    MMM-MyTasklist
    18 Posts 6 Posters 986 Views 6 Watching
    • htilburgsH Offline
      htilburgs @chrisfr1976
      @chrisfr1976
      Thank you 👍
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
        sdetweil @htilburgs
        @htilburgs none that I know of. Anything 8000 and above is ‘free’ of system requirements.
        • karsten13K Offline
          karsten13 @htilburgs
          @htilburgs said in MMM-MyTasklist:
          Is there a tule for the Ports? Which I can use or not use?
          you could add a config param for the port so that everyone who collides with 8123 could choose another one without hacking the source code
          htilburgsH 1 Reply Last reply Reply Quote 1
            htilburgs @karsten13
            @karsten13
            I know that is an option. The fast fix now is that I have changed the port to 8448
              htilburgs @htilburgs
              I Just published v1.2.0
              This is an update with EDIT possibility in the Webinterface
                chrisfr1976 @htilburgs
                @htilburgs I love this module already due to its simplicity. One small issue: the web interface always jumps back to Netherlands on a reload. Maybe this can be saved in the json with the tasks. Or as an Option in the config.
                And on a phone display the text for edit and delete is quite wide. Maybe just symbols would be better.
                Regards, Chris.
                htilburgsH M 2 Replies Last reply Reply Quote 0
                  @chrisfr1976
                  That was the reason for me to create this (Simple) module.
                  Just this and nothing more.
                  On my site, the language is saved in the tasks.json and reloaded when I reload the page. I have to check. I’m Currently in a short holliday, but if you can you can make an issue in github so I don’t forget. I come back to you.
                    meikelrix @chrisfr1976
                    @chrisfr1976 you can change line 214 in .public/script.js from
                    lang = data.lang || “nl”;
                    into
                    lang = data.lang || “en”;
                    This loads english for me as default now. Maybe that can be put into the config.js?
                    htilburgsH 1 Reply Last reply Reply Quote 0
                      htilburgs @meikelrix
                      @meikelrix @chrisfr1976
                      MMM-MyTasklist is updated to v1.2.1 with correct language support in the Webinterface
                      • G Offline
                        Getinthegames
                        Maybe someone can help.
                        I cannot seem to reach the web interface using http://localIP:8448.
                        I know I got it right because I connect to my RaspberryPi in VNC and SSH without issue, but when I put the IP:8448 i get a “Site Unreachable” error.
                        I’m not running anything but Magic Mirror on the device.
                        S G 2 Replies Last reply Reply Quote 0
