    digital photo frame
    34 Posts 15 Posters 43.6k Views 18 Watching
      1m2
      Haven’t tried but If dropbox can run on Pi, all you need is this module?
      https://forum.magicmirror.builders/topic/986/mmm-globe
        chrisfoerg @1m2
        @1m2 https://github.com/andreafabrizi/Dropbox-Uploader can also download
        • L
          Labzz @chrisfoerg
          @chrisfoerg said in digital photo frame:
          download
          Sounds great indeed!
          • PatexP
            Patex
            Maybe https://github.com/kapsolas/MMM-Flickr is suited for this task
            • O
              onetwankyfive
              I use https://github.com/kapsolas/MMM-Instagram
              with swapping the line
              var media = items[i].images.low_resolution.url;
              in node_helper.js with
              var media = items[i].images.standard_resolution.url;
              as well as the following in my custom css
              img {
              filter: grayscale(100%);
              max-width:500px;
              setup a seperate private instagram and give the login details to everyone in the house…
                schlachtkreuzer6 @onetwankyfive
                @onetwankyfive but instagram is crap… low resolution etc. etc. local would be super cool :)
                PatexP 1 Reply Last reply Reply Quote -1
                • PatexP
                  Patex @schlachtkreuzer6
                  @schlachtkreuzer6 I created a picture module which loads pictures from a local folder and downscales them to show 1,2 or 4 of them at the same time. The issue being that electron crashes after some time due to being out of memory. The images have a very high resolution (3000 px) and if the 4 image layout is chosen actually 8 pictures are loaded at a time. Maybe time will tell if these issues can be fixed (http://stackoverflow.com/questions/27321997/how-to-request-the-garbage-collector-in-node-js-to-run).
                    Mr.Sponti
                    over the Chrismas days I’ve created a slideshow modul which is close to the functionality of a “digital photo frame”.
                    MMM-Photoshow
                    At startup the modul scans a local directory structure and creates a repository of the image files to display. At this point in time the module hide itself and waits on a command to start. The slideshow will start by a notification message from another modul, hides all other modules and shows the pictures in fullscreen mode. New pictures wil show up by a configurable time intervall. If the exif tag of the photo provides an information on the date taken, this date is shown in a footer line at the bottom of the screen. In addtion the footer line shows an album name, the number of photos of the album and the last received notification message (command to steer the show).
                    The slideshow is controlled by notification messages from a separate control modul. I’ve implemented a communication (socket io) to an external voice recognition modul based on snowboy. I think the modul (i.e alexyak/voicecontrol) would also work.
                    It is possible to switch between photo albums (represented by subdirectories of the loaded directory structure), to go forward , backward or to stop the photoshow by speaking a command.
                    It would be easy to modify the module with regular scans of the directory structure. There is already a command to reload the file structure during the run of the slideshow. Access to pictures on a remote server (i.e. NAS) works fine by mounting the remote folders into the local directory structure.
                    With the command ‘INFO_BOARD’ the slideshow stop, hide itselfs and switch back to info mode by showing up all other module.
                    I would be pleased if my modul can be used as a base for further development by a more experienced programmer like me.
                    S garblefluxG 2 Replies Last reply Reply Quote 2
                      schlachtkreuzer6 @Patex
                      @Patex cool! i hope you will figure that out soon :)
                        schlachtkreuzer6 @Mr.Sponti
                        @Mr.Sponti sounds great :) I´ll see if I can use the code (still need to get better at coding at all…) :smiley:
                          roramirez Core Contributors
                          I just publish another module for show images from a directory. The idea was checking process of module development.
                          If anybody have ideas or new features to add please add issue into the Github.
                          https://github.com/roramirez/MMM-ImagesPhotos.git
                          S L 2 Replies Last reply Reply Quote 1
                            schlachtkreuzer6 @roramirez
                            @roramirez Super cool! thanks :)
                            • L
                              Labzz @roramirez
                              @roramirez
                              Wow well done ! But if i understand the module correctly it will show pictures from the var urlApHelper = “/MMM-ImagesPhotos/photos” directory?
                              Is it possible to add a feature that grab the images from dropbox or simulair?
                              ~Edit: maybe a local website, or mobile application to upload pictures is earier to setup? ~
                              Hope to hear you soon!
                              C R 2 Replies Last reply Reply Quote 0
                                chrisfoerg @Labzz
                                @Labzz you can set a ln -s between your dropbox and the modules folder
                                  roramirez Core Contributors @Labzz
                                  @Labzz the /MMM-ImagesPhotos/photos is a backend endpoint for get content from upload directory used by module. You can synchronize the your DropBox folder in upload directory.
                                  • garblefluxG
                                    garbleflux Project Sponsor @Mr.Sponti
                                    @Mr.Sponti
                                    I’m also looking for a solution to make the mirror to a photo frame. Is it maybe
                                    possible to use with your module a picture viewer like “feh”? Up to now I’m useing
                                    feh to show my HD-Photos on a large TV. The best would be to have a hardwareswitch (or a voice command) to chanced between photoshow and the
                                    infos an the mirror. Has anyone an idea?
                                    Unfortunatelly I have no experience in programming.
                                    • N
                                      nobita @roramirez
                                      @roramirez you can change or modify your module pull photo from dropbox (replace from folder) . I mean more detail in programming for apply in mirror project v2.1
                                      Thanks for your kind
                                        roramirez Core Contributors @nobita
                                        @nobita said in digital photo frame:
                                        What? Why you dont synchronize your Dropbox folder into the upload directory of the module ?
                                        If you can help this feature to pull directly from DropBox the Pull request are welcome ;)
                                          soqueen
                                          I am extremely interested in this as well. In fact, I just posted about this very thing elsewhere in this forum. Question- OpenFrame and Canviz (openframe is on github, canviz software you can download for free) do what I want. Is there a way to incorporate them into the same pi, or somehow use them as modules on the mm? I want to run the mm with all the info for certain parts of the day and then use it the rest of the day as a digital art display for my artist daughter’s artwork.
                                            schlachtkreuzer6 @soqueen
                                            @soqueen to change the modules per time, you can use this: https://github.com/ianperrin/MMM-ModuleScheduler
