    MMM- Carousel
    7 Posts 3 Posters 1.5k Views 3 Watching
      Mati_93
      Hi friends, liebe Grüße Freunde!
      The concept of Carousel is more complicated than MMM-pages where I succeeded. This unfortunately not working, ignoring my usb keyboard and I still see on the middle of screen " module M_Carousel …etc" ps I’m a Newbie
      let config = {
          address: "0.0.0.0",
          port: 8080,
          basePath: "/",
          ipWhitelist: [],
          useHttps: false,
          httpsPrivateKey: "",
          httpsCertificate: "",
          language: "en",
          locale: "en-US",
          logLevel: ["INFO", "LOG", "WARN", "ERROR"],
          timeFormat: 24,
          units: "metric",
       		module: "MMM-KeyBindings",
         			evdev: { enabled: false },
      			enableKeyboard: true,
        			keyBindings: [
              				key: "ArrowRight",
              				notification: "PAGE_INCREMENT"
              				key: "ArrowLeft",
              				notification: "PAGE_DECREMENT"
            		module: "MMM-Carousel",
            		position: "bottom_bar",
              		transitionInterval: 10000,
              		ignoreModules: ["clock", "alert"],
              		mode: "slides",
              		showPageIndicators: true,
              		showPageControls: true,
              		slides: {
                			main: ["calendar", "compliments", "weather"],
                			"Slide 2": ["weather", "newsfeed"],
                			"Slide 3": ["MMM-PublicTransportHafas"]
              		keyBindings: {
                			enabled: true,
                				map: {
                  					NextSlide: "ArrowRight",
                 		 			PrevSlide: "ArrowLeft",
                  					Pause: "ArrowDown",
                  					Slide0: "Home"
               		 mode: "DEFAULT"
                  module: "alert"
                  module: "updatenotification",
                  position: "top_bar",
                  header: "US Holidays",
                              symbol: "calendar-check",
                              url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
      		module: "MMM-Touch",
      		module: 'MMM-ViewNotifications',
      		position: "bottom_right",
      		header: "Notifications",
                      // See below for Configuration Options
      		module: "compliments",
      		position: "lower_third",
                  module: "weather",
                  header: "Weather Forecast",
                      weatherProvider: "openmeteo",
                      type: "forecast",
                      lat: 40.776676,
                      lon: -73.971321
                  module: "weather",
                  header: "Weather Current",
                      type: "current",
                      lat: 40.776676,
                      lon: -73.971321
                  module: "newsfeed",
                      feeds: [
                              title: "New York Times",
                              url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                      showSourceTitle: true,
                      showPublishDate: true,
                      broadcastNewsFeeds: true,
                      broadcastNewsUpdates: true
      		module: 'clock',
            		position: 'bottom_bar'
      		module: "MMM-PublicTransportHafas",
                  	position: "bottom_left",
                      	stationID: "645239",
                      	stationName: "18.-März-Straße",
                      	direction: "",
                      	excludedTransportationTypes: [],
                      	ignoredLines: [],
                      	timeToStation: 10,
                      	displayLastUpdate: true,
                      	maxUnreachableDepartures: 0,
                      	maxReachableDepartures: 7,
                      	showColoredLineSymbols: true,
                      	customLineStyles: "",
                      	showOnlyLineNumbers: false,
                      	showTableHeadersAsSymbols: true,
                      	useColorForRealtimeInfo: true
                  module: "MMM-Remote-Control",
                  //position: "bottom_right",
                      customCommand: {},
                      showModuleApiMenu: true,
                      secureEndpoints: false,
                      showQRCode: true,
                      qrCodeSize: 150,
                      qrCodePosition: "below"
      /***** DO NOT EDIT THE LINE BELOW *****/
      Thanks in advance,/Vielen Dank im voraus
        sdetweil @Mati_93
        @Mati_93 why did you change from pages?
        also, future posts
        if config, or code or log files, use the code block around them
        paste text to message editor, blank line above and below
        select the text just pasted
        hit the </> button on the message editor tool bar
        I have fixed first post
          Mati_93 @sdetweil
          Ok sorry , in hurry.
          Why? Because mnm-pages does not support keyBinding module. I want to move pages manually before I order IR touch frame.
            Mati_93 @sdetweil
            @sdetweil topic solved. I’ve downloaded older version from the first guy, not the forked one. Now everythings works perfect from shbatm.
            KristjanESPERANTOK 1 Reply Last reply Reply Quote 2
            • M Mati_93 has marked this topic as solved on
            • KristjanESPERANTOK Offline
              KristjanESPERANTO Module Developer @Mati_93
              @Mati_93 This sort of thing happens to others from time to time as well. It would be really interesting to know how you came across the old version 🕵️. We have the module list, which refers to the fork from shabatm since a while. Did you come across the old version in the forum?
                Mati_93 @KristjanESPERANTO
                @KristjanESPERANTO I know topic is old…well instead of searching inside the app, I have been digging in Google browser . " Magic mirror modules"
                  sdetweil @Mati_93
                  @Mati_93 you will get older more times than not thru google…
