    PIR / MQTT - Presence sensor(s) revived
    43 Posts 7 Posters 11.1k Views 9 Watching
      rkorell Module Developer @htilburgs
      @htilburgs cool!
      happy, that you are satisfied!
      Warm regards,
      Ralf
      interesting that you are poistion this counterbar on thr right side of the screen.
      For me it feels/looks more natural on the left side.
      May this is the reason for my “acceptance” of the colorFrom / colorTo - “mismatch” you had reported …
      htilburgsH 1 Reply Last reply Reply Quote 0
      • htilburgsH
        htilburgs @rkorell
        @rkorell
        My current mirror
        This is why I have it on the right. For me this feels better.
        On the left side there comes the Spotify information, when I play music.
        (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
          I have a quite similar layout.
          My MusicPlayer (Volumio) is on the left side, too but is spreading the region if cover-art is appearing…
          Warmest regards,
          Ralf
          • htilburgsH
            htilburgs @rkorell
            @rkorell
            I see you’re even using one of my Modules (MMM-MyGarbage)
            Did you do something special for this, or is this an option in de Module?
            Because when MMM-OnSpotify appears, it just go over everything that is standing there.
            So for now I’ve disabled it and looking for a solution.
              Dear @htilburgs,
              Yes, I Like your garbage module - it’s really great - thanks for this!
              I’m using MMM-NowPlayingOnSpotify …
              This has exactly the behavioour as described.
              Shows a spotify logo - which I had replaced with Volumio logo (which is my favourite spotify player) and only expands if something is played.
              In this case the left corner looks like
              Warm regards,
              Ralf
                rkorell Module Developer @rkorell
                I’ve just seen that you had invented a solution for your problem - MMM-HideModulesOnSpotify :-)
                Cool!
                Ralf
                htilburgsH 1 Reply Last reply Reply Quote 1
                • htilburgsH
                  htilburgs @rkorell
                  @rkorell
                  That’s correct!
                  At the end, because it currently just works with MMM-OnSpotify, it was not so difficult.
                  I Will look into this in the near future to support other Player also.
                    MMM-PresenceScreenControl — two new releases (ecoMode + Notification API)
                    Dear all
                    a small but meaningful round of updates for MMM-PresenceScreenControl just landed on main. Both started from a single GitHub issue, so I thought I’d write up the chain of reasoning rather than just drop a changelog — maybe useful for anyone evaluating a migration from MMM-Pir, and definitely useful as a reminder to myself to check the parent project’s feature surface more carefully when forking.
                    Part 1 — ecoMode (Issue #5)
                    Rocket78 opened issue #5 with a really well-argued request: even with the screen physically off, Electron keeps repainting hidden DOM. On a Pi 3 with X11, MMM-PresenceScreenControl was leaving things like Newsfeed cross-fades running every 20 seconds — and those repaints showed up clearly as CPU spikes in his graph. He asked for an equivalent of MMM-Pir’s ecoMode, which hides every other module while the screen is off, so the browser skips layout/paint/composite for them.
                    So I built it, but tried to keep it lean:
                    ecoMode: false,        // opt-in, default off → no surprise
                    ecoModeIgnore: []      // module names to keep visible
                    Implementation notes that might interest other module authors:
                    Rocket78 also dropped a great ddcutil snippet in the issue for monitors that show a “no signal” splash when the video output is cut — that splash is genuinely immersion-breaking, and ddcutil setvcp D6 sends the actual DDC/CI power command, which is much closer to pressing the hardware power button:
                    onCommand:  ddcutil setvcp D6 1 --skip-ddc-checks
                    offCommand: ddcutil setvcp D6 5 --skip-ddc-checks
                    Added to the README’s offCommand examples. The --skip-ddc-checks is needed because some monitors stop responding to DDC queries when powered off but still process incoming power-on commands — so the check would fail before the command is even sent.
                    → Issue #5 closed, commit 42b68a6.
