    MMM-KitchenTimer - Touch-friendly countdown timer
    timertouchkitchen
    29 Posts 3 Posters 1.2k Views 3 Watching
    • NiggichN Offline
      Niggich @bwente
      @bwente I’m sorry but where I found trigger.payload_json.remainingSeconds?
        sdetweil @Niggich
        @Niggich in an HA. Automation are variable to help you do want you want
        One of those is
        trigger. - what started the automation
        If you go into HA , settings, automations, pick any one,
        Look at the traces (3 dot menu). You can see the variables and values for each step of the automation
        NiggichN 1 Reply Last reply Reply Quote 1
        • NiggichN Offline
          Niggich @sdetweil
          @sdetweil Thank you. I don’t know if I’m right but this is the variable from the traces.
          this:
            entity_id: automation.timer
            state: 'on'
            attributes:
              last_triggered: '2026-08-13T11:33:26.793052+00:00'
              mode: single
              current: 0
              friendly_name: MagicMirror kitchen timer started
            last_changed: '2026-08-14T20:14:37.860754+00:00'
            last_reported: '2026-08-14T20:14:37.860754+00:00'
            last_updated: '2026-08-14T20:14:37.860754+00:00'
            context:
              parent_id: null
              user_id: null
          trigger:
            idx: '0'
            alias: null
            platform: mqtt
            topic: magicmirror/kitchen-timer/started
            payload: >-
              {"status":"running","remainingSeconds":60,"endsAt":1786738603487,"durationSeconds":60,"elapsedRatio":0}
            qos: 0
            description: mqtt topic magicmirror/kitchen-timer/started
            payload_json:
              status: running
              remainingSeconds: 60
              endsAt: 1786738603487
              durationSeconds: 60
              elapsedRatio: 0
            sdetweil @Niggich
            @Niggich so
            trigger.payload.remainingSeconds
            NiggichN 1 Reply Last reply Reply Quote 0
            • NiggichN Offline
              Niggich @sdetweil
              @sdetweil No, it is not working.
                sdetweil @Niggich
                @Niggich sorry, this is case sensitive and I had lower case s, see my edit
                • NiggichN Offline
                  Niggich @sdetweil
                  @sdetweil No, it’s not working. This is the automation
                  alias: MagicMirror kitchen timer started
                  triggers:
                    - trigger: mqtt
                  actions:
                    - action: media_player.play_media
                      target:
                        entity_id: media_player.echo_show_kuche
                      data:
                        media:
                          media_content_id: >-
                            set a timer for {{ trigger.payload.remainingSeconds | int }}
                            seconds
                          media_content_type: custom
                          metadata: {}
                    sdetweil @Niggich
                    @Niggich if you examine the traces , what error is reported?
                    • NiggichN Offline
                      Niggich @sdetweil
                      @sdetweil sagte:
                      This Error is shown: “Error rendering data template: UndefinedError: ‘str object’ has no attribute ‘remainingSeconds’”
                      When I change the trigger back to trigger.payload_json.remainingSeconds is no Error reported an the Echo asks for how long should be the timer.
                      The traces-Log says this.
                      params:
                        domain: media_player
                        service: play_media
                        service_data:
                          entity_id:
                            - media_player.echo_show_kuche
                          media_content_id: set a timer for 60 seconds
                        target:
                          entity_id:
                      running_script: false
                        sdetweil @Niggich
                        @Niggich ok. Good info
                        I need to test this myself, but won’t be able to til tomorrow sometime. I also need to use my echo device which is currently not used
                        • NiggichN Offline
                          Niggich @sdetweil
                          @sdetweil Ok, don’t worry. I’m happy you help me. Thank you!
