                            @pat59 can you show the messages
                              pat59 @sdetweil
                              @sdetweil Good evening, there was no message displayed for MPlayer, so I uninstalled it in config.js and reinstalled RTSTseam. Everything is back to normal except that I still have the taskbar displayed. Thank you.
                                pat59 @sdetweil
                                  sdetweil @pat59
                                  @pat59 I know. But if you keep changing we can’t debug what’s going on
                                  There had to be at least one message for bolster in the startup messages.
                                    pat59 @sdetweil
                                    @sdetweil Hello, yes, I understand perfectly. Excuse me, being a novice, I’m too afraid I won’t be able to get it working again. I’ve put the old module back in. I’m going to try again with MPlayer and will get back to you. Once again, I’m sorry, I’m very attached to my mirror.
                                      sdetweil @pat59
                                      @pat59 I understand. I suggest using a new separate config file for new individual modules until you get them working
                                      You can use the environment variable to define it
                                      export MM_CONFIG_FILE=config/fribble.js
                                      Or whatever name you choose
                                      Then
                                      npm start
                                      After turning off any pm2 instance
                                      Then you haven’t touched your good config
                                      Can stop any time, have only one module of output to deal with
                                      Once all good, you copy this one module def to your good config
                                        pat59 @pat59
                                        Sorry to be back, I had to be away. I’m taking this opportunity to ask you to close the request as I’m currently unable to address the issue. Thank you for your understanding.
                                        Sincerely,
                                        I would like to thank everyone who contributed. See you soon.
                                          sdetweil @pat59
                                          @pat59 no problem leaving it open. Come back when you can.
