    digital photo frame
    34 Posts 15 Posters 38.6k Views 18 Watching
    • schlachtkreuzer6S Offline
      schlachtkreuzer6 @Labzz
      @Labzz I´m interested and i pulled a similar request days ago :P
        chrisfoerg @Labzz
        @Labzz is this not possible with dropbox and the possibility of showing local pictures?
        • 1m21 Offline
          1m2
          Haven’t tried but If dropbox can run on Pi, all you need is this module?
          https://forum.magicmirror.builders/topic/986/mmm-globe
            chrisfoerg @1m2
            @1m2 https://github.com/andreafabrizi/Dropbox-Uploader can also download
            • L Offline
              Labzz @chrisfoerg
              @chrisfoerg said in digital photo frame:
              download
              Sounds great indeed!
              • PatexP Offline
                Patex
                Maybe https://github.com/kapsolas/MMM-Flickr is suited for this task
                • O Offline
                  onetwankyfive
                  I use https://github.com/kapsolas/MMM-Instagram
                  with swapping the line
                  var media = items[i].images.low_resolution.url;
                  in node_helper.js with
                  var media = items[i].images.standard_resolution.url;
                  as well as the following in my custom css
                  img {
                  filter: grayscale(100%);
                  max-width:500px;
                  setup a seperate private instagram and give the login details to everyone in the house…
                  schlachtkreuzer6S 1 Reply Last reply Reply Quote 0
                    schlachtkreuzer6 @onetwankyfive
                    @onetwankyfive but instagram is crap… low resolution etc. etc. local would be super cool :)
                    PatexP 1 Reply Last reply Reply Quote -1
                    • PatexP Offline
                      Patex @schlachtkreuzer6
                      @schlachtkreuzer6 I created a picture module which loads pictures from a local folder and downscales them to show 1,2 or 4 of them at the same time. The issue being that electron crashes after some time due to being out of memory. The images have a very high resolution (3000 px) and if the 4 image layout is chosen actually 8 pictures are loaded at a time. Maybe time will tell if these issues can be fixed (http://stackoverflow.com/questions/27321997/how-to-request-the-garbage-collector-in-node-js-to-run).
                      schlachtkreuzer6S 1 Reply Last reply Reply Quote 1
                      • Mr.SpontiM Offline
                        Mr.Sponti
                        over the Chrismas days I’ve created a slideshow modul which is close to the functionality of a “digital photo frame”.
                        MMM-Photoshow
                        At startup the modul scans a local directory structure and creates a repository of the image files to display. At this point in time the module hide itself and waits on a command to start. The slideshow will start by a notification message from another modul, hides all other modules and shows the pictures in fullscreen mode. New pictures wil show up by a configurable time intervall. If the exif tag of the photo provides an information on the date taken, this date is shown in a footer line at the bottom of the screen. In addtion the footer line shows an album name, the number of photos of the album and the last received notification message (command to steer the show).
                        The slideshow is controlled by notification messages from a separate control modul. I’ve implemented a communication (socket io) to an external voice recognition modul based on snowboy. I think the modul (i.e alexyak/voicecontrol) would also work.
                        It is possible to switch between photo albums (represented by subdirectories of the loaded directory structure), to go forward , backward or to stop the photoshow by speaking a command.
                        It would be easy to modify the module with regular scans of the directory structure. There is already a command to reload the file structure during the run of the slideshow. Access to pictures on a remote server (i.e. NAS) works fine by mounting the remote folders into the local directory structure.
                        With the command ‘INFO_BOARD’ the slideshow stop, hide itselfs and switch back to info mode by showing up all other module.
                        I would be pleased if my modul can be used as a base for further development by a more experienced programmer like me.
                        schlachtkreuzer6S garblefluxG 2 Replies Last reply Reply Quote 2
                        • 1 / 4
