    MMM-MyTasklist
    18 Posts 6 Posters 3.5k Views 6 Watching
      sdetweil @htilburgs
      @htilburgs none that I know of. Anything 8000 and above is ‘free’ of system requirements.
      • karsten13K
        karsten13 @htilburgs
        @htilburgs said in MMM-MyTasklist:
        Is there a tule for the Ports? Which I can use or not use?
        you could add a config param for the port so that everyone who collides with 8123 could choose another one without hacking the source code
        htilburgsH 1 Reply Last reply Reply Quote 1
        • htilburgsH
          htilburgs @karsten13
          @karsten13
          I know that is an option. The fast fix now is that I have changed the port to 8448
          (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
          • htilburgsH
            htilburgs @htilburgs
            I Just published v1.2.0
            This is an update with EDIT possibility in the Webinterface
              chrisfr1976 @htilburgs
              @htilburgs I love this module already due to its simplicity. One small issue: the web interface always jumps back to Netherlands on a reload. Maybe this can be saved in the json with the tasks. Or as an Option in the config.
              And on a phone display the text for edit and delete is quite wide. Maybe just symbols would be better.
              Regards, Chris.
              htilburgsH M 2 Replies Last reply Reply Quote 0
              • htilburgsH
                htilburgs @chrisfr1976
                @chrisfr1976
                That was the reason for me to create this (Simple) module.
                Just this and nothing more.
                On my site, the language is saved in the tasks.json and reloaded when I reload the page. I have to check. I’m Currently in a short holliday, but if you can you can make an issue in github so I don’t forget. I come back to you.
                  meikelrix @chrisfr1976
                  @chrisfr1976 you can change line 214 in .public/script.js from
                  lang = data.lang || “nl”;
                  into
                  lang = data.lang || “en”;
                  This loads english for me as default now. Maybe that can be put into the config.js?
                  htilburgsH 1 Reply Last reply Reply Quote 0
                  • htilburgsH
                    htilburgs @meikelrix
                    @meikelrix @chrisfr1976
                    MMM-MyTasklist is updated to v1.2.1 with correct language support in the Webinterface
                    • G
                      Getinthegames
                      Maybe someone can help.
                      I cannot seem to reach the web interface using http://localIP:8448.
                      I know I got it right because I connect to my RaspberryPi in VNC and SSH without issue, but when I put the IP:8448 i get a “Site Unreachable” error.
                      I’m not running anything but Magic Mirror on the device.
                      S G 2 Replies Last reply Reply Quote 0
                        sdetweil @Getinthegames
                        @Getinthegames by default MagicMirror is at 8080
                        Did you update the config.js? And to allow outside system connections?
                        port:
                        address:
                        ipWhitelist:
                        G 1 Reply Last reply Reply Quote 1
                        • G
                          Getinthegames @sdetweil
                          My bad. Case of CamelToe.
                          Installed it in MMM-MyTaskList instead of MyTasklist
                          Works fine now.
                          • G
                            Getinthegames @Getinthegames
                            Seems like a case of CamelToe.
                            I installed MyTaskList instead of MyTasklist.
                            Works great now and love it. Simple for a family shared list.
                            • htilburgsH
                              htilburgs @Getinthegames
                              @Getinthegames
                              Thank you, that was the reason for me to create this module, simplicity.
                              I didn’t need all the extras, just a simple list.
