    Black screen with cursor (some days)
    5 Posts 2 Posters 272 Views 2 Watching
    • N Offline
      nowayto
      Re: Performances on Pi 3A+
      Hello, I have this issue from the past.
      In these months I tried a lot of things but I didn’t solve it.
      I know it’s not hardware related, so I don’t know where to “bang my head”.
      Raspberry is set up to start itself at 7:30.
      The issue is: some days, not everydays, when it start raspberry reach the desktop but when MM is loaded the screen remain black with a white cursor in the middle.
      In these months I temporary solved it in two ways:
      1- refresh the page with a simple CTRL+R. It need a keyboard connected but it work flawlessly and istantly.
      2- sending a “pm2 restart mm” through terminal
      3- adding a delaying with export mmFetchTimeout=30000 seems helps a bit but it didn’t solve it totally
      Ok, it’s not a great issue but I like to make my things working without issues :)
      Do you have any advices?
      Honestly, I’m a little bit ignorant but to me it could be related to electron because with a simple CTRL+R it shows everything, so (to me) it seem MM is loaded correctly but electron decide to show a black screen with cursor instead of MM modules.
      Do I need to maybe update electron?
      I prefer not to update raspberry frequently, if it works.
      Is there a way to add a CTRL+R command after a delay of 10 seconds inside the mm.sh?
      I think that could solve it easily.
        sdetweil @nowayto
        @nowayto I don’t know.
        You could try adding a sleep xxx (seconds)
        In front of the npm start in mm.sh to let the system settled down a little.
        The remote control module has a refresh api url you could invoke thru curl
        But, I think this may indicate the beginning of the sd card death, they are not made to handle a lot of writes. And your system is doing the worst kind, restarting every day.
        Make sure you have a good backup
        • N Offline
          nowayto @sdetweil
          I tried with another sd (brand new) and keep happen so I don’t think it is hardware related.
          Yes it turn off during night and it restart in the morning, this could affect the sd but I tried with a brand new one.
          Yes, back it up often, thanks to your script :)
          I use the mmFetchTimeout=40000 before npm start but it happen.
          I think the solution could be to insert after the npm start a:
          sleep 30
          (a command that CTRL+R the page)
          If a command like this exist
            sdetweil @nowayto
            @nowayto all mmFetchTimeout does is allow waiting longer in the modules mode-helpers
            The black screen means the app crashed, lucky that ctrl-r works
            There are Linux tools that can send keystrokes
            • N Offline
              nowayto @sdetweil
              Today I notice something.
              I had to turning off my router for a while, so no internet connection were available for nearly 10 minutes.
              In that time MM goes black with cursor…
              so the issue could be internet connection related
