    MMM-Webuntis
    Scheduled Pinned Locked Moved Education
    82 Posts 13 Posters 32.0k Views 13 Watching
    • H
      HeikoGr @ochja
      @ochja it should be possible to add support for teacher accounts - but i have no ways to implement/support/test it.
      Can you turn on logging (for MagicMirror and Webuntis module) an send me the logs?
      You may need to redact the logs before sending me any files.
      • O
        ochja @HeikoGr
        @HeikoGr
        It would be great if you could take a look at the logs. Before trying the QR code method, I also tried the “normal” login, but I didn’t get any further.
        logs:
        https://we.tl/t-zTm0HFmRPn
          magicghost
          My 1st post and my 1st 24h with MagicMirrow:
          I was able to get the webuntis app working with the QR code link after I changed the login name, which contains a „ö“ letter. The QR code has the letter <0xF6> rewritten.
          I get the changes of the timetable, how I can get a full timetable for today and next day, so that I can get rid of the printed timetable.
          Erik
          • H
            HeikoGr @magicghost
            @magicghost
            this should work as minimum working example for your requirements.
                  module: "MMM-Webuntis",
                    displayMode: 'grid',
                    grid: {
                      nextDays: 1, // today plus tomorrow = 2 days
                      maxLessons: 0, // max lessons per day (0 = no limit)
                    students: [
                        title: "NAME",
                        qrcode: "untis://setschool?...", //your qrcode
              magicghost @HeikoGr
              @HeikoGr
              Great - exactly what I wanted. Thanks!
              One small question - I have two kids and both kids with two days in one tall box. Is it possible to get them side by side?
              • H
                HeikoGr @magicghost
                @magicghost yes, just define two modules. or maybe there are some fancy css hacks possible? i choose the first option for my two kids.
                  magicghost @HeikoGr
                  @HeikoGr
                  Thanks a lot.
                  One issue I have with „ö“ in the Login Name. It worked some days, then I edit the config file with Winscp - now the encoding is wrong and the login results with an error that - The output shows for the „ö“ an special character…. With authentication failed.
                  Any idea how to fix this?
                  • H
                    HeikoGr
                    you can change the encoding in winscp to utf-8 then it should work again
                    • H
                      HeikoGr
                      i recently messed up the github repository.
                      If your last update was ~2 weeks ago you should be fine.
                      Otherwise your update may fail.
                      You can get the most recent versions in this way:
                      There was no new feature in the last days. Only a more robust session management (hopefully) and internal changes.
                      cd ~/MagicMirror/modules/MMM-Webuntis
                      # Reset to match the remote repository
                      git fetch origin
                      git reset --hard origin/master
                      npm ci --omit=dev
                      I’m sorry for any inconvenience!
                        magicghost
                        Thanks a lot for your Support- is it possible to load also the class Book, if there is any entry about the Child? Would be good to get records of the actual month.
                        • H
                          HeikoGr @magicghost
                          @magicghost our school doesn’t offer this untis feature for us, so i can’t implement and test it. youcan add this feature if you want/can do it
                            meralith
                            Hi Heiko,
                            ich bin gerade am Update des Moduls und hänge an der Stelle, dass er mir keinen Stundenplan anzeigt. Der Login läuft über den Direct Login mit Username und Passwort. Die Daten habe ich mit dem Skript (./scripts/test_auth_with_curl.sh “school” “server.webuntis.com” “username” “password”) kontrolliert und da stand, dass alles passt.
                            Im Log erhalte ich allerdings Folgendes: 0|mm | [2839:0309/111715.890708:ERROR:gbm_wrapper.cc(79)] Failed to get fd for plane.: Datei oder Verzeichnis nicht gefunden (2)
                            0|mm | [2839:0309/111715.891030:ERROR:gbm_wrapper.cc(262)] Failed to export buffer to dma_buf: Datei oder Verzeichnis nicht gefunden (2)
                            0|mm | [2026-03-09 11:17:26.229] [WARN] [Mayra] No REST targets built - cannot fetch data! Check authentication and credentials.
                            Leider bin ich da aktuell mit meinem Latein am Ende. Hast du da zufällig die zündende Idee?
                            LG, Meralith
                            • H
                              HeikoGr @meralith
                              @meralith die Fehler:
                              kommen sicher nicht vom MMM-Webuntis Modul sondern vom Chrome / Electon und sind vermutlich harmlos.
                              • Welches Version von Node.js läuft bei dir (node -v)?
                              • Hast du npm ci --omit=dev (oder npm install ausgeführt?)
                              • Hast du Sonderzeichen im Anmeldenamen?
                              Alternativ kannst du mal den qrcode login ausprobieren.
                                meralith @HeikoGr
                                @HeikoGr
                                • node Version habe ich geupdated auf v20.18.1.
                                • ausgeführt habe ich npm install.
                                • keine Sonderzeichen
                                Nach der Aktualisierung von node und Verwendung von qrcode login zeigt es den Stundenplan jetzt an.
                                Danke für den Anstoß!
                                • H
                                  HeikoGr @meralith
                                  @meralith Danke für die Rückmeldung. Ich habe node.js in der Version 20.18.1 jetzt mal als Bedingung in der Readme formuliert.
                                  Falls du noch irgendwoe Probleme, Fragen oder Anregungen hast - einfach melden!
                                    DerHerrB
                                    Hallo!
                                    Ich habe gerade MMM-Webuntis installiert, läuft auch, bis auf eine häßliche Fehlermeldung.
                                    Hintergrund: Ich nutze Webuntis/Untis als Lehrer und ich finde nirgendwo den key und auch keinen QR-Code
                                    Liebe Grüße
                                    Julian
                                    • H
                                      HeikoGr @DerHerrB
                                      @DerHerrB
                                      Was sagt die Fehlermeldung denn?
                                      Du kannst deinen Stundplan sehen? Weil dann ist die Fehlermeldung vermutlich zuviel ;-)
                                      Den Qrcode gibts auf der Einstellungen Seite (links unten auf den Benutzernamen gehen und dann den Tab „Freigaben“ ansteuern.
                                      Lehreraccounts sind für mich leider nicht testbar.
                                        DerHerrB
                                        Den Studenplan sehe ich, allerdings wird er einmal beim Start geladen und updatet sich nicht
                                        Einen QR-Code gibt es an der beschriebenen Stelle leider auch nicht
                                        Fehlermeldung:
                                        Webuntis Server Error (http 500) for “title” This is temporary Retrying automatically…
                                        Ich schreib Dir mal eine PN
                                        • H
                                          HeikoGr @DerHerrB
                                          Fehlermeldung:
                                          Danke - das hilft mir schon mal weiter.
                                          Die Fehlermeldung sagt, dass für den Schüler “title” die Daten nicht geladen werden konnten. Da du kein Schüler bist, hast du auch keine studentID und die API läuft auf Fehler.
                                          Ich habe jetzt für die Rolle “TEACHER” die Schülerbezogenen APIs abgeklemmt. Also Hausaufgaben, Fehlzeiten und Klassenarbeiten bekommst du jetzt keine mehr angezeigt.
                                          Kannst du einmal das Modul bitte updaten? und mir Rückmeldung geben, ob es jetzt funktioniert?
                                            DerHerrB @HeikoGr
                                            @HeikoGr schaut super aus!
                                            Danke vielmals
                                            • 4 / 5
