    Pollen module
    11 Posts 6 Posters 5.9k Views 6 Watching
      Sam 0
      I’m not a developer but maybe a pollen module would be nice or if it already exists I’d like to hear about it https://developers.google.com/maps/documentation/pollen/overview
        JohnGalt
        I use MMM-Pollen: https://github.com/vincep5/MMM-Pollen
        J 1 Reply Last reply
          joey @JohnGalt
          @JohnGalt Sorry to resurrect a year-old thread, but is MMM-Pollen still working for you? I cannot get it to work, but I am trying it for the first time today. Even just trying to go to the website referenced in the code directly gives me an HTTP error.
          I looked around a bit, and it looks like there are some people saying that the website it relies on, pollen.com, has disallowed or broken its API page, and others seem to say it is still working fine.
          Before I spend too much more time on this, I wanted to ask you, who is/was using the module, if it was still working. Hopefully, others can mention if it is working for them as well, or what they are using instead (assuming they are somewhere the other location-specific “Pollen” modules do not apply to).
          G R J 3 Replies Last reply
          • G
            gonzonia @joey
            @joey as far as I can tell it’s working for me. It’s not throwing any errors and the values change each day.
            Reply Quote 2
              raymondjspigot @joey
              @joey Hi how are things. Just from taking a quick look (am not the developer, don’t use this module, don’t have a test magicmirror to-hand) it looks like the API call the module’s making should work just fine.
              Trying to access the website using the url of the resource you can see inside MMM-Pollen.js doesn’t look like it will work, as I think maybe you need to specify a Referer in the header? Am new to this.
              If you want to test it out you could try: (this is what I did)
              • Go to an online API call utility like https://reqbin.com/
              • Add the base URL for the API call the module tries to make in the URL field (looks like it’s https://www.pollen.com/api/forecast/current/pollen/ )
              • Specify a zipcode for the call by adding it to the end of your URL so you have (e.g.) https://www.pollen.com/api/forecast/current/pollen/90210
              • Under Headers add a Key Referer and set its value to the same as the URL you have in the URL field
              • Click the Send button
              Mine came back with a json body that looks like it has pollen data in
                  "Type": "pollen",
                  "ForecastDate": "2026-05-25T00:00:00-04:00",
                  "Location": {
                      "ZIP": "90210",
                      "City": "BEVERLY HILLS",
                      "State": "CA",
                      "periods": [{
                          "Triggers": [{
                              "LGID": 186, ...
              so I’d’ve said the API the module depends on was ok at least. Maybe post a relevant chunk of your config.js you were using for the module and it’ll help with debugging it?
              Reply Quote 2
                joey @raymondjspigot
                @raymondjspigot Hey, that is good stuff! I did not think about adding a Referer. Following your instructions, I was able to pull real data instead of getting an error:
                My config is using the example from the module, just with a different zipcode and different screen region:
                   module: "MMM-Pollen",
                   position: "top_center",
                   header: "Pollen Forecast",
                       updateInterval: 3 * 60 * 60 * 1000, // every 3 hours
                       zip_code: "22202"
                It has been a while since I have had to think about headers, so I will brush up and see what I can do to make it work. It looks like vincep5 is still occasionally active on github, so maybe I can contribute a fix there.
                I appreciate your time looking at this. I was really only asking to see if it was working for everyone else (purely my problem) or if it was still hit-or-miss (problem with the API). Now, I even have a direction to start troubleshooting!
                  JohnGalt @joey
                  @joey – Yes, it is still working for me.
                  As a cross-check I just visited several websites that purport to track pollen levels, and verified the module appears to be reporting relatively the same pollen levels. Each site appears to have its own scale and they don’t all appear to measure the same pollen particles - so direct comparison is difficult - but the MagicMirror module appears to be working.
                  For reference, following is the config I use for this module:
                  {module: "MMM-Pollen", // https://github.com/vincep5/MMM-Pollen
                     disabled: false, position: "top_right", header: "Pollen Forecast",
                     updateInterval: 5 * 60 * 60 * 1000, // every 5 hours
                     zip_code: "xxxxx" }
                  I hope this helps.
                  Reply Quote 2
                    joey
                    After chasing my tail on the Referrer issue, I finally just started throwing “console.log” everywhere in the .js. By dumping the actual result from the query (called “body”), I can actually see valid data being returned! So, it is getting the data, but failing to parse/process/display it. The module is stuck on “Loading…” (And, even weirder, while restarting my MM over and over, it seemed like the module worked once! But with no changes, it is not working again now.)
                    I am digging into how it parses the data, and learning a lot about the console.log statement to figure out where it is breaking down.
