    MMM-PublicTransportHafas
    17 Posts 3 Posters 452 Views 3 Watching
      Mati_93
      Update socket issue 1 No data received yet .
      It is already second time with this problem. Last time update helped. This time not. What has been changed? It still uses vendo profile besides I changed in config.js to “db”
      Edit: by fahrplanguru also only flixbus is available
      • KristjanESPERANTOK
        KristjanESPERANTO Module Developer @Mati_93
        @Mati_93 That are endpoint issues. Have you tried https://github.com/KristjanESPERANTO/MMM-PublicTransportHub?
        O M 2 Replies Last reply Reply Quote 0
        • O
          onkelbobby @KristjanESPERANTO
          @KristjanESPERANTO
          Thank you for all the work and time you have put into the Public Transport Modules.
          Would you say that MMM-PublicTransportHub is intended to replace the MMM-PublicTransportHafas in the future?
          What would you recommend for a local and regional usecase in Munich, Germany including BRB?
            KristjanESPERANTO Module Developer @onkelbobby
            I have the impression that there are fewer and fewer working HAFAS providers - which is why MMM-PublicTransportHub is, in a way, more future-oriented, since it supports more than just HAFAS.
            I don’t have any experience with your region. So I recommend give MMM-PublicTransportHub with Transitous a try :)
              Mati_93 @KristjanESPERANTO
              @KristjanESPERANTO
              Your module does not support German keyboard special signs. How can I find 18 März Straße and besides is not working for Gotha Hbf.
              What’s going on with world transport APIs lol
              Module is working on main station but it’s very hard to find stationId from the German streets like 18 März Straße Gotha. Any ideas? Node query is limited to bigger stations.
                @Mati_93
                What makes you say that? It works for me.
                Did you check the vmt profile?
                This seems to be what you are searching for:
                      module: "MMM-PublicTransportHafas",
                      position: "bottom_left",
                        hafasProfile: "vmt",
                        stationID: "167050",
                        stationName: "Gotha, 18.-März-Straße"
                  @KristjanESPERANTO Have you found in node seeker?
                  Ohhh now Hafas module again : D
                  But your module is working for Gotha Hauptbahnhof. Can we speak German or we require English only on this forum?
                    Mati_93 @Mati_93
                    Error code ops_blocked when searching in MMM-PublicTransportHub module using node --run query
                      @Mati_93 Have you managed to figure it out yet? :) If not, please describe again what you’re trying to do and what’s not working. And most importantly, which module you’re using.
                        @KristjanESPERANTO well, on the HAFAS (older module) I see only 22 position when I am searching using node. Why? How to change pagination.
                        Your new Module HUB is working for Gotha Hauptbahnhof… perfectly. I want to use both modules if possible.
                        And still on theolder module HAFAS is update socket issue 1
                        On the searching mode inside node query can not use German letters. How to configure node CLI?20260904_14h51m33s_grim.png
                        On your module Hub node console looks exactly:
                          Mati_93 @Mati_93
                          So ID searching tool from node query still won’t work with 18 März Straße but i found stationId via gemini :) (i dont’ like it). In my code i am using two TransportHub modules (TransportHafas is in code but i am not using in my carousel because is not working) . 18 Marz Strasse station does not return an error but says that there is no departures. Ansbach station works perfecly.
