    MMM-SwissStationboard
    10 Posts 5 Posters 4.5k Views 5 Watching
    • V Offline
      vanhoekd 0 Module Developer
      Description
      Hi all,
      I’ve made a module that shows you all your departing trains, busses, trams, metros, etc. in switzerland.
      Screenshot
      Stationboard
      #Download
      [card:vanhoekd/MMM-SwissStationboard]
      kwyjibo089K 1 Reply Last reply Reply Quote 1
      • kwyjibo089K Offline
        kwyjibo089 @vanhoekd 0
        @vanhoekd-0 beautiful!
        Added to my mirror and it looks great, thank you!
          magicmir
          When I specify a bus stop name, I have 2 results depending the direction… Is it possible to only get results for a specific direction ?
          Thanks !
          • V Offline
            Yes, have a look at the following module: https://github.com/nixnuex/MMM-SwissCommute/blob/master/README.md
              magicmir @vanhoekd 0
              @vanhoekd-0 Thanks for your reply. The URL you gave doesn’t work with bus station… Is that normal ?
              • V Offline
                Try finding the ID of your busstop with the following API: https://fahrplan.search.ch/api/stationboard.json?limit=1&stop=PUTNAMEHERE
                  magicmirror6043
                  Hi all, great module, thanks.
                  But why are the two top lines grey and not white ?
                  best regards … jr
                  S M 2 Replies Last reply Reply Quote 1
                    sdetweil @magicmirror6043
                    @magicmirror6043 because it’s past the time for those stops?
                    What time was the MagicMirror screenshot?
                      magicmirror6043 @magicmirror6043
                      Hi again, here are two screenshots fom 10:17 and 10:39 with lines greyed out that are in the future.
                        kwyjibo089
                        Check the minWalkingTime value in the config (https://github.com/vanhoekd/MMM-SwissStationboard?tab=readme-ov-file#using-the-module)
                        I guess yours is still at the 10min default?
