    Apply color to future events in CalendarExt3
    38 Posts 3 Posters 11.5k Views 3 Watching
    • K
      kkmirr04 @sdetweil
      @sdetweil Here is the events with the calendar
      Remove the calendar sets and then run npm install again? I did see there is an update for my NPM - should i do that update too?
      I also just noticed theres an error with CalExt3 when I close MM
      S 3 Replies Last reply
        sdetweil @kkmirr04
        @kkmirr04 thanks. I will try to test this out in a little bit
        No, ignore the npm message
        Yes, we found a bug in MagicMirror when looking for module updates. No harm done
          sdetweil @kkmirr04
          @kristjanesperanto
          can you explain this? the default cal shows colored, but Ext3 does not
          I can duplicate, text not colored in Ext3
          but pop is all colored.
            sdetweil @kkmirr04
            @kkmirr04 on your second cal instance not showing
            can you show the config, xxx out the cal url…
            I am using pages, with ext3 on diff and cal on diff without problem… (except for ext3 color)
            K 1 Reply Last reply
            • K
              kkmirr04 @sdetweil
              @sdetweil I think I might’ve just found its related to the month / week views of Ext3…
              This is how I have it now:
              			classes: "page0",
              			header: "What's Poppin'",
              			   colored: true,
              						color: 'yellow',
              						symbol: "calendar-check-o",
              						url: "basic.ics"
              						color: 'green',
              						url: "webcal"
              When I separate them to two instances, this is the code I have:
              			classes: "page0",
              			header: "XX Calendar'",
              			   colored: true,
              						color: 'yellow',
              						url: "basic.ics"
              			classes: "page0",
              			header: "YY Calendar'",
              			   colored: true,
              						color: 'green',
              						url: "webcal"
              And without the Pages module, I do get both to load
              I went to add Pages back in with the two calendar instance configuration and have EXT3 on week mode, the second calendar stream does not load
              And still no color on calendar view on the second page
              But then if I switch to month mode in EXT3 streams are loading in and some colors work - but there’s still two events (from the XX calendar) that loaded but did not get color applied.
              As I’ve been messing with it, sometimes on the first run it will load both calendar streams when its in week mode, but it usually doesn’t load it after it runs once. Sometimes in month mode, it still doesn’t load the second calendar, so its not 100% accurate
                sdetweil @kkmirr04
                @kkmirr04 interesting.
                Also, you are using an old term , colored
                We’ve update to coloredText, symbol,
                There should have been a message in the console output at MagicMirror startup
                pm2 logs —lines=xxx
                xxx is the number of most recent lines in the output, default 15
                I saw that when I was testing yesterday
                When you get the not displayed, can you
                Open the developers console
                On the MagicMirror screen, ctrl-shift-I
                Select the console tab and scroll around for errors(red text usually)
                When one script has a fault in a browser, others will be impacted
                Modules are all script
                • K
                  kkmirr04 @sdetweil
                  @sdetweil I’ll keep messing with coloredText, so far everything is staying white when I use that. Here is the errors I’m seeing
                    sdetweil @kkmirr04
                    @kkmirr04 custom.css not loaded just means there isn’t one. (The default as MagicMirror installed)
                    If you had used the scripted install it would have created an empty one so this error wouldn’t be there
                    There is the colored vs coloredText, coloredSymbol warning
                    No Obvious other errors in that part
                    Calendar sorting events=0, means there weren’t any?
                    Just for testing, if you disable pages and ext3
                    ( add disabled:true, after the module:line)
                    Do both instances of calendar draw and with color?
                    If yes, then set disabled false on ext3
                    • K
                      kkmirr04 @sdetweil
                      @sdetweil with both disabled it did draw both instances with color
                      Then turning EXT3 back on I’ve got no color on any events again
                        sdetweil @kkmirr04
                        @kkmirr04 that’s ext3 not showing color
                        In the off chance of some module install fluke
                        Delete the Mmm-CalendarExt3 folder
                        Then git clone
                        And npm install in the folder created by clone
                        Then restart MagicMirror
                        • K
                          kkmirr04 @sdetweil
                          @sdetweil No change unfortunately. Both event streams load fine and with color, but the calendar still is displaying everything just white, except for one event that did come with color 10.png
                            sdetweil @kkmirr04
                            @kkmirr04 just for testing, if you have a mouse on that system
                            Mouse over the event without color and click. This will show a new view of that event with the rest in blur behind,
                            Does the text appear in the proper color?
                            Escape key to exit that view
                            Could you also add
                            coloredSymbol:true,
                            To the base calendar module config.
                            Next to
                            coloredText:true
                            • K
                              kkmirr04 @sdetweil
                              @sdetweil clicking on the event did bring the color in on that new view
                              It didn’t seem like the coloredSymbol and coloredText had an effect, but not sure if I put them in the right spot? Should I remove the old colored:true, value?
                              			disabled:false,
                              			coloredSymbol:true,
                              			coloredText:true,
                              			classes: "page0",
                              			   colored: true,
                              						color: 'yellow',
                              						url: "https:basic.ics"
                              			classes: "page0",
                              			coloredSymbol:true,
                              			coloredText:true,
                              			   colored: true,
                              						color: 'green',
                              						url: "webcal:
                                sdetweil @kkmirr04
                                @kkmirr04 they replace the colored:true which did everything,
                                Now you can control each separately
                                Inside the config: { section
                                Before the calendars: [ list
                                • K
                                  kkmirr04 @sdetweil
                                  @sdetweil Still the same results with the coloredSymbol and coloredText unfortunately
                                    sdetweil @kkmirr04
                                    @kkmirr04
                                    @kristjanesperanto can you help here? Seems ext3 is having trouble with color….
                                    KristjanESPERANTOK 1 Reply Last reply
                                    • KristjanESPERANTOK
                                      @kkmirr04 Does it work when you add this to your custom.css?
                                      .CX3 .event.singleday .headline .title,
                                      .CX3 .event.singleday .headline .time {
                                        color: var(--calendarColor);
                                      K S 3 Replies Last reply
                                      • K
                                        kkmirr04 @KristjanESPERANTO
                                        @KristjanESPERANTO So I really don’t know anything about modifying CSS , I can’t locate a custom.css file . Would that be in /magicmirror/CSS or MagicMirror/modules/MMM-CalendarExt3 folders? And where in those respective files should it be placed - just at the top or bottom?
                                        Sorry, I’m not a programmer by any stretch, just a hobbyist trying to figure it out
                                          sdetweil @kkmirr04
                                          @kkmirr04 in 2.36 custom.css would be located in the config folder. Before that in the css folder
                                          If you had used my installer script it would have created an empty file for you.
                                          Editing custom.css is just like editing config.js
                                          Just a file of text
                                            sdetweil @KristjanESPERANTO
                                            @KristjanESPERANTO that changed the results for me… now have color