                    Part 2 — what else did I miss?
                    Closing the issue could have been the end of it. But Rocket78’s request raised an uncomfortable question: I never used ecoMode in MMM-Pir myself, so I didn’t notice it was missing. What else did I overlook when reviving MMM-Pir?
                    Three items jumped out as actual gaps that other modules in the ecosystem could legitimately depend on:
                    1. MMM_PIR-USER_PRESENCE — MMM-Pir broadcasts this notification on presence transitions. Other modules (Remote-Control, voice assistants, smart-home bridges) can listen for it.
                    2. MMM_PIR-WAKEUP / LOCK / UNLOCK / END — incoming notifications that let other modules control the screen logic externally.
                    3. MMM_PIR-SCREEN_POWERSTATUS — broadcast when the physical screen turns on or off.
                    Without these, anyone migrating from MMM-Pir to my fork would suddenly find their automations dead — because they’d be listening for MMM_PIR-USER_PRESENCE and nothing was coming through. Even worse, they wouldn’t know why it stopped working; the screen-on/off behavior would seem fine, but cross-module integration would be silently broken.
                    So I built a parallel notification API, namespaced MMM_PSC-* rather than impersonating MMM-Pir’s MMM_PIR-*:
                    Outgoing notifications — emitted on state transitions only:
                    MMM_PSC-USER_PRESENCE       payload: true / false
                                                fires when combined presence changes
                    MMM_PSC-SCREEN_POWERSTATUS  payload: true / false
                                                fires when physical screen turns on/off
                    Both fire only on actual transitions — no spam every poll cycle.
                    Incoming notifications — consumed by the module
                    MMM_PSC-WAKEUP   wake screen, reset timer (equivalent to a touch)
                    MMM_PSC-END      force screen off immediately
                    MMM_PSC-LOCK     freeze presence handling — sensors are still tracked internally, but no longer change screen state
                    MMM_PSC-UNLOCK   resume normal presence handling and re-evaluate the current sensor state
                    Implementation detail worth flagging: the LOCK guard sits in updatePresence(), which is the single funnel through which all sensor inputs (PIR, MQTT, touch, external wakeup socket) eventually pass. So whatever the trigger source, it’s correctly suppressed while locked. UNLOCK calls updatePresence() again, which re-evaluates the current sensor state — so if you’ve unlocked while a person is still in front of the PIR, the screen comes back on immediately. No need for the caller to send a WAKEUP after UNLOCK.
                    Useful patterns this enables:
                    // Wake the mirror when a doorbell event arrives:
                    this.sendNotification("MMM_PSC-WAKEUP");
                    // Force-off cleanly from outside (smart-home rule, etc.) without
                    // bypassing the module and going straight to the screen command:
                    this.sendNotification("MMM_PSC-END");
                    // Take exclusive control of the display for a video call,
                    // then hand it back when done:
                    this.sendNotification("MMM_PSC-LOCK");
                    // ... your module is showing its full-screen content ...
                    this.sendNotification("MMM_PSC-UNLOCK");
                    END is the clean way to force-off the screen from outside without touching offCommand directly — the module’s internal state stays consistent, all the right outgoing notifications still fire, and any other listeners (logging, analytics, smart home) see the transition.
                    Tested live end-to-end via MMM-Remote-Control’s notification API:
                    curl -X GET "http://localhost:8080/api/notification/MMM_PSC-LOCK"
                    curl -X GET "http://localhost:8080/api/notification/MMM_PSC-END"
                        → screen off, stays off
                    curl -X GET "http://localhost:8080/api/notification/MMM_PSC-WAKEUP"
                        → ignored (locked)
                    curl -X GET "http://localhost:8080/api/notification/MMM_PSC-UNLOCK"
                        → screen back on
                    All four routes verified, log trace clean, outgoing notifications fired in the right order on every transition.
                    → Commit 10000ca.
