    MMM-MyTasklist
    18 Posts 6 Posters 1.4k Views 6 Watching
    • htilburgsH Offline
      htilburgs
      MMM-MyTasklist
      This a module for Magic Mirror².
      This displays a simple Tasklist, you can update through a web frontend.
      Installation
      Clone this repository in your modules folder, and install dependencies:
      cd ~/MagicMirror/modules
      git clone https://github.com/htilburgs/MMM-MyTasklist.git
      cd MMM-MyTasklist
      npm install
      Update
      When you need to update this module:
      cd ~/MagicMirror/modules/MMM-MyTasklist
      git pull
      npm install
      Configuration
      Go to the MagicMirror/config directory and edit the config.js file.
      Add the module to your modules array in your config.js.
        module: "MMM-MyTasklist",
        header: "MyTaskList",
        disabled: false,
          tasksFile: "modules/MMM-MyTasklist/tasks.json",
          updateInterval: 300000,
          showCompleted: true,
          maxTasks: null
      Load Webinterface for updating the Tasklist
      Open a browser and type http://serverip address:8448
      So if for example you’re MagicMirror is on 192.168.0.48 then you go to http://192.168.0.48:8448
      The Webinterface for MyTasklist will be loaded and you will be able to:
      • choose language for the Webinterface
      • add tasks
      • complete tasks
      • delete tasks
      • edit tasks
      • move the order from tasks by drag-and-drop
      • filter on all, active or done tasks
      All the updates are instantly published on your Mirror
      NOTE:
      With a touchscreen you’re able to check the checkboxes on the Mirror to complete the task.
      All these changes are instantly published to the Webinterface
      Versions
      v1.0.0 - Initial release
      v1.1.0 - Update Look & Feel
      v1.1.1 - Change Webinterface port from 8123 to 8448
      v1.2.0 - Add possibility to edit the tasks in the Webinterface
      v1.2.1 - Update language selector didn’t work correct in Webinterface (always dutch after reload)
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
      C S 2 Replies Last reply Reply Quote 3
        chrisfr1976 @htilburgs
        @htilburgs Really nice and useful. Great job!
        Regards, Chris.
        htilburgsH 1 Reply Last reply Reply Quote 0
          sdetweil @htilburgs
          @htilburgs you might consider changing the port number. HomeAssistant uses 8123
          so both on the same machine will collide
            htilburgs @sdetweil
            Oké, I didn’t know. Let me see in an hour.
            Is there a rule for the Ports? Which I can use or not use?
            S karsten13K 2 Replies Last reply Reply Quote 0
              htilburgs @chrisfr1976
              @chrisfr1976
              Thank you 👍
                sdetweil @htilburgs
                @htilburgs none that I know of. Anything 8000 and above is ‘free’ of system requirements.
                • karsten13K Offline
                  karsten13 @htilburgs
                  @htilburgs said in MMM-MyTasklist:
                  Is there a tule for the Ports? Which I can use or not use?
                  you could add a config param for the port so that everyone who collides with 8123 could choose another one without hacking the source code
                  htilburgsH 1 Reply Last reply Reply Quote 1
                    htilburgs @karsten13
                    @karsten13
                    I know that is an option. The fast fix now is that I have changed the port to 8448
                      htilburgs @htilburgs
                      I Just published v1.2.0
                      This is an update with EDIT possibility in the Webinterface
                        @htilburgs I love this module already due to its simplicity. One small issue: the web interface always jumps back to Netherlands on a reload. Maybe this can be saved in the json with the tasks. Or as an Option in the config.
                        And on a phone display the text for edit and delete is quite wide. Maybe just symbols would be better.
                        Regards, Chris.
                        htilburgsH M 2 Replies Last reply Reply Quote 0
                          @chrisfr1976
                          That was the reason for me to create this (Simple) module.
                          Just this and nothing more.
                          On my site, the language is saved in the tasks.json and reloaded when I reload the page. I have to check. I’m Currently in a short holliday, but if you can you can make an issue in github so I don’t forget. I come back to you.
                            meikelrix @chrisfr1976
                            @chrisfr1976 you can change line 214 in .public/script.js from
                            lang = data.lang || “nl”;
                            into
                            lang = data.lang || “en”;
                            This loads english for me as default now. Maybe that can be put into the config.js?
                              htilburgs @meikelrix
                              @meikelrix @chrisfr1976
                              MMM-MyTasklist is updated to v1.2.1 with correct language support in the Webinterface
                              • G Offline
                                Getinthegames
                                Maybe someone can help.
                                I cannot seem to reach the web interface using http://localIP:8448.
                                I know I got it right because I connect to my RaspberryPi in VNC and SSH without issue, but when I put the IP:8448 i get a “Site Unreachable” error.
                                I’m not running anything but Magic Mirror on the device.
                                S G 2 Replies Last reply Reply Quote 0
                                  sdetweil @Getinthegames
                                  @Getinthegames by default MagicMirror is at 8080
                                  Did you update the config.js? And to allow outside system connections?
                                  port:
                                  address:
                                  ipWhitelist:
                                  G 1 Reply Last reply Reply Quote 1
                                  • G Offline
                                    Getinthegames @sdetweil
                                    My bad. Case of CamelToe.
                                    Installed it in MMM-MyTaskList instead of MyTasklist
                                    Works fine now.
                                    • G Offline
                                      Getinthegames @Getinthegames
                                      Seems like a case of CamelToe.
                                      I installed MyTaskList instead of MyTasklist.
                                      Works great now and love it. Simple for a family shared list.
                                        htilburgs @Getinthegames
                                        @Getinthegames
                                        Thank you, that was the reason for me to create this module, simplicity.
                                        I didn’t need all the extras, just a simple list.
