    MMM-KitchenTimer - Touch-friendly countdown timer
    timertouchkitchen
    29 Posts 3 Posters 1.2k Views 3 Watching
      bwente @Niggich
      @Niggich said:
      My Echo know I want to start a Timer but it’s asking for how long.
      Great, now that you’ve confirmed MQTT is working, the next step is to add the Home Assistant automation.
      alias: MagicMirror kitchen timer started
      triggers:
        - trigger: mqtt
          topic: magicmirror/kitchen-timer/started
      actions:
        - action: media_player.play_media
          target:
            entity_id: media_player.kitchen_echo
          data:
            media_content_type: custom
            media_content_id: >-
              set a timer for
              {{ trigger.payload_json.remainingSeconds | int }}
              seconds
      I think that will work. I don’t know if it needs to be escaped or not.
      NiggichN 1 Reply Last reply Reply Quote 0
      • NiggichN Offline
        Niggich @bwente
        @bwente I add the automation already and change it again but the echo still asking “for how log should be the timer”… I also try to fix it with ChatGPT but this was not working.
          bwente @Niggich
          @Niggich looks like trigger.payload_json.remainingSeconds is empty or double quoted. Can you view just the payload and see?
          • NiggichN Offline
            Niggich @bwente
            @bwente I’m sorry but where I found trigger.payload_json.remainingSeconds?
              sdetweil @Niggich
              @Niggich in an HA. Automation are variable to help you do want you want
              One of those is
              trigger. - what started the automation
              If you go into HA , settings, automations, pick any one,
              Look at the traces (3 dot menu). You can see the variables and values for each step of the automation
              NiggichN 1 Reply Last reply Reply Quote 1
              • NiggichN Offline
                Niggich @sdetweil
                @sdetweil Thank you. I don’t know if I’m right but this is the variable from the traces.
                this:
                  entity_id: automation.timer
                  state: 'on'
                  attributes:
                    last_triggered: '2026-08-13T11:33:26.793052+00:00'
                    mode: single
                    current: 0
                    friendly_name: MagicMirror kitchen timer started
                  last_changed: '2026-08-14T20:14:37.860754+00:00'
                  last_reported: '2026-08-14T20:14:37.860754+00:00'
                  last_updated: '2026-08-14T20:14:37.860754+00:00'
                  context:
                    parent_id: null
                    user_id: null
                trigger:
                  idx: '0'
                  alias: null
                  platform: mqtt
                  payload: >-
                    {"status":"running","remainingSeconds":60,"endsAt":1786738603487,"durationSeconds":60,"elapsedRatio":0}
                  qos: 0
                  description: mqtt topic magicmirror/kitchen-timer/started
                  payload_json:
                    status: running
                    remainingSeconds: 60
                    endsAt: 1786738603487
                    durationSeconds: 60
                    elapsedRatio: 0
                  sdetweil @Niggich
                  @Niggich so
                  trigger.payload.remainingSeconds
                  • NiggichN Offline
                    Niggich @sdetweil
                    @sdetweil No, it is not working.
                      sdetweil @Niggich
                      @Niggich sorry, this is case sensitive and I had lower case s, see my edit
                      • NiggichN Offline
                        Niggich @sdetweil
                        @sdetweil No, it’s not working. This is the automation
                        triggers:
                          - trigger: mqtt
                        actions:
                            target:
                              entity_id: media_player.echo_show_kuche
                            data:
                              media:
                                  set a timer for {{ trigger.payload.remainingSeconds | int }}
                                  seconds
                                metadata: {}
                          sdetweil @Niggich
                          @Niggich if you examine the traces , what error is reported?
                          • NiggichN Offline
                            Niggich @sdetweil
                            @sdetweil sagte:
                            This Error is shown: “Error rendering data template: UndefinedError: ‘str object’ has no attribute ‘remainingSeconds’”
                            When I change the trigger back to trigger.payload_json.remainingSeconds is no Error reported an the Echo asks for how long should be the timer.
                            The traces-Log says this.
                            params:
                              domain: media_player
                              service: play_media
                              service_data:
                                entity_id:
                                  - media_player.echo_show_kuche
                                media_content_id: set a timer for 60 seconds
                              target:
                                entity_id:
                            running_script: false
                              sdetweil @Niggich
                              @Niggich ok. Good info
                              I need to test this myself, but won’t be able to til tomorrow sometime. I also need to use my echo device which is currently not used
                              • NiggichN Offline
                                Niggich @sdetweil
                                @sdetweil Ok, don’t worry. I’m happy you help me. Thank you!