                          let config = {
                              address: "localhost", // Lub "127.0.0.1"
                              port: 8080,
                              basePath: "/",
                              ipWhitelist: ["127.0.0.1", "::1"], // Zezwala na dostęp tylko z tego samego urządzenia
                              useHttps: false,
                              httpsPrivateKey: "",
                              httpsCertificate: "",
                              language: "pl",
                              locale: "pl",
                              logLevel: ["INFO", "LOG", "WARN", "ERROR"],
                              timeFormat: 24,
                              units: "metric",
                           		module: "MMM-KeyBindings",
                             			evdev: { enabled: false },
                          			enableKeyboard: true,
                                		module: "MMM-Carousel",
                          		position: "bottom_bar",
                                  		transitionInterval: 20000,
                                  		ignoreModules: ["clock", "alert","Station_Gotha"],
                                  		mode: "slides",
                                  		showPageIndicators: true,
                                  		showPageControls: true,
                                  		slides: {
                                    			main: ["weather"],
                                    			"Slide 2": ["MMM-OpenWeatherForecast", "newsfeed"],
                                    			"Slide 3": ["calendar", "compliments"],
                          				"Slide 4": ["MMM-PublicTransportHub"],
                          				"Slide 5": ["MMM-EasyPix"]
                                  		keyBindings: {
                                    			enabled: true,
                                    				map: {
                                      					NextSlide: "ArrowRight",
                                     		 			PrevSlide: "ArrowLeft",
                                      					Pause: "ArrowDown",
                                      					Slide0: "Home"
                                   		 mode: "DEFAULT"
                                		module: "MMM-EasyPix",
                          			picName: "Alona.jpg",  // Enter the picture file name. You can even use a direct internet URL to an image.
                                  		maxWidth: "70%"       // Size picture precisely. Retains aspect ratio.
                                      module: "alert"
                                      module: "updatenotification",
                                      header: "US Holidays",
                          	    position: "top_bar",
                                      header: "Holidays in Thüringen",
                                                  symbol: "calendar-check",
                                                  url: "https://www.officeholidays.com/ics-all/germany/thuringia"
                          		module: "compliments",
                          		position: "lower_third",
                                      module: "weather",
                          	    classes : "weather-forecast",
                                      header: "Weather Forecast",
                                          weatherProvider: "openmeteo",
                                          type: "forecast",
                                          lat: 50.9494849,
                                          lon: 10.7014435
                                      module: "weather",
                                      classes : "weather-current",
                          	    header: "Weather Current",
                                          type: "current",
                                          lat: 50.9494849,
                                          lon: 10.7014435
                             		module: "MMM-OpenWeatherForecast",
                              		header: "Forecast",
                                			apikey: "23cf27375cfb96bd9c4bcfe389c729c6", //only string here
                                			latitude: 50.9494849,            //number works here
                                			longitude: "10.7014435",          //so does a string
                          			units: "metric",                 // dopasowane do reszty
                                          	updateInterval: 600000,          // co 10 min
                                          	animationSpeed: 1000,
                                          	lang: "pl",
                          			label_hourlyTimeFormat: "H:mm",
                          			label_sunriseTimeFormat: "H:mm",
                          			label_days: ["Ndz", "Pon", "Wt", " Śr", "Czw", "Pt", "Sob"],
                                          	showCurrentConditions: true,
                                          	showHourlyForecast: true,
                                          	showDailyForecast: true,
                                          	hourlyForecastInterval: 3,
                                          	dailyForecastDays: 7
                                      module: "newsfeed",
                                          feeds: [
                                                  title: "New York Times",
                                                  url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                                          showSourceTitle: true,
                                          showPublishDate: true,
                                          broadcastNewsFeeds: true,
                                          broadcastNewsUpdates: true
                          		module: 'clock',
                                		position: 'bottom_bar'
                          			carouselId: "My_Station",
                                          	stationName: "Gotha, 18.-März-Straße",
                                          	direction: "",
                                          	excludedTransportationTypes: [],
                                          	ignoredLines: [],
                                          	timeToStation: 10,
                                          	displayLastUpdate: true,
                                          	maxUnreachableDepartures: 0,
                                          	maxReachableDepartures: 7,
                                          	showColoredLineSymbols: true,
                                          	customLineStyles: "",
                                          	showOnlyLineNumbers: false,
                                          	showTableHeadersAsSymbols: true,
                                          	useColorForRealtimeInfo: true
                              		module: "MMM-PublicTransportHub",
                              		header: "Gotha, 18.-März-Straße",
                          			carouselId: "Station_Gotha",
                          			provider: "vmt",
                          			stationId: "de-DELFI_de:16067:167050",
                          			updatesEvery: 60,
                          			maxDepartures: 12,
                          			timeToStation: 4,
                          			maxUnreachableDepartures: 2,
                          			excludeCanceled: false,
                          			lineFilter: [],
                          			directionFilter: [],
                          			productFilter: ["tram", "bus"],
                          			showDelay: false,
                          			showRealtimeIndicator: true,
                          			showRemarks: true,
                          			columnOrder: ["time", "line", "direction", "platform"],
                          			lineStylePreset: "none",
                          			replaceInLineNames: { "Bus ": "" },
                          			requestTimeoutMs: 12000,
                          			fetchRetries: 1,
                          			contact: "mateusz.kujawa93@gmail.com"
                              		position: "bottom_right",
                              		header: "Ansbach",
                          			carouselId: "Station_Ansbach",
                                  		provider: "transitous",
                          			stationId: "de-DELFI_de:09561:11000:53:4",
                          			updatesEvery: 60,
                          			maxDepartures: 12,
                          			timeToStation: 4,
                          			lineFilter: [],
                          			showDelay: false,
                          			showRemarks: true,
                          			fetchRetries: 1,
                          /***** DO NOT EDIT THE LINE BELOW *****/
                          please help me to figure it out together.
