    Install scripts won't install?
    12 Posts 2 Posters 3.9k Views 2 Watching
    • H Offline
      heath1066
      Every attempt shows the below. I am stumped any help is appreciated.
      ys@raspberry:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
      $$$\ $$$ | _| $$$\ $$$ |_| $$ $$
      $$$$\ $$$$ | $$$$$$\ $$$$$$\ $$\ $$$$$$$\ $$$$\ $$$$ |$$\ $$$$$$\ $$$$$$\ $$$$$$\ $$$$$$\ _/ $$ |
      $$$$$$ $$ | _
      $$ $$$ $$ | $$$$$$$ |$$ / $$ |$$ |$$ / $$ $$$ $$ |$$ |$$ | _|$$ | _|$$ / $$ |$$ | _|$$ /
      $$ |$ /$$ |$$ __$$ |$$ | $$ |$$ |$$ | $$ |$ /$$ |$$ |$$ | $$ | $$ | $$ |$$ | $$ |
      $$ | _/ $$ |$$$$$$$ |$$$$$$$ |$$ |$$$$$$$\ $$ | _/ $$ |$$ |$$ | $$ | $$$$$$ |$$ | $$$$$$$$
      _
      | _
      | _
      | _
      $$ |_| _
      |_| _|_|_| __| _
      / _| _______|
      _
      ____/
      install log being saved to /home/hhays/install.log
      Updating packages …
      Installing helper tools …
      nvm_command is export NVM_DIR=/home/hhays/.config/nvm; . “/home/hhays/.config/nvm/nvm.sh” [ -s “/home/hhays/.config/nvm/nvm.sh” ] && . “/home/hhays/.config/nvm/nvm.sh”; nvm install v22.21.1 nvm uninstall
      node failed to execute, please check the error message and resolve before trying again
      • H Offline
        heath1066 @sdetweil
        @sdetweil Sorry for the late reply, family happens… I Gave up on Pi and just wiped the machine and installed ubuntu. Scripts worked flawlessly then Thanks…
          sdetweil @heath1066
          @heath1066 interesting
          Open a terminal window, then do
          If successful,
          do
          hash -r
          node -v
          Should report v22.21.1
          If correct, then rerun the install script
          Please advise. I’ll fix my script
          • H Offline
            heath1066 @sdetweil
            @sdetweil install v22.21.1 failed.
              sdetweil @heath1066
              @heath1066 ok, try the command n
              If it is not found do
              sudo npm install -g n
              Then
              n —version
              Should work
              If so then do
              sudo n 22.21.1
              hash -r
              node -version
              Should say 22.21.1
              If so, then rerun install script
              • H Offline
                heath1066
                errors in shared libraries now
                hhays@raspberry:~ $ n --version
                10.2.0
                hhays@raspberry:~ $ sudo n 22.21.1
                installing : node-v22.21.1
                mkdir : /usr/local/n/versions/node/22.21.1
                fetch : https://nodejs.org/dist/v22.21.1/node-v22.21.1-linux-x64.tar.xz
                copying : node/22.21.1
                node: error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory
                /usr/local/bin/node: error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory
                installed : (with npm )
                  sdetweil @heath1066
                  @heath1066 oh, are you on buster? Or 32 bit system?
                  Do
                  lsb_release -a
                  Can you send me the ~/install.log?
                  Same userid as here on Gmail. Thx
                  • H Offline
                    heath1066 @sdetweil
                    spberry:~ $ lsb_release -a
                    No LSB modules are available.
                    Distributor ID: Debian
                    Description: Debian GNU/Linux 11 (bullseye)
                    Release: 11
                    Codename: bullseye
                      sdetweil @heath1066
                      @heath1066 well then.
                      uname -a
                      • H Offline
                        heath1066 @sdetweil
                        @sdetweil I will have to send later this eve, but here:
                        @raspberry:~ $ uname -a
                        Linux raspberry 5.10.0-39-amd64 #1 SMP Debian 5.10.251-1 (2026-03-09) x86_64 GNU/Linux
                          sdetweil @heath1066
                          @heath1066 weird
                          try this
                          sudo apt update
                          sudo apt install libstdc++6
                          then if successful
                          sudo n 22.21.1
                          • H Offline
                            heath1066 @sdetweil
                              sdetweil @heath1066
                              @heath1066 awesome.
