    Apply color to future events in CalendarExt3
    38 Posts 3 Posters 9.3k Views 3 Watching
    • K Offline
      kkmirr04
      Currently, my CalendarExt3 module is only applying color to events that are within 48 hours. None of the events on the calendar past 48 hours have any coloring applied to them. I took a read through the pinned CSS guide but I’m not sure how to hunt down the sheet / items I need to change to implement this. I didn’t see anything obvious in the readme to edit this either.
      Here is what my calendar looks like right now - only Sams Birthday which is today has color applied
      And here is an example from Google where all of the events for the month have color applied to them:
        sdetweil @kkmirr04
        @kkmirr04 ext3 gets its events from the default c as lender module and can use the color definition there
        Different for each url used/defined
        Can you show your default cal Module config
        Xxx out the urls
        • K Offline
          kkmirr04 @sdetweil
          @sdetweil Yup here it is, pretty basic. I’ve tried running the default calendar module twice with one calendar in each config, but then the second calendar fails to load once I also add in the pages module. Goal is to show a list of the events on the first page, and then the second page is just the monthly calendar
          			classes: "page0",
          			header: "What's Happening'",
          			   colored: true,
          						color: 'yellow',
          						symbol: "calendar-check-o",
          						url: "https://calendar/basic.ics"
          						color: 'green',
          						url: "webcal:xx//"
            sdetweil @kkmirr04
            @kkmirr04 ok,
            1st does the default cal show color on the events in the list per the URL configs?
            the config you presented will show ALL the events together, intertwined. in a single list
            EXT3 could see them differently by name
            can you show the ext3 configs
            please, always use the code block wrapper around config or logs)
            to do in this message editor
            paste the text you want to present
            blank line above and below
            select the text you just pasted
            hit the code block button </> in the menu above the editor
            • K Offline
              kkmirr04 @sdetweil
              I do have color on the events list - hopefully this is what you were asking for
              I would love to have it broken back out into two separate lists, but when I do that and integrate MMM-Pages, it refuses to load the second calendar stream on the events list and also into the calendar. Its like it just refuses to go out and check.
              I think its a limitation of the Pages module, I’ve got it setup for the classes configuration. You can call the same module on different pages, but it doesn’t seem like I can call the default calendar module twice on the same page. I haven’t done much research on the Pages issue, thats my next one to tackle.
              Interestingly, looking at the CalendarExt3 view today - none of the future events have color applied to them:
              Think I got the code block correct this time - thanks for pointing that out to me.
                    module: "MMM-CalendarExt3",
                    classes: "page1",
                    position: "bottom_bar",
                    title: "",
                      mode: "week",
                      instanceId: "main",
              	showWeekNumber: false,
              	//useSymbol: true,
              	//displayLegend: true,
                      maxEventLines: 10,
              	//useWeather: true,
                      firstDayOfWeek: 0,
                      calendarSet: ['xx_cal', 'yy_cal'],
                sdetweil @kkmirr04
                @kkmirr04 ok, there is a quirk in the EXT3 family of modules .
                They don’t know when the messages are coming. And don’t want to flash the screen with changes each time they arrive.
                Some events of today from cal 1 and more from cal 2 at a different time
                So they use a refreshInterval default 15 minutes
                But you don’t want to wait 15 mins for the first draw.
                So they have another setting waitFetch:5 seconds
                After startup wait waitFetch time and draw whatever events have arrived. Even if none
                THEN you have to wait refreshInterval time
                You have both at default
                A little downside on the waitFetch is you get NOTHING til it expires
                  Another question. When did you install ext3
                  You DID run npm install the that module folder right?
                  • K Offline
                    kkmirr04 @sdetweil
                    I believe ext3 was one of the first modules I installed when I started everything this weekend. I do remember having some errors so theres a good chance I messed something up. I just ran npm install again and it processed fine, but no changes on the functionality.
                    Would it make sense to delete out the folder and try downloading / configuring the module again?
                      sdetweil @kkmirr04
                      @kkmirr04 no, there was a fix a couple weeks ago, but if you just loaded it, should be fine
                      Can you add waitFetch:20000,
                      To the EXT3 module config
                        sdetweil @kkmirr04
                        @kkmirr04 can you try release 2.36 just released.
