    Install scripts won't install?
    10 Posts 2 Posters 299 Views 2 Watching
    • H Offline
      heath1066
      Every attempt shows the below. I am stumped any help is appreciated.
      ys@raspberry:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
      $$$\ $$$ | _| $$$\ $$$ |_| $$ $$
      $$$$\ $$$$ | $$$$$$\ $$$$$$\ $$\ $$$$$$$\ $$$$\ $$$$ |$$\ $$$$$$\ $$$$$$\ $$$$$$\ $$$$$$\ _/ $$ |
      $$$$$$ $$ | _
      $$ $$$ $$ | $$$$$$$ |$$ / $$ |$$ |$$ / $$ $$$ $$ |$$ |$$ | _|$$ | _|$$ / $$ |$$ | _|$$ /
      $$ |$ /$$ |$$ __$$ |$$ | $$ |$$ |$$ | $$ |$ /$$ |$$ |$$ | $$ | $$ | $$ |$$ | $$ |
      $$ | _/ $$ |$$$$$$$ |$$$$$$$ |$$ |$$$$$$$\ $$ | _/ $$ |$$ |$$ | $$ | $$$$$$ |$$ | $$$$$$$$
      _
      | _
      | _
      | _
      $$ |_| _
      |_| _|_|_| __| _
      / _| _______|
      _
      ____/
      install log being saved to /home/hhays/install.log
      Updating packages …
      Installing helper tools …
      nvm_command is export NVM_DIR=/home/hhays/.config/nvm; . “/home/hhays/.config/nvm/nvm.sh” [ -s “/home/hhays/.config/nvm/nvm.sh” ] && . “/home/hhays/.config/nvm/nvm.sh”; nvm install v22.21.1 nvm uninstall
      node failed to execute, please check the error message and resolve before trying again
        sdetweil @heath1066
        @heath1066 interesting
        Open a terminal window, then do
        If successful,
        do
        hash -r
        node -v
        Should report v22.21.1
        If correct, then rerun the install script
        Please advise. I’ll fix my script
        • H Offline
          heath1066 @sdetweil
          @sdetweil install v22.21.1 failed.
            sdetweil @heath1066
            @heath1066 ok, try the command n
            If it is not found do
            sudo npm install -g n
            Then
            n —version
            Should work
            If so then do
            sudo n 22.21.1
            hash -r
            node -version
            Should say 22.21.1
            If so, then rerun install script
            • H Offline
              heath1066
              errors in shared libraries now
              hhays@raspberry:~ $ n --version
              10.2.0
              hhays@raspberry:~ $ sudo n 22.21.1
              installing : node-v22.21.1
              mkdir : /usr/local/n/versions/node/22.21.1
              fetch : https://nodejs.org/dist/v22.21.1/node-v22.21.1-linux-x64.tar.xz
              copying : node/22.21.1
              node: error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory
              /usr/local/bin/node: error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory
              installed : (with npm )
                sdetweil @heath1066
                @heath1066 oh, are you on buster? Or 32 bit system?
                Do
                lsb_release -a
                Can you send me the ~/install.log?
                Same userid as here on Gmail. Thx
                • H Offline
                  heath1066 @sdetweil
                  spberry:~ $ lsb_release -a
                  No LSB modules are available.
                  Distributor ID: Debian
                  Description: Debian GNU/Linux 11 (bullseye)
                  Release: 11
                  Codename: bullseye
                    sdetweil @heath1066
                    @heath1066 well then.
                    uname -a
                    • H Offline
                      heath1066 @sdetweil
                      @sdetweil I will have to send later this eve, but here:
                      @raspberry:~ $ uname -a
                      Linux raspberry 5.10.0-39-amd64 #1 SMP Debian 5.10.251-1 (2026-03-09) x86_64 GNU/Linux
                        sdetweil @heath1066
                        @heath1066 weird
                        try this
                        sudo apt update
                        sudo apt install libstdc++6
                        then if successful
                        sudo n 22.21.1
