    obsession with modul checker
    19 Posts 4 Posters 1.3k Views 4 Watching
    • H Offline
      HeikoGr
      I am obsessed with the modul checker on the MagicMirror² 3rd Party Modules list…
      so, i asked github copilot to implement an instant modul checker script.
      technically it clones the modul checker repo, and the local files to /tmp/mm-modul-checker… and installs the deps.
      you can find it in recently most active repo:
      https://github.com/HeikoGr/MMM-Webuntis/blob/master/scripts/magicmirror-check.mjs
      run it: node scripts/magicmirror-check.mjs and you will get:
      > mmm-webuntis@0.6.1 check:mm
      🔍 Setting up MagicMirror checker...
      Fetching checker repository (git-free) via `degit` (first time only)...
      📦 Installing dependencies...
      ✓ Copying local files (excluding node_modules)...
      ✓ Checking MMM-Webuntis (including uncommitted changes)
      🔎 Running full module checks...
      🔍 Running ESLint check on package.json...
      MMM-Webuntis - MagicMirror Module Check Results
      📋 Issues found (1):
        1. Information: There are updates for 1 dependencie(s):
      - prettier  ^3.8.0  →  ^3.8.1
      📄 Results saved to: magicmirror-check-results.md
      Compare with: https://modules.magicmirror.builders/result.html
      💡 Tip: Use --cleanup to remove checker files after check
      htilburgsH 1 Reply Last reply Reply Quote 1
      • htilburgsH Offline
        htilburgs @HeikoGr
        @HeikoGr said in obsession with modul checker:
        I tried it, but get an error
        ❌ Error: Cannot copy a FIFO pipe: cp returned EINVAL (cannot copy a FIFO pipe: /tmp/mm-module-checker-MagicMirror/modules/MagicMirror-----MagicMirrorOrg/.lgd-nfy0) /tmp/mm-module-checker-MagicMirror/modules/MagicMirror-----MagicMirrorOrg/.lgd-nfy0
        (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
        • H Offline
          HeikoGr
          you need to put the script inside the folder of the module you want to check - not the MagicMirror folder itself
          htilburgsH 1 Reply Last reply Reply Quote 0
            htilburgs @HeikoGr
            @HeikoGr
            So it is not possible to check all the modules in one run?
            I have to do it for each module?
            • H Offline
              HeikoGr @htilburgs
              @htilburgs my main objection was to support the module development. so yes, at the moment it’s a per module check,
                htilburgs @HeikoGr
                @HeikoGr
                Oké, clear. Thanks for the quick replys
                • KristjanESPERANTOK Online
                  KristjanESPERANTO Module Developer @htilburgs
                  @heikogr Nice idea! I’ll take a closer look.
                  • H Offline
                    HeikoGr
                    @htilburgs now it should work for all installed modules
                      htilburgs @HeikoGr
                      @HeikoGr
                      So now I put It in the MagicMirror folder?
                      • H Offline
                        HeikoGr @htilburgs
                        @htilburgs the script looks if it is under an magicmirror/modules folder and takes this as root folder for modules.
                        otherwise it will take /opt/magic_mirror/modules
                        if your setup is different you need to adapt the script.
                        the script itself can be placed independently
                        htilburgsH S 2 Replies Last reply Reply Quote 0
                          htilburgs @HeikoGr
                          @HeikoGr
                          Oké, thank you
                            sdetweil @HeikoGr
                            @HeikoGr the script could check and provide a parameter
                              htilburgs @htilburgs
                              @heikogr
                              I gave it a testrun and it gave me an error
                               Running checks for 17 modules...
                              ❌ Error: Command failed: npx tsx scripts/check-modules/index.ts
                              npm warn exec The following package was not found and will be installed: tsx@4.21.0
                              [2026-01-23T17:21:24.195Z] [ERROR] [check-modules] Schema validation failed for modules.stage.4:
                              /modules/6/keywords: must NOT have fewer than 1 items
                              /modules/8/keywords: must NOT have fewer than 1 items
                              /modules/15/keywords: must NOT have fewer than 1 items
                              Any idea?
                                After installing tsx (npm install tsx@4.21.0) it gave me a new error:
                                🔎 Running checks for 17 modules...
                                [2026-01-23T17:25:32.134Z] [ERROR] [check-modules] Schema validation failed for modules.stage.4:
                                H KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
                                • H Offline
                                  HeikoGr @htilburgs
                                  @htilburgs i guess your modules are missing the minimal requirements for MagicMirror modules in the packages.json file.
                                  I managed to lower the requirements…
                                    @htilburgs In case you haven’t seen it yet: You can also check https://modules.magicmirror.builders/result.html#MMM-MyHomeWizard-by-HTilburgs. Thats the result of the checks on what you pushed to GitHub.
                                      htilburgs @KristjanESPERANTO
                                      @KristjanESPERANTO
                                      Thanks, I didn’t know about this.
                                      This is the result of running the script?
                                      • H Offline
                                        HeikoGr @htilburgs
                                        @htilburgs it‘s the original script. My script only tries to run this script locally on demand
                                          htilburgs @HeikoGr
                                          @HeikoGr 👍