                        • K Offline
                          kkmirr04
                          I tried adding the waitFetch and updating and no changes on my end. Do you think doing a clean install might be the next best step?cal1.jpg
                            sdetweil @kkmirr04
                            @kkmirr04 can you show the default cal and ext3 on the same page. With the same events.
                            Can you remove the calendarSets from the ext3 config
                            npm install in the ext3 module folder is enough
                            • K Offline
                              kkmirr04 @sdetweil
                              @sdetweil Here is the events with the calendar
                              Remove the calendar sets and then run npm install again? I did see there is an update for my NPM - should i do that update too?
                              I also just noticed theres an error with CalExt3 when I close MM
                              S 3 Replies Last reply Reply Quote 0
                                sdetweil @kkmirr04
                                @kkmirr04 thanks. I will try to test this out in a little bit
                                No, ignore the npm message
                                Yes, we found a bug in MagicMirror when looking for module updates. No harm done
                                  sdetweil @kkmirr04
                                  @kristjanesperanto
                                  can you explain this? the default cal shows colored, but Ext3 does not
                                  I can duplicate, text not colored in Ext3
                                  but pop is all colored.
                                    sdetweil @kkmirr04
                                    @kkmirr04 on your second cal instance not showing
                                    can you show the config, xxx out the cal url…
                                    I am using pages, with ext3 on diff and cal on diff without problem… (except for ext3 color)
                                    • K Offline
                                      kkmirr04 @sdetweil
                                      @sdetweil I think I might’ve just found its related to the month / week views of Ext3…
                                      This is how I have it now:
                                      			classes: "page0",
                                      			header: "What's Poppin'",
                                      			   colored: true,
                                      						color: 'yellow',
                                      						url: "basic.ics"
                                      						color: 'green',
                                      						url: "webcal"
                                      When I separate them to two instances, this is the code I have:
                                      			classes: "page0",
                                      			header: "XX Calendar'",
                                      			   colored: true,
                                      						color: 'yellow',
                                      						url: "basic.ics"
                                      			classes: "page0",
                                      			header: "YY Calendar'",
                                      			   colored: true,
                                      						color: 'green',
                                      						url: "webcal"
                                      And without the Pages module, I do get both to load
                                      I went to add Pages back in with the two calendar instance configuration and have EXT3 on week mode, the second calendar stream does not load
                                      And still no color on calendar view on the second page
                                      But then if I switch to month mode in EXT3 streams are loading in and some colors work - but there’s still two events (from the XX calendar) that loaded but did not get color applied.
                                      As I’ve been messing with it, sometimes on the first run it will load both calendar streams when its in week mode, but it usually doesn’t load it after it runs once. Sometimes in month mode, it still doesn’t load the second calendar, so its not 100% accurate
                                        sdetweil @kkmirr04
                                        @kkmirr04 interesting.
                                        Also, you are using an old term , colored
                                        We’ve update to coloredText, symbol,
                                        There should have been a message in the console output at MagicMirror startup
                                        pm2 logs —lines=xxx
                                        xxx is the number of most recent lines in the output, default 15
                                        I saw that when I was testing yesterday
                                        When you get the not displayed, can you
                                        Open the developers console
                                        On the MagicMirror screen, ctrl-shift-I
                                        Select the console tab and scroll around for errors(red text usually)
                                        When one script has a fault in a browser, others will be impacted
                                        Modules are all script
                                        • K Offline
                                          kkmirr04 @sdetweil
                                          @sdetweil I’ll keep messing with coloredText, so far everything is staying white when I use that. Here is the errors I’m seeing
                                            sdetweil @kkmirr04
                                            @kkmirr04 custom.css not loaded just means there isn’t one. (The default as MagicMirror installed)
                                            If you had used the scripted install it would have created an empty one so this error wouldn’t be there
                                            There is the colored vs coloredText, coloredSymbol warning
                                            No Obvious other errors in that part
                                            Calendar sorting events=0, means there weren’t any?
                                            Just for testing, if you disable pages and ext3
                                            ( add disabled:true, after the module:line)
                                            Do both instances of calendar draw and with color?
                                            If yes, then set disabled false on ext3
