    MMM-RainRadarDWD
    6 Posts 3 Posters 2.6k Views 3 Watching
    • O Offline
      OliWer
      Hey all,
      after MMM-RAIN-MAP literaly stopped working because of the API changes of Rainviewer.com I was looking for something that works.
      Unfortunatelly I’m not a developer, so I got a lot of help from an AI (vibe coding). So if there is a real developer want to check it, make it better, take ownership of the project: Let me know, I just want something that works for me ;)
      Also, this is only working for Germany as I use the data from the German Weather Service (Deutscher Wetterdienst - DWD).
      The module works for me, but I consider it beta as I did not see it long enough. I took some of the feature ideas from MMM-RAIN-MAP, so thanks guys for developing this first!
      -> Rain/snow Radar that is either always visible or only when it will start rain in X minutes
      -> works 2 hours into the past to 2 hours into the future
      -> not much more =)
      It uses data from DWD, Bright Sky API, CARTO map tiles (by Open Street Map) and the OpenLayers map engine.
      you can find the module here:
      https://github.com/realoliwer/MMM-RainRadarDWD
      Any feedback is valued, especially if you find something stupid due to the AI usage.
      For now I’m happy as it is currently working as intended for me and maybe it also works for the one or other here in the forum as well.
      Cheers!
      KristjanESPERANTOK R 2 Replies Last reply Reply Quote 2
      • KristjanESPERANTOK Online
        KristjanESPERANTO Module Developer @OliWer
        @OliWer Nice. Don’t forget to add it to the module list: https://github.com/MagicMirrorOrg/MagicMirror/wiki/3rd-party-modules
        • O Offline
          OliWer @KristjanESPERANTO
          @KristjanESPERANTO Done, thanks =)
            rkorell Module Developer @OliWer
            @OliWer cool idea, thanks!
            You could save a lot of your parameters (all of the “// — Language & Text —” section) if you use the translate - capability…
            But with your approach it’s straight forward and really “all languages” - intersting idea!
            Warm regrds,
            Ralf
            • O Offline
              OliWer @rkorell
              @rkorell Thanks Ralf!
              was not aware of the translate capability, but as I was not sure which text I wanted to have there (in which scenario), hence I thought it would be great if it is configurable in general. I for my self try to get rid of the one or other text if it does not provide information useful for me so I thought it would help others as well, even if it makes the configuration in general a bit larger/complex. Sometimes hard to find the right balance ^^
                @OliWer
                Absolutely fine for me. Just a hint - as improvement path for further upcoming modules from your side :-)
                Warm regards,
                Ralf