                    Update / install
                    If you’re already on the module:
                    cd ~/MagicMirror/modules/MMM-PresenceScreenControl
                    rm -rf node_modules
                    git pull
                    npm install
                    Both changes are backwards-compatible. ecoMode is opt-in (default false), and the new notifications are additive — nothing existing is modified. So you can update without touching your config and pick up only what you need.
                    A genuine thank-you to Rocket78 for the well-reasoned issue and the ddcutil tip — it triggered the full audit, which in turn closed a much bigger latent gap.
                    Exactly the kind of feedback that improves a fork. If you’ve migrated from MMM-Pir and notice anything else missing that you’d consider load-bearing, please open an issue.
                    Hope you find it useful.
                    Warmest regards,
                    Ralf
                    • A
                      atwist
                      For some reason, my mirror is not able to turn on thru MQTT. Below is most of the detail from the log file. MQTT explorer is showing that HomeAssistant is publishing via MQTT “true”. Do you have any suggestions?
                      [2026-05-22T21:32:28.750Z] PresenceControl: Received config: {“mode”:“MQTT”,“pirGPIO”:4,“mqttServer”:“mqtt://192.168.4.160:1883”,“mqttTopic”:“sensor/presence”,"mqttPayloadOccupancyF>
                      [2026-05-22T21:32:28.910Z] PresenceControl: [updateScreen] on=true, cmd=“wlopm --on HDMI-A-2”
                      [2026-05-22T21:32:29.211Z] PresenceControl: [updateScreen] SUCCESS: executed “wlopm --on HDMI-A-2”
                      [2026-05-22T21:32:29.357Z] PresenceControl: [updatePresence] pirPresence=false, touchPresence=false, presence=false, newPresence=false, locked=false
                      [2026-05-22T21:32:29.359Z] PresenceControl: Subscribed to MQTT topic: sensor/presence
                      [2026-05-22T21:33:02.189Z] PresenceControl: [startCounter] Counter expired: presence=false, pirPresence=false, calling updateScreen(false)
                      [2026-05-22T21:33:02.190Z] PresenceControl: [updateScreen] on=false, cmd=“wlopm --off HDMI-A-2”
                      [2026-05-22T21:40:24.572Z] PresenceControl: [updatePresence] pirPresence=false, touchPresence=false, presence=false, newPresence=false, locked=false
                      [2026-05-22T21:40:25.575Z] PresenceControl: [startCounter] Counter expired: presence=false, pirPresence=false, calling updateScreen(false)
                      [2026-05-22T21:40:25.576Z] PresenceControl: Counter expired, set presence to FALSE and stopped timer.
                        rkorell Module Developer @atwist
                        Dear @atwist,
                        first of all apologies for long delay - I was on vacation and offline.
                        A small disclaimer upfront: I haven’t seen your actual MQTT traffic, so the following is a hypothesis based on the log excerpt you posted. It fits the symptoms cleanly, but please verify before changing anything.
                        What I see in your log:
                        • The module connects to the broker fine
                        • It subscribes successfully to sensor/presence
                        • [updatePresence] fires (so messages ARE arriving — otherwise you wouldn’t see those entries triggered)
                        • But no parse error is logged, which means JSON.parse() did not throw
                        • The result is consistently mqttPresence=false, screen turns off after the counter or even never turns on.
                        Most likely cause: HomeAssistant publishes the value true directly (a JSON primitive), not a JSON object like {"presence": true}.
                        The module currently expects an object and reads the field onfigured in mqttPayloadOccupancyField (default: “presence”). JSON.parse("true") succeeds and returns the boolean true, but true["presence"] is undefined — which evaluates to no presence.
                        No exception, no parse error log, just silent false.
                        Quick way to verify what HA actually sends:
                        mosquitto_sub -h 192.168.4.160 -t sensor/presence -v
                        That’ll print one line per message. You’ll see exactly what arrives.
