    Calendar CustomEvents
    19 Posts 3 Posters 2.6k Views 3 Watching
      daportelli
      Thanks for explaining this in a language I can understand. I got that to work.
      In my calendar I have “amex” typed in lower case and I want the transform it to upper “AMEX” to show this works.
      However when I use the below code on a calendar event that only has an event titled ‘amex’ in lower case does not work.
      {keyword: 'amex', transform: { search: 'amex', replace: 'AMEX'}},
      This simple thing is confusing me. I have removed all variables, and it still does not work.
      Thanks again for everyone help.
      S evroomE 2 Replies Last reply Reply Quote 0
        sdetweil @daportelli
        @daportelli I’m not sure of the effect, but the keyword is treated as a regular expression. I don’t know if single quotes make a difference
        Also don’t know if js regex works the same, from the code
        • evroomE
          evroom @daportelli
          @daportelli
          The comments in the code are very confusing, but I think I get it now, more or less.
          Try this:
          {keyword: '.*', transform: { search: 'Spotify', replace: 'Music'}},
          {keyword: '.*', transform: { search: 'Canterbury-Bankstown Bulldogs', replace: 'Bulldogs'},
          The keyword is the event title string you want to change, in format regex.
          The search is the substring that you want to replace, in format regex
          The replace is what will be replaced based on your search
          So in this case, let’s say the event title string is:
          ‘Spotify play list’
          Then you search the complete string (.*) for the substring from search and you replace it by the string from replace.
          Hence, the event title now becomes:
          ‘Music play list’
          I hope it is a little bit more clear.
          Should it not work, then please supply a event title and in short what you want to be replaced.
          MagicMirror version: 2.37.0
            sdetweil @evroom
            @evroom keyword means find this(via regex) in the title, then work rest of customization . ONLY For events that find keyword string
            .* Means all events
            • evroomE
              evroom @sdetweil
              .* Means all events
              Yes, it is a double regex, right?
              First look if this an event title that you would like to change, then search for the string you want to replace.
              Still do not understand why the examples from the first post do not work, but for that we would need the exact event titles.
              {keyword: ‘this event’, transform: { search: ‘changed’, replace: ‘modified’}
              Event title: ‘we want this event to be changed’.
              New title: ‘we want this event to be modified’.
              Do you happen to know how to make the keyword case insensitive?
              string/i or m/string/i do not work.
              Neither does (?i)
              which means ‘match the reminder of the pattern with the i modifier.
                sdetweil @evroom
                @evroom keyword is not insensitive and cannot be set that way.
                the search can be
                  daportelli @sdetweil
                  @sdetweil to remove as many variables as I can, I have created a reoccuring event called “Spotify” and I want to change it to “Music”
                  And I have tried the code below with single and double quotes with no success
                  For something so simple this is driving me crazy.
                    @daportelli ok, I just setup an event, happening every day
                    ‘Spotify Event’
                    added the custom event def you showed
                                            header: "US Holidays",
                                                    customEvents: [
                                                            { keyword:'.*', transform :{ search:'Spotify', replace:'Music'} }
        symbol: "calendar-check",
        url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
                    and got this result
                    MM 2.34
                    I changed the customEvent definition to
                    { keyword:'event', transform :{ search:'Spotify', replace:'Music'} }
                    and it produced the same resutlts
                      @daportelli Ah, you are using MMM-GoogleCalendar
                      which doesn’t support the text replacement
                      I am talking about the default module:‘calendar’
                        @sdetweil well that explains it. I thought the default calendar configs were available to the MMM-GoogleCalendar.
                        Sorry, i did not make it clearer. Everyone thanks for the assist in getting to the bottom of it.
                          @daportelli looks like cloned config, but not implemetation
                            @daportelli if you change the module name for a test, does it work?
                            What do you get from MMM-GoogleCalendar that the default does not provide?
                            never mind, it won’t work with the google side config…
                            as for the purpose of this configuration.
                            the content is protected by https encryption and no user will see it, its only exposed ON the system where MagicMirror runs, same for both modules.
                            you can get the secret URL from the calendar.google.com settings,