                            @Mati_93 Wow, that a bunch of separate issues. These three minimal configurations work for me with the Gotha stop. Please test them one at a time first. I had to play with timeInFutureMinutes a bit to get departures.
                            MMM-PublicTransportHub with HAFAS
                                provider: "hafas",
                                stationId: "167050",
                                timeInFutureMinutes: 720
                            Older MMM-PublicTransportHafas
                                timeInFuture: 720
                              position: "top_center",
                                stationId: "de-DELFI_de:16067:167050::16705000",
                                contact: "@Mati_93",
                            Please note that vmt is a HAFAS profile, not a provider. Therefore the Hub needs provider: "hafas" together with hafasProfile: "vmt".
                            The garbled German characters look like a UTF-8/locale problem on Raspberry Pi OS. Please check:
                            locale
                            locale charmap
                            The result should contain UTF-8. You can configure this with:
                            sudo raspi-config
                            I think you have to select Localization Options → Locale and enable de_DE.UTF-8 UTF-8. Log in again or reboot afterwards.
                            As a quick test, you can search without special characters:
                            18 Maerz Strasse Gotha
                            OPS_BLOCKED usually comes from a blocked DB endpoint. For Gotha, please use the regional vmt profile instead of a DB profile.
                              @KristjanESPERANTO I can use German signs everywhere on terminal but not in node.js.
                              After I type node – run query i am no longer permitted to use äüß umlauts.
                              Second problem : HAFAS is over. All the time I have socket issue.
                              As you seen in my project i am using carouselId variable because on every slide I have different station. On HAFAS this was possible but on your new module Hub this is impossible(or maybe i don’t know the new way) . New modules understand only module name instead of carouselId. Please take a deeper look on my slide config.
                              let config = {
                                  port: 8080,
                                  basePath: "/",
                                  useHttps: false,
                                  language: "pl",
                                  locale: "pl",
                                  timeFormat: 24,
                                  units: "metric",
                                      		ignoreModules: ["clock", "alert","Station_Gotha_18_März"],
                                      		mode: "slides",
                                      		slides: {
                                        			main: ["weather"],
                                        			"Slide 3": ["calendar", "compliments","MMM-PublicTransportHub"],
                                      		keyBindings: {
                                        			enabled: true,
                                        				map: {
                                          					Pause: "ArrowDown",
                                          					Slide0: "Home"
                                       		 mode: "DEFAULT"
                                          module: "alert"
                                          module: "weather",
                                              type: "forecast",
                                              lat: 50.9494849,
                                              lon: 10.7014435
                                          module: "weather",
                                              type: "current",
                                              lat: 50.9494849,
                                              lon: 10.7014435
                                  		header: "Forecast",
                                              	lang: "pl",
                                          module: "newsfeed",
                                              feeds: [
                              		module: 'clock',
                              			timeInFuture: 720,
                                              	stationName: "Gotha, Hauptbahnhof",
                                              	direction: "",
                                              	ignoredLines: [],
                                              	timeToStation: 10,
                              			carouselId: "Station_Gotha_18_März",
                              			timeInFutureMinutes: 720,
                              			updatesEvery: 60,
                              			maxDepartures: 12,
                              			timeToStation: 4,
                              			lineFilter: [],
                              			showDelay: false,
                              			showRemarks: true,
                              			fetchRetries: 1,
                                  		header: "Ansbach",
                              			updatesEvery: 60,
                              			maxDepartures: 12,
                              			timeToStation: 4,
                              			lineFilter: [],
                              			showDelay: false,
                              			showRemarks: true,
                              			fetchRetries: 1,
                                  		header: "Gotha, Hauptbahnhof",
                              			stationId: "de-DELFI_de:16067:8010136",
                              			updatesEvery: 60,
                              			maxDepartures: 12,
                              			timeToStation: 4,
                              			lineFilter: [],
                              			showDelay: false,
                              			showRemarks: true,
                              			fetchRetries: 1,
                              For Slide 3 and 4 I have no solution. Your module Hub understand carouselId only when i put it in ignoreModules list!