                        If the payload turns out to be a bare value (just true, "ON", etc.), there are two paths forward:
                        Either:
                        1. Update the module — I just pushed support for bare-string payloads exactly because of this case:
                        git pull
                        Then add to your module config:
                        mqttPayloadOn: "true"
                        (or whatever HA actually publishes — "ON", "on", etc.; check with the mosquitto_sub command above). With this set, the module compares the raw MQTT payload exactly against your string. Match → presence detected. Anything else → no presence.
                        Or:
                        2. Configure HA to publish a JSON object like {"presence": true} / {"presence": false} instead of the bare value (e.g. via the payload template of your MQTT publish action). Then your existing config works unchanged.
                        The new release also adds two diagnostic improvements that would have made this immediately visible:
                        • A new [MQTT] received (field/bare mode): mqttPresence=true/false log line on every message (debug level “complex”)
                        • The [updatePresence] line now includes mqttPresence= alongside the other sources
                        Sorry for the silent-fail behavior in the previous version — that’s been a documentation gap as well as a feature gap. Let me know if my hypothesis turns out to be wrong; if HA publishes something else entirely, the diagnosis would change.
                        Good luck.
                        Warmest regards,
                        Ralf
                        • A
                          atwist
                          That got me fixed up!. Thanks!
                            Good evening to all.
                            Today was an interesting day - caused by an issue posted by Stefano ( papinist )
                            He opened issue # 10 . with a friendly, well-argued suggestion: expose the mirror screen to Home Assistant as a proper switch — something you can both see (is the screen on?) and control (turn it on/off) as a native HA entity.
                            The nice realisation while designing it was that this needs almost nothing new. PSC already speaks MQTT — it already subscribes to a presence topic so that MQTT occupancy sensors can drive the screen. So Home Assistant is simply another presence source, exactly like a radar or mmWave sensor publishing occupancy. The only piece genuinely missing was the reverse direction: a topic the mirror writes, carrying its own screen state. No extra module, no shell scripts, no IPC — just publish one more thing and let HA subscribe to it.
                            The design
                            The result is an optional homeAssistant config block. Enable it and PSC opens a dedicated MQTT connection (independent of mode, so it works even in pure PIR setups), reusing the broker and credentials you already configured:
                            homeAssistant: {
                              enabled: false,                  // opt-in, default off → no surprise
                              discovery: true,                 // publish the HA auto-discovery config
                              discoveryPrefix: "homeassistant",// must match your HA MQTT discovery prefix
                              objectId: "magicmirror_screen",  // technical id → topic paths + HA unique_id
                              name: "MagicMirror Screen"       // friendly name shown in HA
                            A few decisions worth flagging, because each is a small opinion:
                            It’s a switch, not a button — so ON latches. ON sets a held presence signal: the screen stays on for as long as the switch is on. OFF releases it, and the mirror returns to standby through your normal counterTimeout — the same graceful countdown a PIR walk-away uses. There’s deliberately no separate “instant off”; if you want a snappy off, lower counterTimeout.
                            It never reaches into the module’s own logic. The integration adds exactly one OR-term to the presence evaluation — haPresence alongside the existing PIR / MQTT / touch sources — and it sits below the cron windows in precedence. The scheduler still wins: an ON during a cronIgnoreWindows is swallowed, an OFF during a cronAlwaysOnWindows is overridden. Timer, dimming and window logic are untouched.
                            The switch is a strict mirror of the real screen. The state topic always publishes the actual screen state, whatever caused the change — PIR, schedule, touch or HA — and it re-publishes after every command. So when the schedule rejects or overrides a command, the switch snaps back to reality rather than lying: HA can never show “on” while the screen is off, or vice versa. A command is a request; the fact is whatever the mirror actually does.
                            Auto-discovery + availability, so setup is effortless. On connect PSC publishes a retained Home Assistant MQTT-Discovery config and an availability topic backed by a Last-Will. HA creates the entity automatically and marks it unavailable if the mirror drops off the broker.