                    See below for proof that the module is actually pulling data. Hopefully, tomorrow will bring more time to investigate.
                    On a side note, it is amazing how easy it is to lose track of time while working on what amounts to a sophisticated clock!
                    /* Magic Mirror
                     * Module: Pollen allergies
                    var NodeHelper = require('node_helper');
                    var request = require('request');
                      start: function () {
                        console.log('MMM-Pollen helper started ...');
                      getData: function (url) {
                          var self = this;
                          console.log('requesting:' + url);
                          request({ url: url, headers: {'Referer' : url}, method: 'GET' }, function (error, response, body) {
                              if (!error && response.statusCode == 200) {
                                  var result = JSON.parse(body);
                                  self.sendSocketNotification('POLLEN_RESULT', result);
                    -->       console.log('display body contents:' + body);
                              } else {
                                  console.log("MMM-Pollen : Could not load data.");
                      //Subclass socketNotificationReceived received.
                      socketNotificationReceived: function(payload) {
                         this.getData(payload);
                    [2026-05-27 20:20:28.607] [LOG]   Module helper loaded: MMM-Pollen
                    [2026-05-27 20:20:29.747] [LOG]   Connecting socket for: MMM-Pollen
                    [2026-05-27 20:20:29.747] [LOG]   MMM-Pollen helper started ...
                    [2026-05-27 20:20:31.512] [LOG]   requesting:https://www.pollen.com/api/forecast/current/pollen/90210
                    [2026-05-27 20:20:31.605] [INFO]  Checking git for module: MMM-Pollen
                    [2026-05-27 20:20:31.733] [LOG]   display body contents:{"Type":"pollen","ForecastDate":"2026-05-27T00:00:00-04:00","Location":{"ZIP":"90210","City":"BEVERLY HILLS","State":"CA","periods":[{"Triggers":[{"LGID":186,"Name":"Oak","Genus":"Quercus","PlantType":"Tree"},{"LGID":346,"Name":"Grasses","Genus":"Grasses","PlantType":"Grass"},{"LGID":236,"Name":"Mulberry","Genus":"Morus","PlantType":"Tree"}],"Period":"0001-01-01T00:00:00","Type":"Yesterday","Index":4.5},{"Triggers":[{"LGID":186,"Name":"Oak","Genus":"Quercus","PlantType":"Tree"},{"LGID":346,"Name":"Grasses","Genus":"Grasses","PlantType":"Grass"},{"LGID":236,"Name":"Mulberry","Genus":"Morus","PlantType":"Tree"}],"Period":"0001-01-01T00:00:00","Type":"Today","Index":4.5},{"Triggers":[{"LGID":186,"Name":"Oak","Genus":"Quercus","PlantType":"Tree"},{"LGID":346,"Name":"Grasses","Genus":"Grasses","PlantType":"Grass"},{"LGID":236,"Name":"Mulberry","Genus":"Morus","PlantType":"Tree"}],"Period":"0001-01-01T00:00:00","Type":"Tomorrow","Index":4.1}],"DisplayLocation":"Beverly Hills, CA"}}
                      sdetweil @joey
                      @joey node js now has fetch built in so you can stop
                      using request,
                      Take the json text and put it into one of the online formatters
                      my go to https://codebeautify.org/jsonvalidator?/jsonvalidate
                      paste, then hit the format button top left , you can copy out the formatter text to look at later too
                      and then you can see the structure and compare it to what the code expects
                        joey
                        I figured it out, at least for my system. I leaned on ChatGPT to figure out how to fix it. It appeared that it would sometimes update when I had MagicMirror running on the mirror system, but I also had a browser open to troubleshoot. Reloading the browser would sometimes make the module work.
                        It appears that the problem is the delay for updateDom might have been causing a timing issue. I posted the following as an issue to the module GitHub page:
                        In MMM-Pollen.js, changing “this.updateDom(this.config.fadeSpeed)” (line 132) to “this.updateDom(0)” seems to fix the problem I am seeing. There may be a more elegant solution, and it is possible this avoids one issue but can cause a different issue. Hopefully, vincep5 (or someone who knows more JS than I do) can find a proper way to fix this (or put logic to avoid the problem I see).
                        At some point, I will learn more JavaScript AND learn how to properly contribute code changes to GitHub projects. For today, I got a thing working and now I have to get back to other stuff.
                        @sdetweil This is entirely vincep5’s code (except for the one change I made). I am happy to keep using others’ modules, but I have not found the courage or time to make or fork things myself yet!
                          sdetweil @joey
                          @joey you are doing great!!!
