    MMM-JAST stopped updating a couple of days ago.
    26 Posts 7 Posters 4.9k Views 6 Watching
    • V
      vgardenn @KristjanESPERANTO
      @KristjanESPERANTO Here is my system info from the npm run start output:
      ####  System Information  ####
      - SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 5 Model B Rev 1.0; virtual: false; MM: 2.34.0
      - OS:       platform: linux; distro: Debian GNU/Linux; release: 13; arch: arm64; kernel: 6.12.62+rpt-rpi-2712
      - VERSIONS: electron: 39.2.7; used node: 22.21.1; installed node: 22.21.1; npm: 10.9.4; pm2: 6.0.14
      - ENV:      XDG_SESSION_TYPE: tty; MM_CONFIG_FILE: undefined
                  WAYLAND_DISPLAY:  undefined; DISPLAY: :0; ELECTRON_ENABLE_GPU: undefined
      - RAM:      total: 8062.92 MB; free: 7342.48 MB; used: 720.44 MB
      - OTHERS:   uptime: 12 minutes; timeZone: America/Chicago
      This also highlighted an error I may have been missing in the pm2 logs output, so it may not be a module issue at all. I apologize if I had you looking at this and it was just an issue with my MM setup. I’ll start researching what this error means:
      [2026-01-19 18:14:54.626] [ERROR] [app] WARNING! Config file appears empty, maybe missing module.exports last line?
      [2026-01-19 18:14:54.627] [ERROR] [app] WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: userConfig.modules is not iterable
        sdetweil @vgardenn
        @vgardenn show the last 5 lines of config.js
        Compare to the sample in the same folder
        What is this?
        userConfig.modules
        • V
          vgardenn
          I’m unsure what that userConfig.modules is, from my googling it seems maybe related to node.js?
          Here is the entire config.js. The last 5 lines look similar to the sample config:
          let config = {
                module: "MMM-MagicMover",
                module: "clock",
                position: "top_bar",
          	timeFormat: 12,
          	displaySeconds: false,
          	dateFormat: "dddd, MMMM D",
                module: "weather",
                position: "top_center",
          	weatherProvider: "weathergov",
                  type: "current",
          	tempUnits: "imperial",
          	roundTemp: true,
          	showFeelsLike: false,
          	colored: true,
          	showSun: false,
          	lat: "xxxxxx",
          	lon: "xxxxxxx",
                module: "MMM-Jast",
                position: "middle_center",
          	displayMode: "none",
          	stocks: [
          	  { name: 'DJIA', symbol: 'DIA' },
          	  { name: 'SP500', symbol: 'VOO' }
                 disabled: true,
                 module: "MMM-NowPlayingOnSpotify",
                 position: "bottom_center",
                 	 showCoverArt: false,
                   clientID: "<YOUR_CLIENT_ID>",
                   clientSecret: "<YOUR_CLIENT_SECRET>",
                   accessToken: "<YOUR_ACCESS_TOKEN>",
                   refreshToken: "<YOUR_REFRESH_TOKEN>"
            sdetweil @vgardenn
            @vgardenn these lines are not at the bottom of your config file
            Typically to start your MagicMirror journey
            You copy the sample and edit the copy for your use
            V 1 Reply Last reply
            • V
              vgardenn @sdetweil
              Well you called it correct, I did not start with the sample config and adding that missing line at the end of my config got this mod working as expected. I had grabbed the example config from documentation here assuming it was good enough and was off to the races.
              Thank you very much for your help on this @sdetweil and @kristjanesperanto
                sdetweil @vgardenn
                @vgardenn cool. We’ll fix that
                The MagicMirror install doc says
