    Apply color to future events in CalendarExt3
    38 Posts 3 Posters 10.4k Views 3 Watching
      sdetweil @kkmirr04
      @kkmirr04 interesting.
      Also, you are using an old term , colored
      We’ve update to coloredText, symbol,
      There should have been a message in the console output at MagicMirror startup
      pm2 logs —lines=xxx
      xxx is the number of most recent lines in the output, default 15
      I saw that when I was testing yesterday
      When you get the not displayed, can you
      Open the developers console
      On the MagicMirror screen, ctrl-shift-I
      Select the console tab and scroll around for errors(red text usually)
      When one script has a fault in a browser, others will be impacted
      Modules are all script
      • K Offline
        kkmirr04 @sdetweil
        @sdetweil I’ll keep messing with coloredText, so far everything is staying white when I use that. Here is the errors I’m seeing
          sdetweil @kkmirr04
          @kkmirr04 custom.css not loaded just means there isn’t one. (The default as MagicMirror installed)
          If you had used the scripted install it would have created an empty one so this error wouldn’t be there
          There is the colored vs coloredText, coloredSymbol warning
          No Obvious other errors in that part
          Calendar sorting events=0, means there weren’t any?
          Just for testing, if you disable pages and ext3
          ( add disabled:true, after the module:line)
          Do both instances of calendar draw and with color?
          If yes, then set disabled false on ext3
          • K Offline
            kkmirr04 @sdetweil
            @sdetweil with both disabled it did draw both instances with color
            Then turning EXT3 back on I’ve got no color on any events again
              sdetweil @kkmirr04
              @kkmirr04 that’s ext3 not showing color
              In the off chance of some module install fluke
              Delete the Mmm-CalendarExt3 folder
              Then git clone
              And npm install in the folder created by clone
              Then restart MagicMirror
              • K Offline
                kkmirr04 @sdetweil
                @sdetweil No change unfortunately. Both event streams load fine and with color, but the calendar still is displaying everything just white, except for one event that did come with color 10.png
                  sdetweil @kkmirr04
                  @kkmirr04 just for testing, if you have a mouse on that system
                  Mouse over the event without color and click. This will show a new view of that event with the rest in blur behind,
                  Does the text appear in the proper color?
                  Escape key to exit that view
                  Could you also add
                  coloredSymbol:true,
                  To the base calendar module config.
                  Next to
                  coloredText:true
                  • K Offline
                    kkmirr04 @sdetweil
                    @sdetweil clicking on the event did bring the color in on that new view
                    It didn’t seem like the coloredSymbol and coloredText had an effect, but not sure if I put them in the right spot? Should I remove the old colored:true, value?
                    			disabled:false,
                    			coloredSymbol:true,
                    			coloredText:true,
                    			classes: "page0",
                    			header: "XX Calendar'",
                    			   colored: true,
                    						color: 'yellow',
                    						symbol: "calendar-check-o",
                    						url: "https:basic.ics"
                    			classes: "page0",
                    			coloredSymbol:true,
                    			coloredText:true,
                    			header: "YY Calendar'",
                    			   colored: true,
                    						color: 'green',
                    						url: "webcal:
                      sdetweil @kkmirr04
                      @kkmirr04 they replace the colored:true which did everything,
                      Now you can control each separately
                      Inside the config: { section
                      Before the calendars: [ list
                      • K Offline
                        kkmirr04 @sdetweil
                        @sdetweil Still the same results with the coloredSymbol and coloredText unfortunately
                          sdetweil @kkmirr04
                          @kkmirr04
                          @kristjanesperanto can you help here? Seems ext3 is having trouble with color….
                          • KristjanESPERANTOK Online
                            @kkmirr04 Does it work when you add this to your custom.css?
                            .CX3 .event.singleday .headline .title,
                            .CX3 .event.singleday .headline .time {
                              color: var(--calendarColor);
                            K S 3 Replies Last reply Reply Quote 0
                            • K Offline
                              kkmirr04 @KristjanESPERANTO
                              @KristjanESPERANTO So I really don’t know anything about modifying CSS , I can’t locate a custom.css file . Would that be in /magicmirror/CSS or MagicMirror/modules/MMM-CalendarExt3 folders? And where in those respective files should it be placed - just at the top or bottom?
                              Sorry, I’m not a programmer by any stretch, just a hobbyist trying to figure it out
                                sdetweil @kkmirr04
                                @kkmirr04 in 2.36 custom.css would be located in the config folder. Before that in the css folder
                                If you had used my installer script it would have created an empty file for you.
                                Editing custom.css is just like editing config.js
                                Just a file of text
                                  sdetweil @KristjanESPERANTO
                                  @KristjanESPERANTO that changed the results for me… now have color
                                    @KristjanESPERANTO but how does that work for multiple calendars with different colors with events on the same month display
                                      @sdetweil CX3 should use each event’s source-calendar color even when multiple calendars are shown together in the same month view. Does it work with multiple calendars?
                                        @KristjanESPERANTO it does work with multiple cals with different colors…
                                        this used to be default behavior, did the module css get changed?
                                        K KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
                                        • K Offline
                                          kkmirr04 @sdetweil
                                          @sdetweil This fixed it for me, both calendar event streams are pulling in colors and even across all ‘modes’ of EXT3 now. (month, week, day) and its extending out to all events I can see on the calendar.
                                          Thank you both so much for all of the help on this, my two way glass just arrived so timing couldn’t be better!
                                          Thanks!!!
                                            Are you sure? Do you remember in which version it worked that way? I’m not aware of it ever being the default, but I could be wrong :)