                              EDIT! I’ve found a solution : O to the carouselId!
                                      		mode: "slides",
                                      		slides: {
                                        			main: ["weather"],
                                        			"Slide 3": ["calendar", "compliments",{name: "MMM-PublicTransportHub", carouselId: "Station_Ansbach" }],
                              				"Slide 4": [{ name: "MMM-PublicTransportHub", carouselId: "Station_Gotha" }],
                                      		keyBindings: {
                                        			enabled: true,
                                        				map: {
                                          					Pause: "ArrowDown",
                                          					Slide0: "Home"
                                       		 mode: "DEFAULT"
                              dictionaries were the key. Sorry for my bad level of programming.
                              Still bad that hafas module is over. I liked design of hafas module much more.
                              Now everyhing is working on HUB module just like before it has been running on HAFASmodule (clock and main station is permanent on the screen on every slide and other modules and stations shows only with dedicated ones slides.) I like this combination. Still have not found a solution to UTF encoding in node.js query searching tool.
                                @Mati_93 Great, I’m glad you got the carousel setup working!
                                I don’t have a hot tip for the umlaut problem at the moment since I can’t reproduce it on my system.
                                You mentioned that you liked the design of the old HAFAS module more. What exactly do you prefer about it, and what is missing or different for you in MMM-PublicTransportHub? Maybe we can improve that :)
                                  @KristjanESPERANTO haha Kristjan, there in hafas was displayed important delay for each position if occured. To be honest sweet train and clock icons on the layout schedule were very nice for eyes. Im pretty sure station ID had been easier to find on HAFAS module too (more friendly IDs with less display problems)
                                    There, HAFAS displayed important delays for each departure.
                                    The module supports this, but Transitous apparently does not receive real-time data for your station. The open-source community is doing impressive work trying to collect real-time data wherever possible, but this is unfortunately difficult in some regions.
                                    HAFAS interfaces were never really intended for the kind of free use we make of them, and access is becoming more and more restricted. You could contact your local transport association and ask why they do not provide real-time data through an open API, preferably GTFS-RT. This would allow projects like Transitous, and therefore MMM-PublicTransportHub, to use it.
                                    The train and clock icons in the timetable looked very nice.
                                    That was already on my to-do list. I have now added a similar header to MMM-PublicTransportHub, so you only need to update the module.
                                    Station IDs were easier to find with the HAFAS module.
                                    Those IDs come from the provider, so there is not much I can change about their format. I actually prefer the Transitous IDs because they are real DHIDs and work globally.
                                    The display problem with umlauts is still a bit mysterious. The query scripts of both modules are not fundamentally very different, so I currently do not have a reliable explanation for why it only happens on your machine with the new query tool.
                                      @KristjanESPERANTO thanks a lot .
                                      Sorry I mean umlauts don’t work on both node run query (hafas and hub) but on the HAFAS module it had simply required less …less precise data and forgave the absence of umlauts. Output (results) were clearlier. On HAFAS I found my station (18 März Straße) by myself on December 2025, and on new hub module I needed your help .
