    RPi5 running hot
    12 Posts 4 Posters 5.0k Views 4 Watching
      mvrlogins
      I have a new 1GB RPi5 running the latest version of MM, installed using @sdetweil 's scripts
      It is running very hot at 84C
      I don’t have any cooling hardware and it is not installed in a case, but airflow around is not restricted at all.
      The only additional program I have running is go2rtc to stream an RTSP camera feed to an iFrame, but that is on a seperate page (using MMM-pages) that is only called on demand
      I have ordered a cooler, but wanted to see if there was something amiss.
      pi@MMPi5:~ $ top -b -n 1 | head -20
      top - 12:40:10 up  5:33,  4 users,  load average: 8.30, 8.04, 7.71
      Tasks: 232 total,   3 running, 229 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 77.8 us, 11.1 sy,  0.0 ni, 11.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   2006.8 total,    160.7 free,   1137.2 used,    870.8 buff/cache
      MiB Swap:   2006.0 total,   1966.0 free,     40.0 used.    869.5 avail Mem
          PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
       450392 pi        20   0 1143840  56256  41376 R 100.0   2.7   0:00.33 MainThr+
         2582 pi        20   0   32.6g 160848 132096 S  72.7   7.8 234:05.79 electron
         2685 pi        20   0 1407.7g 169824 113552 R  45.5   8.3 103:34.34 electron
       449306 pi        20   0 1415.9g 185040 120112 S  45.5   9.0   0:23.18 electron
         3153 pi        20   0 1407.8g 162912 101904 S  27.3   7.9 102:32.93 electron
         1334 pi        20   0  527936 116960  85824 S  18.2   5.7  72:06.61 labwc
         1525 pi        20   0 1408.1g 269904 160912 S  18.2  13.1  16:37.33 electron
         2658 pi        20   0   32.3g  88832  71040 S  18.2   4.3   9:05.59 electron
         3253 pi        20   0   32.5g  67680  53712 S   9.1   3.3  17:05.44 electron
        40449 pi        20   0 1245936  38560     16 S   9.1   1.9  19:24.04 go2rtc
       450399 pi        20   0   10368   5152   2800 R   9.1   0.3   0:00.02 top
            1 root      20   0   25712  13968   9424 S   0.0   0.7   0:01.83 systemd
            2 root      20   0       0      0      0 S   0.0   0.0   0:00.04 kthreadd
      pi@MMPi5:~ $
        mvrlogins
        The list of running modules -
        The EmbendURL modules only display on demand on a seperate page
        pi@MMPi5:~ $ curl -s http://localhost:8080/api/module | python3 -c "import sys,json; [print(m['identifier'], '-', m['name']) for m in json.load(sys.stdin)['data']]"
        module_0_alert - alert
        module_1_MMM-Remote-Control - MMM-Remote-Control
        module_2_MMM-pages - MMM-pages
        module_3_MMM-EmbedURL - MMM-EmbedURL
        module_4_MMM-EmbedURL - MMM-EmbedURL
        module_5_calendar - calendar
        module_6_iFrame - iFrame
        module_7_clock - clock
        module_8_MMM-Worldclock - MMM-Worldclock
        module_9_MMM-OpenWeatherForecast - MMM-OpenWeatherForecast
        module_10_MMM-EmbedURL - MMM-EmbedURL
        module_11_iFrame - iFrame
        module_12_newsfeed - newsfeed
        module_13_newsfeed - newsfeed
        pi@MMPi5:~ $
          S374n
          My Pi5 has a on chip fan and it was running 75 inside the box attached to the monitor in the back.
          I added external little fab on top of my enclosure to extract the hot air and it dropped the temp to 60.
          Moved it 1 inch away from the monitor back panel and the temp now is 55 all the time with screen on and 44 during the night when the screen off.
          • V Offline
            videogame95
            You shouldn’t run any raspberry pi 5 without cooling fan on top it will break if run it without fan installed
            Buy fan
              mvrlogins
              I have ordered a fan/cooler
              But anyone have any insight into whethere the processes I listed are over running?
                sdetweil @mvrlogins
                @mvrlogins if you stop MagicMirror what is the temp?
                  mvrlogins @sdetweil
                  It drops to 50C in a few min
                    sdetweil @mvrlogins
                    what do you mean by separate page?
                    MagicMirror does not have pages, it has logical groupings of content, some shown together, others hidden (this is MMM-pages, MMM-Carousel, MMM-ModulesGroupsRotation, MMM-ProfileSwitcher, etc)
                    so even if not shown, some content could still be generated (Embed/iFrame) , they don’t know they are hidden
                    if you run ps -ef you can see the commandline used to launch each process.
                    you say you have a 1 gig pi5, but mem reports as 2gig.
                    but you are over physical, and swapping. which takes cycles.
                    I would suggest, disabling module at a time
                    add
                    disabled:true,
                    after the module:name… line
                    and rerun to see what the effect is. what are the embed modules showing? active content, graphs, images??
                      mvrlogins @sdetweil
                      add
                      disabled:true,
                      The EmbedURL module shows a WebRTC video. The page is hiddent and called on demand (not regular rotation).
                      I thought that the module would not continue to stream the video when hidden. I guess this is the problem, since it does continue
                        mvrlogins
                        Instead of using pages to hide the module, I guess I could use MMM-Remote-Control to enable/disable the EmbedURL module? That would stop the streaming?
                          sdetweil @mvrlogins
                          @mvrlogins i think runtime enable/disable just changes its visibility. there are no apis to add/remove modules from the DOM.
                          the disable at startup skips adding it as a runtime module… which is completely different
                            mvrlogins @sdetweil
                            I’ll have to find another way to stop the streaming while the page is hidden
