    MMM-JAST stopped updating a couple of days ago.
    26 Posts 7 Posters 3.8k Views 6 Watching
    • 1 Offline
      1a2a3a @KristjanESPERANTO
      @KristjanESPERANTO hi, i have updated to the latest version but my modules is still stuck at loading. any idea?
      • KristjanESPERANTOK Offline
        KristjanESPERANTO Module Developer @1a2a3a
        @1a2a3a Any unusual log entries in the node or browser console? Do you use the current MM version?
        • plainbrokeP Offline
          plainbroke @KristjanESPERANTO
          @KristjanESPERANTO
          I hate to jump on the bandwagon, but I am also having an issue with it saying undefined. I did do the git pull and npm install on MMM-Jast since it is the only one of 48 modules that stopped working… Kind of amazing, Since some of them are getting to be old modules… Running Trixie and latest MM. Pi4 8gb fully up to date…
            KristjanESPERANTO Module Developer @plainbroke
            @plainbroke Please update to v2.10.3 and check. If it doesn’t work: Any unusual log entries in the node or browser console? Show me your config.
              @KristjanESPERANTO
              I had to remove and reinstall, just updating with git pull did not fix it, but the reinstall fixed it. Thanks for your efforts.
              Much appreciated.
                sdetweil @plainbroke
                @plainbroke did you do an npm install after the git pull?
                  plainbroke @sdetweil
                  Yes
                  npm ci
                  Like his read me says to.
                  Worked with reinstall so alls good on my mirror again.
                  • 1 Offline
                    1a2a3a
                    Ok, after git pull, had to do a npm ci and that fixes it!
                    • V Offline
                      vgardenn
                      Hi, I’m stuck at “Loading…” on this module as well. This is a new build I’ve been working on in the last week or so, first timer with MagicMirror so hopefully I’m not missing something obvious. I’ve not been able to get MMM-Jast to display any values at all, but I can get other modules working no problem.
                      I’m running the latest 2.10.3 version and I’ve removed and reinstalled it a few times, as well as completely reloaded my raspi device from scratch, but no luck. pm2 logs don’t show any errors, but I’m unsure what other logs to evaluate.
                      Here is my config. I’ve tried a bunch of different config options to see if anything kicks it into gear, including a completely bare config with just the example config from the README, but each attempt just shows “Loading”.
                            module: "MMM-Jast",
                            position: "middle_center",
                              displayMode: "none",
                              stocks: [
                                { name: 'DJIA', symbol: 'DIA' },
                                { name: 'SP500', symbol: 'VOO' },
                        KristjanESPERANTO Module Developer @vgardenn
                        @vgardenn Interesting. Your config works on my system.
                        Please show us your system information (you can see it when you run npm run start) - and looks like this:
                        [2026-01-19 21:07:04.407] [INFO]  [systeminformation]
                        ####  System Information  ####
                        - SYSTEM:   manufacturer: Micro-Star International Co., Ltd.; model: MS-7D75; virtual: false; MM: v2.35.0-develop
                        - OS:       platform: linux; distro: Debian GNU/Linux; release: forky/sid; arch: x64; kernel: 6.17.13+deb14-amd64
                        - VERSIONS: electron: 39.2.7; used node: 25.0.0; installed node: 25.0.0; npm: 11.7.0; pm2: 6.0.14
                        - ENV:      XDG_SESSION_TYPE: wayland; MM_CONFIG_FILE: modules/MMM-Jast/config.demo.js
                                    WAYLAND_DISPLAY:  wayland-0; DISPLAY: :0; ELECTRON_ENABLE_GPU: undefined
                        - RAM:      total: 61884.49 MB; free: 52612.92 MB; used: 9271.57 MB
                        - OTHERS:   uptime: 60 minutes; timeZone: Europe/Berlin
                        • V Offline
                          vgardenn @KristjanESPERANTO
                          @KristjanESPERANTO Here is my system info from the npm run start output:
                          - SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 5 Model B Rev 1.0; virtual: false; MM: 2.34.0
                          - OS:       platform: linux; distro: Debian GNU/Linux; release: 13; arch: arm64; kernel: 6.12.62+rpt-rpi-2712
                          - VERSIONS: electron: 39.2.7; used node: 22.21.1; installed node: 22.21.1; npm: 10.9.4; pm2: 6.0.14
                          - ENV:      XDG_SESSION_TYPE: tty; MM_CONFIG_FILE: undefined
                                      WAYLAND_DISPLAY:  undefined; DISPLAY: :0; ELECTRON_ENABLE_GPU: undefined
                          - RAM:      total: 8062.92 MB; free: 7342.48 MB; used: 720.44 MB
                          - OTHERS:   uptime: 12 minutes; timeZone: America/Chicago
                          This also highlighted an error I may have been missing in the pm2 logs output, so it may not be a module issue at all. I apologize if I had you looking at this and it was just an issue with my MM setup. I’ll start researching what this error means:
                          [2026-01-19 18:14:54.626] [ERROR] [app] WARNING! Config file appears empty, maybe missing module.exports last line?
                          [2026-01-19 18:14:54.627] [ERROR] [app] WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: userConfig.modules is not iterable
                            sdetweil @vgardenn
                            @vgardenn show the last 5 lines of config.js
                            Compare to the sample in the same folder
                            What is this?
                            userConfig.modules
                            • V Offline
                              vgardenn
                              I’m unsure what that userConfig.modules is, from my googling it seems maybe related to node.js?
                              Here is the entire config.js. The last 5 lines look similar to the sample config:
                              let config = {
                                    module: "MMM-MagicMover",
                                    module: "clock",
                                    position: "top_bar",
                              	timeFormat: 12,
                              	displaySeconds: false,
                              	dateFormat: "dddd, MMMM D",
                                    module: "weather",
                                    position: "top_center",
                              	weatherProvider: "weathergov",
                                      type: "current",
                              	tempUnits: "imperial",
                              	roundTemp: true,
                              	showFeelsLike: false,
                              	colored: true,
                              	showSun: false,
                              	lat: "xxxxxx",
                              	lon: "xxxxxxx",
                                    module: "MMM-Jast",
                              	stocks: [
                                     disabled: true,
                                     module: "MMM-NowPlayingOnSpotify",
                                     position: "bottom_center",
                                     	 showCoverArt: false,
                                       clientID: "<YOUR_CLIENT_ID>",
                                       clientSecret: "<YOUR_CLIENT_SECRET>",
                                       accessToken: "<YOUR_ACCESS_TOKEN>",
                                       refreshToken: "<YOUR_REFRESH_TOKEN>"
                                sdetweil @vgardenn
                                @vgardenn these lines are not at the bottom of your config file
                                Typically to start your MagicMirror journey
                                You copy the sample and edit the copy for your use
                                • V Offline
                                  vgardenn @sdetweil
                                  Well you called it correct, I did not start with the sample config and adding that missing line at the end of my config got this mod working as expected. I had grabbed the example config from documentation here assuming it was good enough and was off to the races.
                                  Thank you very much for your help on this @sdetweil and @kristjanesperanto
                                    sdetweil @vgardenn
                                    @vgardenn cool. We’ll fix that
                                    The MagicMirror install doc says
