    Version upgrade from 2.34.0 to 2.36.0 Calendar Probs
    10 Posts 3 Posters 1.9k Views 3 Watching
      MyMirror
      Hello everyone,
      Since upgrading to MM version 2.36.x, I’ve been having a problem with the display of my images, which are controlled via the calendar.
      I use an ICS file to display the collection times for my various bins on MM.
      Up to version 2.34.x, this worked quite smoothly with a little trick.
      This is what the display looked like in version 2.34.x (grey, blue, green images):
      Here is the custom.css file for the calendar:
      The names and locations of the pictures:
      The excerpt from the config.js file for the calendar module:
      And finally, here’s a short extract from my ics file:
      I used Sam’s Backup&Restore script to back up my modules. I then installed the new version 2.36.x on a new SD card and restored the modules using Sam’s script.
      Basically, everything is working again – apart from the display of the coloured bins.
      A test via a browser on my PC within my network showed me that I can’t display the images in the CSS folder.
      Attempts using the “default” or “vendor” directories also failed to produce the desired result.
      Does anyone have any idea how I can get the icons to display again?
      Many thanks
      KristjanESPERANTOK S 2 Replies Last reply Reply Quote 0
        MyMirror @sdetweil
        Hi Sam, at the end i’ve to change a little bit more:
        I’ve created following folders under modules:
        pi@MM30626:~/MagicMirror/modules $ ls -al calendar/
        total 28
        drwxrwxr-x  3 pi pi  4096 Aug 12 19:34 .
        drwxrwxr-x 31 pi pi  4096 Aug 12 15:31 ..
        -rw-rw-r--  1 pi pi 15565 Jul 26 15:23 abholtermine_gefiltert.ics
        drwxrwxr-x  2 pi pi  4096 Aug 12 19:34 public
        pi@MM30626:~/MagicMirror/modules $ ls -al calendar/public/
        total 48
        drwxrwxr-x 2 pi pi 4096 Aug 12 19:34 .
        drwxrwxr-x 3 pi pi 4096 Aug 12 19:34 ..
        As you can see, there is my ics file and a public folder witth my pictures.
        E.g. “BL.png” means blue garbage can for paper, “GR.png” for green waste bin etc.
        The “abholtermine_gefiltert.ics” is a python output 'cause i have to take out some lines.
        This is how my config folder looks like:
        pi@MM30626:~/MagicMirror/config $ ls -al
        total 40
        drwxrwxr-x  2 pi   pi    4096 Aug 27 15:33 .
        drwxrwxr-x 17 pi   pi    4096 Aug 23 10:32 ..
        -rw-rw-r--  1 pi   pi      30 Aug 27 15:24 basepath.js
        -rw-rw-r--  1 pi   pi   18339 Aug 27 15:24 config.js
        -rw-rw-r--  1 pi   pi    2220 Aug 18 15:37 custom.css
        The description for the calendar in the config.js:
        //		siehe im MagicMirrir/css Veerzeichnis die custom.css und Bilder
        			header: "Mülltermine",
        					maximumNumberOfDays: 60,
        					maximumEntries: 4,
        					timeFormat:"HH:mm [Uhr]",
        					joiningWord:"um",
        					dateFormat:"DD.MMMM",
        					maximumNumberOfDays:"31",
        					maxTitleLength:"30",
        					customEvents: [
        							keyword: 'Abfuhr blaue',
        							symbol: '',
        							eventClass: 'muell-blau'
        							keyword: 'Abfuhr schwarze',
        							symbol: '',
        							eventClass: 'muell-schwarz'
        							keyword: 'Abfuhr grüne',
        							symbol: '',
        							eventClass: 'muell-gruen'
        							keyword: 'Problemabfall',
        							symbol: '',
        							eventClass: 'muell-rot'
        					coloredSymbolOnly: true,
        					coloredSymbol: true,
        					coloredText: true,
        					columns: true,
        						symbol: 'calendar',	//'calendar',
        						color: '#2e9afe',
        						url: 'webcal://localhost:8080/modules/calendar/abholtermine_gefiltert.ics'
        and my custom.css looks like this:
         * Magic Mirror                                      *
         * Custom CSS                                        *
         * By Michael Teeuw http://michaelteeuw.nl           *
         * MIT Licensed.                                     *
         * Add any custom CSS below.                         *
         * Changes to this files will be ignored by GIT. *
         body {
        /* Gemeinsame Basis für alle Müll-Icons */
           Mülltonnen-Symbole für das Standard Calendar-Modul
        /* Standard-Font-Awesome-Symbol ausblenden */
        .calendar .event-wrapper.muell-blau .symbol span,
        .calendar .event-wrapper.muell-schwarz .symbol span,
