    Modular configuration generation
    Scheduled Pinned Locked Moved Solved Feature Requests
    8 Posts 4 Posters 4.1k Views 4 Watching
      daedalus7
      I would propose the following as a transitional addition to the configuration system.
      1. Add a simple GUI based configuration utility or web frontend to the system (there are some modules that attempt to do this already so it would be minimal work to adapt it to the following second detail.
      2. For the simple GUI enforce a configuration contract with modules that follows a defined schema using [tags] to define types of information blocks. For a module to be able to show up in the GUI developers will need to briefly update their github repository to add a contract.yaml etc file that defines the default settings for the module.
      This merges into the main program a feature that other modules have attempted to create while transitioning the system to a true contract based configuration system that allows for much easier user settings changes. The onus is on the module developers to present the correct base configuration file from which the dynamic configuration file for magicmirror can then be crafted from.
      S 2 Replies Last reply
        sdetweil @daedalus7
        @daedalus7
        See my MMM-Config.
        https://github.com/sdetweil/MMM-Config
        It supports the base MagicMirror and all modules.
        It does not require a specific set of options, but auto discovers the module definitions
        It supports the module defaults, can provide select lists, booleans, numbers, floats, structures, arrays. And field level help
        Also supports live view of the module readme, in both install and configure scenarios
        A module developer can create a json file to describe their module config if the auto generated format isn’t sufficient.
        See the wiki on creating the custom module form definition
        https://github.com/sdetweil/MMM-Config/wiki
        I have helped a few module authors in this process. and I have created a few customized forms, which MMM-Config ships to cover the modules not being maintained but used
        The objective of MMM-Config is to
        • support the modules(1400+) as is( some are not maintained, but heavily used),
        • allow extended customization, (as you suggest), see the wiki, I provide a tool to generate the form for a module so that it can be tweaked instead of developed from scratch
        • provide a common ui structure, for the base and modules,
        • support modules that support multiple instances ( calendar and weather are good examples) ,
        and do this as one view, everything all at once.
        The ui can be customized thru css
        The current version also provides support for module installation, using the data from the 3rd party module list
        msimon360M 1 Reply Last reply
        • msimon360M
          msimon360 @sdetweil
          @sdetweil This is great. I have been working on something similar but I didn’t need to. I wish I could find cool things like this already exist for Magic Mirror easier.
            sdetweil @msimon360
            @msimon360 use the search in the 3rd party list…
            links in the header of this forum
              sdetweil @msimon360
              @msimon360 i’d love your feedback on a new feature
              I don’t provide support to upgrade individual modules.
              thinking about this
              should it only list those modules IN USE? or ALL modules ‘cloned’ into the modules folder (note ‘installed’ is a vague term here)
              as a developer of this module , I have 100’s of modules ‘cloned’, but only a few (in use) at any time
              I don’t want to burden the user with unnecessary things to work on. but don’t want to make them do things over and over from being too selective(Oh added another module to the active config, but its downlevel… oops)… (and I don’t WANT to provide a config option, cause NOBODY (me included) reads the doc)…
              maybe its just a checkbox on the page in use/all
                sdetweil @daedalus7
                @daedalus7 one other focus area for MMM-Config,
                most of our ‘developers’ have never written a line of code before…
                they just want something displayed on the MM screen…
                so, I have done everything I can to make this a NO effort added value for them too.
                i don’t read the code to figure out how variables are used, and looking thru the modules, this only applies in less than 10 of now 1418 modules
                the mod to make a select list vs a text entry field is to add an
                enum:[choice1, choice2, choice3…]
                to the form definition
                and sometimes what you CAN do in javascript, doesn’t fit to the form UI at all, so one can convert back/forth with a converter routine to make it better… see the compliments module for example
                B 1 Reply Last reply
                  braijuvrou @sdetweil
                  MMM Config already seems to cover most of the proposed workflow without forcing every module author to adopt a new schema. The automatic discovery plus optional custom form definitions sounds like a practical balance between compatibility and structured configuration.
                    sdetweil @braijuvrou
                    @braijuvrou thanks… and the MMM-Config user doesn’t know, or need to know, how all this was constructed…
                    • S sdetweil has marked this topic as solved