                            The topics, all derived from objectId:
                            homeassistant/switch/magicmirror_screen/config   (retained)  → discovery
                            magicmirror/magicmirror_screen/set                           → command  (HA → mirror: ON/OFF)
                            magicmirror/magicmirror_screen/state             (retained)  → state     (mirror → HA: ON/OFF)
                            magicmirror/magicmirror_screen/availability      (retained)  → online/offline (LWT)
                            How the auto-creation works
                            The mirror and Home Assistant never talk to each other directly — the broker is the only meeting point, and the discoveryPrefix (homeassistant) is the agreed channel. HA’s MQTT integration subscribes to homeassistant/# and listens for anyone announcing themselves there. Because our config is published retained, the broker hands it to HA the instant HA connects — even if HA boots hours later. HA reads the topic path plus the JSON body and builds switch.magicmirror_screen, wired to the command/state/availability topics. It’s the same mechanism Tasmota, Zigbee2MQTT and ESPHome use — the mirror just follows the convention, so it’s picked up like any other device.
                            An example automation (doorbell → wake → graceful standby)
                            automation:
                              - alias: "Doorbell wakes the MagicMirror"
                                trigger:
                                  - platform: state
                                    entity_id: binary_sensor.video_doorbell
                                    to: "on"
                                action:
                                  - service: switch.turn_on
                                    target: { entity_id: switch.magicmirror_screen }
                                  - delay: "00:00:30"        # keep the camera visible while you look
                                  - service: switch.turn_off
                            Turn it on when the doorbell rings, keep it visible for half a minute, then hand back to PSC’s timer for the standby — or drop the delay/off and turn it off from another trigger, whatever fits your flow.
                            A note on testing
                            I don’t run Home Assistant here, so I verified the whole MQTT surface with MQTT Explorer playing HA’s role — publishing ON/OFF to the command topic and watching the discovery, state and availability topics. The entire round-trip is observable that way: ON holds, OFF starts the countdown, the state tracks the real screen (including snapping back when the schedule overrides a command), the discovery config is well-formed, availability goes online on start. The one thing that needs a real instance — does HA actually auto-create the entity from that config — is being confirmed by papinist, who has the setup for it.
                            Update / install
                            git pull
                            No dependency changes this time, so no npm install is needed — just restart MagicMirror. Everything is backwards-compatible and opt-in: homeAssistant.enabled defaults to false, and the rest is additive, so an update touches nothing in your existing setup until you switch it on.
                            A genuine thank-you to papinist for the friendly, well-reasoned suggestion and the pleasantconversation that shaped it. Exactly the kind of exchange that makes maintaining a module worthwhile.
                            Warmest regards,
                            Ralf
                              papinist @rkorell
                              Hi Ralf (@rkorell),
                              Stefano here! Thank you so much for the detailed explanation and the kind words!
                              I can confirm to the whole community that v1.6.0 works perfectly with a real Home Assistant setup. The Auto-Discovery payload is recognized immediately by HA, creating a native switch.magicmirror_screen entity out of the box.
                              The behavior is super smooth: switching it ON holds the screen and modules active, and turning it OFF allows PSC to handle the graceful countdown to standby via counterTimeout.
                              Thank you again for your open collaboration and for turning a issue/discussion into such a brilliant feature for the module!
                              Warm regards,
                              Stefano (papinist)
                                rkorell Module Developer @papinist
                                @papinist Thanks, dear Stefano for your confirmation!
                                in addition Stefano introduced another idea which pumps addional value to the module.
                                Following Stefano’s idea the module now announces the raw PIR-Motion data as well as the presence-information to MQTT Broker - so HA is able to trigger additinal actions (e.g. switching a light on) .
                                Happy mirroring!
                                Warmest regards,
                                Ralf
                                • 2 / 3
