    $9 C.H.I.P.
    11 Posts 4 Posters 10.0k Views 5 Watching
    • KirAsh4K Offline
      KirAsh4 Moderator
      The blanking out is the screen saver kicking in, I think. You should be able to disable that. I’d have to go back and load mine up to see what I did, but I do remember running it for a while without it blanking out on me.
      • morozgrafixM Offline
        morozgrafix Moderator
        I dug up the CHIP that was sitting and collecting dust to see if I can run MM on it. It was almost successful. I documented my installation and setup path here https://gist.github.com/morozgrafix/db069203ac4d8635a0f27e3dfa52f532
        S R 2 Replies Last reply Reply Quote 1
          simongaviria1 @morozgrafix
          @morozgrafix sick! Can’t wait to try this out tonight. I’ve been trying to run MM on the chip for a bit now
          morozgrafixM 1 Reply Last reply Reply Quote 0
            morozgrafix Moderator @simongaviria1
            @simongaviria1 there are still a few limitations that I haven’t solved. It was more of an experiment to see if it would run.
              @morozgrafix Nonetheless, it’s still pretty exciting
                roramirez Core Contributors @morozgrafix
                @morozgrafix So cool.
                  If folks find it helpful. I can copy contents of that gist here. Just let me know.
