    MMM-Webuntis
    Scheduled Pinned Locked Moved Education
    71 Posts 11 Posters 9.8k Views 11 Watching
    • H Offline
      HeikoGr @ochja
      @ochja it should be possible to add support for teacher accounts - but i have no ways to implement/support/test it.
      Can you turn on logging (for MagicMirror and Webuntis module) an send me the logs?
      You may need to redact the logs before sending me any files.
      • O Offline
        ochja @HeikoGr
        @HeikoGr
        It would be great if you could take a look at the logs. Before trying the QR code method, I also tried the “normal” login, but I didn’t get any further.
        logs:
        https://we.tl/t-zTm0HFmRPn
          magicghost
          My 1st post and my 1st 24h with MagicMirrow:
          I was able to get the webuntis app working with the QR code link after I changed the login name, which contains a „ö“ letter. The QR code has the letter <0xF6> rewritten.
          I get the changes of the timetable, how I can get a full timetable for today and next day, so that I can get rid of the printed timetable.
          Erik
          • H Offline
            HeikoGr @magicghost
            @magicghost
            this should work as minimum working example for your requirements.
                  module: "MMM-Webuntis",
                    displayMode: 'grid',
                    grid: {
                      nextDays: 1, // today plus tomorrow = 2 days
                      maxLessons: 0, // max lessons per day (0 = no limit)
                    students: [
                        title: "NAME",
                        qrcode: "untis://setschool?...", //your qrcode
              magicghost @HeikoGr
              @HeikoGr
              Great - exactly what I wanted. Thanks!
              One small question - I have two kids and both kids with two days in one tall box. Is it possible to get them side by side?
              • H Offline
                HeikoGr @magicghost
                @magicghost yes, just define two modules. or maybe there are some fancy css hacks possible? i choose the first option for my two kids.
                  magicghost @HeikoGr
                  @HeikoGr
                  Thanks a lot.
                  One issue I have with „ö“ in the Login Name. It worked some days, then I edit the config file with Winscp - now the encoding is wrong and the login results with an error that - The output shows for the „ö“ an special character…. With authentication failed.
                  Any idea how to fix this?
                  • H Offline
                    HeikoGr
                    you can change the encoding in winscp to utf-8 then it should work again
                    • H Offline
                      HeikoGr
                      i recently messed up the github repository.
                      If your last update was ~2 weeks ago you should be fine.
                      Otherwise your update may fail.
                      You can get the most recent versions in this way:
                      There was no new feature in the last days. Only a more robust session management (hopefully) and internal changes.
                      cd ~/MagicMirror/modules/MMM-Webuntis
                      # Reset to match the remote repository
                      git fetch origin
                      git reset --hard origin/master
                      npm ci --omit=dev
                      I’m sorry for any inconvenience!
                        magicghost
                        Thanks a lot for your Support- is it possible to load also the class Book, if there is any entry about the Child? Would be good to get records of the actual month.
                        • 7 / 8
