    Camera intigration in your Mirror
    23 Posts 6 Posters 21.2k Views 11 Watching
    • L Offline
      lolobyte
      @schlachtkreuzer6 , @yawns , @andrei20wks , @reaper81
      and here some pictures from the Mirror it self.
        schlachtkreuzer6 @lolobyte
        @lolobyte WOW! that is great thank you very much! That helps me immensely :D
        which camera version are you using? the Pi Noir v2? and which transmision has the mirror?
        • SvenSommerS Offline
          SvenSommer @lolobyte
          @lolobyte
          I’m amazed by the quality of your picture with IR-Light.
          What kind of IR lamp are you using?
          I’m also using a raspi noir camera and integraded like 30 IR-Leds within the mirror to get a brighter picture.
          But always have problems with the face recognition. I assume it’s because the pictures used for comparing a black and white and for contrast reasons much darker.
          Looking for some building inspiration?
          Check out my large, thin and metal framed mirror on robstechlog.com.
          Modules released:
          MMM-GoogleAnalytics
          MMM-GrafanaChart
          MMM-GrafanaGauges
          • L Offline
            lolobyte @schlachtkreuzer6
            @schlachtkreuzer6
            https://www.conrad.de/de/raspberry-pi-kamera-gehaeusemodul-raspberry-pi-622959.html
            Full HD Video Auflösung mit 1080p
            Omnivision 5647 CMOS Bildsensor
            Maximale Framerate: 30 fps
            Integrierter IR-Filter
            5 Megapixel
              @lolobyte ah okay thats V1 so :) Thank you :)
              • L Offline
                lolobyte @SvenSommer
                @SvenSommer
                http://www.ebay.de/sch/sis.html?_nkw=Neu+Night+Vision+Infrared+LED+Board+Für+Rapsberry+Camera+Module+60+Array+3+Light&_id=181557695080&&_trksid=p2057872.m2749.l265
                  reaper81
                  @lolobyte Thanks also from my side. Is the IR-LED-board wired with the camera board? I see no wires for IR-powersupply to the Raspi in your picture. How do you enable/disable your mirror?
                  Are the camera and the IR-LEDs visible from the other side, through the mirros. And last but not least: What’s the function of the red-white and the blue-white cable?
                  • L Offline
                    lolobyte
                    Hello.
                    My fist step was mounting the IR together with the cam behind the mirror.
                    Was a disaster. From that point as the IR is starting, no really good picture was available.
                    After that i mounted the cam without IR and the IR extra outside from the Mirror.
                    The cam is not visible. The IR has his own power supply.
                    The mirror is enabled and disabled by the cam.
                    The blue/white cable is soldered on a switch (Taster) to be capable to make soft reset to the raspi mirror or to shutdown the raspi mirror. You can set the option in a python script.
                    I planed to install one other switch for a hard reset. I have recognized this switch will also enable the mirror after a shutdown an i didn’t must pull the Raspberry power supply.
                    The red/white one is also a switch (Taster) to enable the "Tagesschau in 100 sek.) with the MMM-Button and the MMM-Podcast modules.
                      reaper81
                      Where do you hide the IR-LEDs? In the Frame? Is there a special Module to use the Camera to disable the mirror or do you just disable all modules, if no face is recognized?
                      • L Offline
                        lolobyte @reaper81
                        @reaper81
                        No, the IR-Spot is completely at another place. This spot is mounted under the room cover above the mirror.
                        I use the cam SW to recognize any motion in the front of the mirror named MOTION-MMAL
                        Take a look for example at
                        https://embeddedday.com/projects/raspberry-pi/a-step-further/install-motion-mmal/
                        In the config file you can define how the SW has to work and which commands are executed by the SW.
                        Se also here in this Forum
                        https://forum.magicmirror.builders/topic/988/motion-detection-with-raspicam-non-module-version/
                          reaper81
                          Ok, sounds interesting. Can the Face-Recognitiontool and the MMAL-Motion share the camera? If I try to use the Camera with “raspistill” while the Face-Recog-Module is enable, I get an Error.