        .calendar .event-wrapper.muell-gruen .symbol span,
        .calendar .event-wrapper.muell-laub .symbol span {
            display: none;
        /* Symbol-Zelle der blauen Tonne */
        .calendar .event-wrapper.muell-blau .symbol {
            background-image: url("/modules/calendar/public/BL.png");
            background-repeat: no-repeat;
            background-position: center center;
            background-size: contain;
            width: 40px;
            height: 40px;
        /* Symbol-Zelle der schwarzen/grauen Tonne */
        .calendar .event-wrapper.muell-schwarz .symbol {
            background-image: url("/modules/calendar/public/SW.png");
            width: 40px;
            height: 40px;
        /* Symbol-Zelle der grünen Tonne */
        .calendar .event-wrapper.muell-gruen .symbol {
            background-image: url("/modules/calendar/public/GR.png");
            width: 40px;
            height: 40px;
        /* Symbol-Zelle der Laubtonne */
        .calendar .event-wrapper.muell-laub .symbol {
            background-image: url("/modules/calendar/public/LA.png");
            width: 40px;
            height: 40px;
        At the end i have my bins on the screen:
        I’m sure there must be a much simpler way, but it took me quite a while to get the result, and that’s what counts in the end. ;-)
        BR
        Jens
        • KristjanESPERANTOK Online
          KristjanESPERANTO Module Developer @MyMirror
          @MyMirror We have calendar issues in v2.36.0. These have been fixed in the development branch. The new release, v2.37.0, will be released today. I would recommend waiting for it and then trying it out :)
            MyMirror @KristjanESPERANTO
            @KristjanESPERANTO
            Thanks for this answer !
            I’ll wait.
              sdetweil @MyMirror
              @MyMirror also, the css folder is for OUR stuff in 2.35+, all user stuff is moved to the config folder
              so, move the images there and see if it works
              also, picky support person here, please use text for config content…
              pics are very hard to read…
              also, config or log info should go in a code block…
              paste text in this message editor, blank line above and below
              select the text just pasted
              hit the code button </> above on the editor toolbar
              thanks
                @mymirror did the 2.37 release resolve this problem?
                  MyMirror @sdetweil
                  total 28
                  total 48
                  total 40
                  					maximumEntries: 4,
                  					joiningWord:"um",
                  					customEvents: [
                  							symbol: '',
                  							symbol: '',
                  							symbol: '',
                  							symbol: '',
                  					coloredText: true,
                  					columns: true,
                  						color: '#2e9afe',
                   * Magic Mirror                                      *
                   * Custom CSS                                        *
                   * MIT Licensed.                                     *
                   body {
                      display: none;
                      width: 40px;
                      height: 40px;
                      width: 40px;
                      height: 40px;
                      width: 40px;
                      height: 40px;
                      width: 40px;
                      height: 40px;
                  BR
                  Jens
                    sdetweil @MyMirror
                    @MyMirror cool. You could have done the files and folders in the config folder
                    path="config/xxx.ics" or png
                    Or
                    url("/config/public/xxx.png")
                      MyMirror @sdetweil
                      Thank you very much for the tip.
                      But I’ll leave it as it is for now.
                        sdetweil @MyMirror
                        @MyMirror I wasn’t suggesting you change anything… just for others watching, there are other options…
                        my backup/restore won’t save/restore files from inside the default_modules… cause they are not supposed to change
                          MyMirror @sdetweil
                          Everything’s fine – that’s what I thought.
                          That’s why I’ve set out my changes as clearly as possible.
                          Thank you very much!
                          • S sdetweil has marked this topic as solved
