    Install scripts won't install?
    12 Posts 2 Posters 4.3k Views 2 Watching
    • H
      heath1066 @sdetweil
      @sdetweil install v22.21.1 failed.
        sdetweil @heath1066
        @heath1066 ok, try the command n
        If it is not found do
        sudo npm install -g n
        Then
        n —version
        Should work
        If so then do
        sudo n 22.21.1
        hash -r
        node -version
        Should say 22.21.1
        If so, then rerun install script
        • H
          heath1066
          errors in shared libraries now
          hhays@raspberry:~ $ n --version
          10.2.0
          hhays@raspberry:~ $ sudo n 22.21.1
          installing : node-v22.21.1
          mkdir : /usr/local/n/versions/node/22.21.1
          fetch : https://nodejs.org/dist/v22.21.1/node-v22.21.1-linux-x64.tar.xz
          copying : node/22.21.1
          node: error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory
          /usr/local/bin/node: error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory
          installed : (with npm )
            sdetweil @heath1066
            @heath1066 oh, are you on buster? Or 32 bit system?
            Do
            lsb_release -a
            Can you send me the ~/install.log?
            Same userid as here on Gmail. Thx
            H 1 Reply Last reply
            • H
              heath1066 @sdetweil
              spberry:~ $ lsb_release -a
              No LSB modules are available.
              Distributor ID: Debian
              Description: Debian GNU/Linux 11 (bullseye)
              Release: 11
              Codename: bullseye
                sdetweil @heath1066
                @heath1066 well then.
                uname -a
                • H
                  heath1066 @sdetweil
                  @sdetweil I will have to send later this eve, but here:
                  @raspberry:~ $ uname -a
                  Linux raspberry 5.10.0-39-amd64 #1 SMP Debian 5.10.251-1 (2026-03-09) x86_64 GNU/Linux
                    sdetweil @heath1066
                    @heath1066 weird
                    try this
                    sudo apt update
                    sudo apt install libstdc++6
                    then if successful
                    sudo n 22.21.1
                    • H
                      heath1066 @sdetweil
                      @sdetweil Sorry for the late reply, family happens… I Gave up on Pi and just wiped the machine and installed ubuntu. Scripts worked flawlessly then Thanks…
                        sdetweil @heath1066
                        @heath1066 awesome.
