    Apply color to future events in CalendarExt3
    38 Posts 3 Posters 10.8k Views 3 Watching
    • K
      kkmirr04 @sdetweil
      @sdetweil with both disabled it did draw both instances with color
      Then turning EXT3 back on I’ve got no color on any events again
        sdetweil @kkmirr04
        @kkmirr04 that’s ext3 not showing color
        In the off chance of some module install fluke
        Delete the Mmm-CalendarExt3 folder
        Then git clone
        And npm install in the folder created by clone
        Then restart MagicMirror
        • K
          kkmirr04 @sdetweil
          @sdetweil No change unfortunately. Both event streams load fine and with color, but the calendar still is displaying everything just white, except for one event that did come with color 10.png
            sdetweil @kkmirr04
            @kkmirr04 just for testing, if you have a mouse on that system
            Mouse over the event without color and click. This will show a new view of that event with the rest in blur behind,
            Does the text appear in the proper color?
            Escape key to exit that view
            Could you also add
            coloredSymbol:true,
            To the base calendar module config.
            Next to
            coloredText:true
            • K
              kkmirr04 @sdetweil
              @sdetweil clicking on the event did bring the color in on that new view
              It didn’t seem like the coloredSymbol and coloredText had an effect, but not sure if I put them in the right spot? Should I remove the old colored:true, value?
              			disabled:false,
              			coloredSymbol:true,
              			coloredText:true,
              			classes: "page0",
              			header: "XX Calendar'",
              			   colored: true,
              						color: 'yellow',
              						symbol: "calendar-check-o",
              						url: "https:basic.ics"
              			classes: "page0",
              			coloredSymbol:true,
              			coloredText:true,
              			header: "YY Calendar'",
              			   colored: true,
              						color: 'green',
              						url: "webcal:
                sdetweil @kkmirr04
                @kkmirr04 they replace the colored:true which did everything,
                Now you can control each separately
                Inside the config: { section
                Before the calendars: [ list
                • K
                  kkmirr04 @sdetweil
                  @sdetweil Still the same results with the coloredSymbol and coloredText unfortunately
                    sdetweil @kkmirr04
                    @kkmirr04
                    @kristjanesperanto can you help here? Seems ext3 is having trouble with color….
                    • KristjanESPERANTOK
                      @kkmirr04 Does it work when you add this to your custom.css?
                      .CX3 .event.singleday .headline .title,
                      .CX3 .event.singleday .headline .time {
                        color: var(--calendarColor);
                      K S 3 Replies Last reply Reply Quote 0
                      • K
                        kkmirr04 @KristjanESPERANTO
                        @KristjanESPERANTO So I really don’t know anything about modifying CSS , I can’t locate a custom.css file . Would that be in /magicmirror/CSS or MagicMirror/modules/MMM-CalendarExt3 folders? And where in those respective files should it be placed - just at the top or bottom?
                        Sorry, I’m not a programmer by any stretch, just a hobbyist trying to figure it out
                          sdetweil @kkmirr04
                          @kkmirr04 in 2.36 custom.css would be located in the config folder. Before that in the css folder
                          If you had used my installer script it would have created an empty file for you.
                          Editing custom.css is just like editing config.js
                          Just a file of text
                            sdetweil @KristjanESPERANTO
                            @KristjanESPERANTO that changed the results for me… now have color
                              @KristjanESPERANTO but how does that work for multiple calendars with different colors with events on the same month display
                                @sdetweil CX3 should use each event’s source-calendar color even when multiple calendars are shown together in the same month view. Does it work with multiple calendars?
                                  @KristjanESPERANTO it does work with multiple cals with different colors…
                                  this used to be default behavior, did the module css get changed?
                                  K KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
                                  • K
                                    kkmirr04 @sdetweil
                                    @sdetweil This fixed it for me, both calendar event streams are pulling in colors and even across all ‘modes’ of EXT3 now. (month, week, day) and its extending out to all events I can see on the calendar.
                                    Thank you both so much for all of the help on this, my two way glass just arrived so timing couldn’t be better!
                                    Thanks!!!
                                      Are you sure? Do you remember in which version it worked that way? I’m not aware of it ever being the default, but I could be wrong :)
                                        @KristjanESPERANTO I don’t run ext3 all the time, just to test. But this is such a core value. I think because of the ext modules color and symbol were added to the broadcast data
                                        Lots of features are turned on by default, week number, blah blah, and use css to turn them off.
                                        This seems simple to be default and hard for others to do ( witness wasted time here and another
