    Apply color to future events in CalendarExt3
    38 Posts 3 Posters 10.4k Views 3 Watching
      Another question. When did you install ext3
      You DID run npm install the that module folder right?
      • K Offline
        kkmirr04 @sdetweil
        I believe ext3 was one of the first modules I installed when I started everything this weekend. I do remember having some errors so theres a good chance I messed something up. I just ran npm install again and it processed fine, but no changes on the functionality.
        Would it make sense to delete out the folder and try downloading / configuring the module again?
          sdetweil @kkmirr04
          @kkmirr04 no, there was a fix a couple weeks ago, but if you just loaded it, should be fine
          Can you add waitFetch:20000,
          To the EXT3 module config
            sdetweil @kkmirr04
            @kkmirr04 can you try release 2.36 just released.
            • K Offline
              kkmirr04
              I tried adding the waitFetch and updating and no changes on my end. Do you think doing a clean install might be the next best step?cal1.jpg
                sdetweil @kkmirr04
                @kkmirr04 can you show the default cal and ext3 on the same page. With the same events.
                Can you remove the calendarSets from the ext3 config
                npm install in the ext3 module folder is enough
                • K Offline
                  kkmirr04 @sdetweil
                  @sdetweil Here is the events with the calendar
                  Remove the calendar sets and then run npm install again? I did see there is an update for my NPM - should i do that update too?
                  I also just noticed theres an error with CalExt3 when I close MM
                  S 3 Replies Last reply Reply Quote 0
                    sdetweil @kkmirr04
                    @kkmirr04 thanks. I will try to test this out in a little bit
                    No, ignore the npm message
                    Yes, we found a bug in MagicMirror when looking for module updates. No harm done
                      sdetweil @kkmirr04
                      @kristjanesperanto
                      can you explain this? the default cal shows colored, but Ext3 does not
                      I can duplicate, text not colored in Ext3
                      but pop is all colored.
                        sdetweil @kkmirr04
                        @kkmirr04 on your second cal instance not showing
                        can you show the config, xxx out the cal url…
                        I am using pages, with ext3 on diff and cal on diff without problem… (except for ext3 color)
                        • K Offline
                          kkmirr04 @sdetweil
                          @sdetweil I think I might’ve just found its related to the month / week views of Ext3…
                          This is how I have it now:
                          			classes: "page0",
                          			header: "What's Poppin'",
                          			   colored: true,
                          						color: 'yellow',
                          						symbol: "calendar-check-o",
                          						url: "basic.ics"
                          						color: 'green',
                          						url: "webcal"
                          When I separate them to two instances, this is the code I have:
                          			classes: "page0",
                          			header: "XX Calendar'",
                          			   colored: true,
                          						color: 'yellow',
                          						url: "basic.ics"
                          			classes: "page0",
                          			header: "YY Calendar'",
                          			   colored: true,
                          						color: 'green',
                          						url: "webcal"
                          And without the Pages module, I do get both to load
                          I went to add Pages back in with the two calendar instance configuration and have EXT3 on week mode, the second calendar stream does not load
                          And still no color on calendar view on the second page
                          But then if I switch to month mode in EXT3 streams are loading in and some colors work - but there’s still two events (from the XX calendar) that loaded but did not get color applied.
                          As I’ve been messing with it, sometimes on the first run it will load both calendar streams when its in week mode, but it usually doesn’t load it after it runs once. Sometimes in month mode, it still doesn’t load the second calendar, so its not 100% accurate
                            sdetweil @kkmirr04
                            @kkmirr04 interesting.
                            Also, you are using an old term , colored
                            We’ve update to coloredText, symbol,
                            There should have been a message in the console output at MagicMirror startup
                            pm2 logs —lines=xxx
                            xxx is the number of most recent lines in the output, default 15
                            I saw that when I was testing yesterday
                            When you get the not displayed, can you
                            Open the developers console
                            On the MagicMirror screen, ctrl-shift-I
                            Select the console tab and scroll around for errors(red text usually)
                            When one script has a fault in a browser, others will be impacted
                            Modules are all script
                            • K Offline
                              kkmirr04 @sdetweil
                              @sdetweil I’ll keep messing with coloredText, so far everything is staying white when I use that. Here is the errors I’m seeing
                                sdetweil @kkmirr04
                                @kkmirr04 custom.css not loaded just means there isn’t one. (The default as MagicMirror installed)
                                If you had used the scripted install it would have created an empty one so this error wouldn’t be there
                                There is the colored vs coloredText, coloredSymbol warning
                                No Obvious other errors in that part
                                Calendar sorting events=0, means there weren’t any?
                                Just for testing, if you disable pages and ext3
                                ( add disabled:true, after the module:line)
                                Do both instances of calendar draw and with color?
                                If yes, then set disabled false on ext3
                                • K Offline
                                  kkmirr04 @sdetweil
                                  @sdetweil with both disabled it did draw both instances with color
                                  Then turning EXT3 back on I’ve got no color on any events again
                                    sdetweil @kkmirr04
                                    @kkmirr04 that’s ext3 not showing color
                                    In the off chance of some module install fluke
                                    Delete the Mmm-CalendarExt3 folder
                                    Then git clone
                                    And npm install in the folder created by clone
                                    Then restart MagicMirror
                                    • K Offline
                                      kkmirr04 @sdetweil
                                      @sdetweil No change unfortunately. Both event streams load fine and with color, but the calendar still is displaying everything just white, except for one event that did come with color 10.png
                                        sdetweil @kkmirr04
                                        @kkmirr04 just for testing, if you have a mouse on that system
                                        Mouse over the event without color and click. This will show a new view of that event with the rest in blur behind,
                                        Does the text appear in the proper color?
                                        Escape key to exit that view
                                        Could you also add
                                        coloredSymbol:true,
                                        To the base calendar module config.
                                        Next to
                                        coloredText:true
                                        • K Offline
                                          kkmirr04 @sdetweil
                                          @sdetweil clicking on the event did bring the color in on that new view
                                          It didn’t seem like the coloredSymbol and coloredText had an effect, but not sure if I put them in the right spot? Should I remove the old colored:true, value?
                                          			disabled:false,
                                          			coloredSymbol:true,
                                          			coloredText:true,
                                          			classes: "page0",
                                          			   colored: true,
                                          						color: 'yellow',
                                          						url: "https:basic.ics"
                                          			classes: "page0",
                                          			coloredSymbol:true,
                                          			coloredText:true,
                                          			   colored: true,
                                          						color: 'green',
                                          						url: "webcal:
                                            sdetweil @kkmirr04
                                            @kkmirr04 they replace the colored:true which did everything,
                                            Now you can control each separately
                                            Inside the config: { section
                                            Before the calendars: [ list
