    ipWhitelist HowTo
    83 Posts 36 Posters 162.8k Views 34 Watching
    • T
      toonazd @mochman
      @mochman thanks topman been trying to get this back up and running
        mochman Module Developer @looolz
        @looolz When you run the mirror through VNC. If you leave the terminal open then try to open the mirror on your other computer, do you see the
        “This device is not allowed to access your mirror.
        Please check your config.js or config.js.sample to change this.”
        message? If so, does anything pop up in your terminal?
        Another thing to look at, if you run ifconfig and take a look at your wlan0 (assuming you are using wifi to get internet) do you see a “inet6 addr:”? If not, just try adding "10.0.0.95" to the whitelist.
        L O 2 Replies Last reply
          A way to tell if you need to use "::ffff:192.168.1.120" or just "192.168.1.120"
          Run netstat -lnpt, if you see something like:
          tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN 1271/electron.js
          Then you are using IPv4 and should add "YO.UR.IP.AD" or "YO.UR.IP.AD/24" to the whitelist.
          If you see: tcp6 0 0 :::8080 :::* LISTEN 1170/electron.js
          You are using IPv6 address schemas and need to add "::ffff:YO.UR.IP.AD" or "::ffff:YO.UR.IP.AD/120" to the whitelist.
          If you have IPv6 and want to turn it off, add ipv6.disable=1 to your /boot/cmdline.txt and restart your pi.
          Reply Quote 2
          • X
            xer0design
            Not a fan of this addition; would have rathered it was something you enable rather than disable.
            For anyone wondering how to allow all ips, use:
            ipWhitelist: ["::fff:0.0.0.0/1", "::fff:128.0.0.0/2", "::fff:192.0.0.0/3", "::fff:224.0.0.0/4", "127.0.0.1", "::ffff:127.0.0.1", "::1"],
            L S 2 Replies Last reply
            Reply Quote 3
            • L
              looolz @xer0design
              @xer0design
              Thanks! That worked for me!
              • L
                looolz @mochman
                @mochman
                Thanks, I do see a inet6 address with the command ifconfig.
                I tried to add 10.0.0.95 to the config with no success :-(
                But @xer0design’s tip worked!
                  schlachtkreuzer6 @xer0design
                  @xer0design verry nice thx!
                    BenRoe Module Developer
                    • A
                      AAPS @mochman
                      @mochman I have put “/24” in my ipWhitelist. Looking around the forum, I’ve seen that “/120” might help. What I have now seems to be working for my devices, so is there a difference between “/24” and “/120” that I should know about? Which is better?
                      M 1 Reply Last reply
                        mochman Module Developer @AAPS
                        @AAPS If /24 is working for you then stick with it. The /120 just allows less IPs the ability to access your mirror.
                        If you aren’t forwarding your pi’s ports outside your local network it really shouldn’t matter.
                        • SnilleS
                          Snille Module Developer
                          Hi all, anybody else having trouble accessing the mirror remotely? I have reinstalled mm (development branch and nodejs v7.7.3), default config. only added allow access from my “lan”.
                          The mirror shows up on the local screen, so it works.
                          Mirrors IP: 10.0.0.112/24
                          ipWhitelist: ["::ffff:10.0.0.1/120", "127.0.0.1", "::ffff:127.0.0.1", "::1"],
                          Still I get
                          0|mm       | Access denied to IP address: 10.0.0.99
                          In the log.
                          My client IP: 10.0.0.99/24
                          Just to be sure, here is my full config:
                          /* Magic Mirror Config Sample
                           * MIT Licensed.
                          var config = {
                          	port: 8080,
                          	language: "en",
                          	timeFormat: 24,
                          	units: "metric",
                          			module: "alert",
                          			module: "updatenotification",
                          			position: "top_bar"
                          			module: "clock",
                          			position: "top_left"
                          			header: "US Holidays",
                          						symbol: "calendar-check-o ",
                          			module: "compliments",
                          			position: "lower_third"
                          			module: "currentweather",
                          				locationID: "",  //ID from http://www.openweathermap.org
                          			module: "weatherforecast",
                          			header: "Weather Forecast",
                          				locationID: "5128581",  //ID from http://www.openweathermap.org
                          			module: "newsfeed",
                          			position: "bottom_bar",
                          				feeds: [
                          						title: "New York Times",
                          				showSourceTitle: true,
                          				showPublishDate: true
                          Everything is default, no modules installed… What am I missing?!
                            Have you tried adding "10.0.0.1/24" to the list since it looks like your client is using an IPv4 connection?
                            SnilleS 1 Reply Last reply
                            • SnilleS
                              Snille Module Developer @mochman
                              @mochman Hmm… Clearly I have missunderstood something. I thought this: “::ffff:10.0.0.1/120” was to allow my 10.0.0.x network to access, I have used that from the beginning and it has worked. But yesterday it stopped working. So I added as you suggested “10.0.0.1/24” and it works… So, Thank you! :)
                              In the instructions in the first post, it’s suppose to be “::ffff:10.0.0.1/120” for a full C-Net. But… Not any more obviously. :)
                              Thanks again! I’m all happy now!
                                It looks like your raspberry pi started using IPv4 instead of IPv6. the ::ffff: before your ip shows that it’s trying to use a IPv6. That’s where "::ffff:10.0.0.1/120" was working. Seems like something changed though that it’s now using the IPv4 address.
                                So to cover all your bases, keep both "::ffff:10.0.0.1/120" and "10.0.0.1/24" in and you shouldn’t run into this problem again.
                                • SnilleS
                                  @mochman Will do, thank you, no idea what changed the behavior. :) But at least I have a totally fresh install now! :)
                                    pepemujica
                                    Hi @mochman !! I can access from the same device where I run the MM, but can’t access from external devices (smartphone ie)
                                    Any idea why?
                                    Kind regards
                                      Is the smartphone on your wifi? If it is, just follow the steps to add your whole subnet.
                                      If you’re trying to access it while using the phone’s network, that’s going to be harder. You’re going to have to configure your router to allow port forwarding to your pi, then figure out what your phones IP is. Then you could be safe and only allow that IP. The problem with that is when your IP changes, you’ll have to edit your whitelist again. You could try to add the class C or D subnet if you don’t want to worry too much about this, but you’ll be opening up your network to the internet in the process so good luck!
                                      P 1 Reply Last reply
                                        pepemujica @mochman
                                        @mochman Yes, it is in the same network, also I’ve tried sharing internet from my smartphone, and nothing.
                                        Which steps should I follow?
                                          Please follow the steps outlined at the top of this page. Let me know what you’re seeing when you do those steps.
                                            pepemujica @mochman
                                            @mochman It’s working! Thanks!
                                            • 1 / 5
