V2.0.X Updates
Scheduled Pinned Locked Moved MagicMirror
5 Posts 1 Posters 6.4k Views 6 Watching
    MichMich Admin
    I’ve just pushed V2.0.1 to stable.
    https://github.com/MichMich/MagicMirror/releases/tag/v2.0.1
    [2.0.1] - 2016-05-18
    Added
    • Changelog
    • Italian Translation
    Changed
    • Improve the installer by fetching the latest Node.js without any 3rd party interferences.
      MichMich Admin
      I’ve just pushed V2.0.2 to stable.
      https://github.com/MichMich/MagicMirror/releases/tag/v2.0.2
      [2.0.2] - 2016-06-05
      Added
      • Norwegian Translations (nb and nn)
      • Portuguese Translation
      • Swedish Translation
      Fixed
      • Added reference to Italian Translation.
      • Added the missing NE translation to all languages. #334
      • Added proper User-Agent string to calendar call.
      Changed
      • Add option to use locationID in weather modules.
        MichMich Admin
        A new version just rolled of the press … v2.0.3
        https://github.com/MichMich/MagicMirror/releases/tag/v2.0.3
        [2.0.3] - 2016-07-12
        Added
        • Add max newsitems parameter to the newsfeed module.
        • Translations for Simplified Chinese, Traditional Chinese and Japanese.
        • Polish Translation
        • Add an analog clock in addition to the digital one.
        Fixed
        • Edit Alert Module to display title & message if they are provided in the notification (Issue #300)
        • Removed ‘null’ reference from updateModuleContent(). This fixes recent Edge and Internet Explorer browser displays (Issue #319)
        Changed
        • Added default string to calendar titleReplace.
          MichMich Admin
          There it is, the next release: v2.0.4
          https://github.com/MichMich/MagicMirror/releases/tag/v2.0.4
          [2.0.4] - 2016-08-07
          Added
          • Brazilian Portuguese Translation.
          • Option to enable Kios mode.
          • Added ability to start the app with Dev Tools.
          • Added ability to turn off the date display in clock.js when in analog mode.
          • Greek Translation
          Fixed
          • Prevent getModules() selectors from returning duplicate entries.
          • Append endpoints of weather modules with / to retreive the correct data. (Issue #337)
          • Corrected grammer in module.js from ‘suspend’ to ‘suspended’.
          • Fixed openweathermap.org URL in config sample.
          • Prevent currentweather module from crashing when received data object is incorrect.
          • Fix issue where translation loading prevented the UI start-up when the language was set to ‘en’. (Issue #388)
          Updated
          • Updated package.json to fix possible vulnerabilities. (Using Snyk)
          • Updated weathericons
          • Updated default weatherforecast to work with the new icons.
          • More detailed error message in case config file couldn’t be loaded.
            MichMich Admin
            Wait no longer. The next update is here: v2.0.5
            https://github.com/MichMich/MagicMirror/releases/tag/v2.0.5
            [2.0.5] - 2016-09-20
            Added
            • Added ability to remove tags from the beginning or end of newsfeed items in ‘newsfeed.js’.
            • Added ability to define “the day after tomorrow” for calendar events (Definition for German and Dutch already included).
            • Added CII Badge (we are compliant with the CII Best Practices)
            • Add support for doing http basic auth when loading calendars
            • Add the abilty to turn off and on the date display in the Clock Module
            Fixed
            • Fix typo in installer.
            • Add message to unsupported Pi error to mention that Pi Zeros must use server only mode, as ARMv6 is unsupported. Closes #374.
            • Fix API url for weather API.
            Updated
            • Force fullscreen when kioskmode is active.
            • Update the .github templates and information with more modern information.
            • Update the Gruntfile with a more functional StyleLint implementation.
