    ipWhitelist HowTo
    83 Posts 36 Posters 162.7k Views 34 Watching
      mochman Module Developer @AAPS
      @AAPS If /24 is working for you then stick with it. The /120 just allows less IPs the ability to access your mirror.
      If you aren’t forwarding your pi’s ports outside your local network it really shouldn’t matter.
      • SnilleS
        Snille Module Developer
        Hi all, anybody else having trouble accessing the mirror remotely? I have reinstalled mm (development branch and nodejs v7.7.3), default config. only added allow access from my “lan”.
        The mirror shows up on the local screen, so it works.
        Mirrors IP: 10.0.0.112/24
        ipWhitelist: ["::ffff:10.0.0.1/120", "127.0.0.1", "::ffff:127.0.0.1", "::1"],
        Still I get
        0|mm       | Access denied to IP address: 10.0.0.99
        In the log.
        My client IP: 10.0.0.99/24
        Just to be sure, here is my full config:
        /* Magic Mirror Config Sample
         * MIT Licensed.
        var config = {
        	port: 8080,
        	language: "en",
        	timeFormat: 24,
        	units: "metric",
        			module: "alert",
        			module: "updatenotification",
        			position: "top_bar"
        			module: "clock",
        			position: "top_left"
        			header: "US Holidays",
        						symbol: "calendar-check-o ",
        			module: "compliments",
        			position: "lower_third"
        			module: "currentweather",
        				locationID: "",  //ID from http://www.openweathermap.org
        			module: "weatherforecast",
        			header: "Weather Forecast",
        				locationID: "5128581",  //ID from http://www.openweathermap.org
        			module: "newsfeed",
        			position: "bottom_bar",
        				feeds: [
        						title: "New York Times",
        				showSourceTitle: true,
        				showPublishDate: true
        Everything is default, no modules installed… What am I missing?!
          Have you tried adding "10.0.0.1/24" to the list since it looks like your client is using an IPv4 connection?
          SnilleS 1 Reply Last reply
          • SnilleS
            Snille Module Developer @mochman
            @mochman Hmm… Clearly I have missunderstood something. I thought this: “::ffff:10.0.0.1/120” was to allow my 10.0.0.x network to access, I have used that from the beginning and it has worked. But yesterday it stopped working. So I added as you suggested “10.0.0.1/24” and it works… So, Thank you! :)
            In the instructions in the first post, it’s suppose to be “::ffff:10.0.0.1/120” for a full C-Net. But… Not any more obviously. :)
            Thanks again! I’m all happy now!
              It looks like your raspberry pi started using IPv4 instead of IPv6. the ::ffff: before your ip shows that it’s trying to use a IPv6. That’s where "::ffff:10.0.0.1/120" was working. Seems like something changed though that it’s now using the IPv4 address.
              So to cover all your bases, keep both "::ffff:10.0.0.1/120" and "10.0.0.1/24" in and you shouldn’t run into this problem again.
              • SnilleS
                @mochman Will do, thank you, no idea what changed the behavior. :) But at least I have a totally fresh install now! :)
                  pepemujica
                  Hi @mochman !! I can access from the same device where I run the MM, but can’t access from external devices (smartphone ie)
                  Any idea why?
                  Kind regards
                    Is the smartphone on your wifi? If it is, just follow the steps to add your whole subnet.
                    If you’re trying to access it while using the phone’s network, that’s going to be harder. You’re going to have to configure your router to allow port forwarding to your pi, then figure out what your phones IP is. Then you could be safe and only allow that IP. The problem with that is when your IP changes, you’ll have to edit your whitelist again. You could try to add the class C or D subnet if you don’t want to worry too much about this, but you’ll be opening up your network to the internet in the process so good luck!
                    P 1 Reply Last reply
                      pepemujica @mochman
                      @mochman Yes, it is in the same network, also I’ve tried sharing internet from my smartphone, and nothing.
                      Which steps should I follow?
                        Please follow the steps outlined at the top of this page. Let me know what you’re seeing when you do those steps.
                          pepemujica @mochman
                          @mochman It’s working! Thanks!
                            Mitchfarino Module Developer
                            The default of [] doesn’t work at all for me. I’m happy to let all devices on my network access my mirror, how do I do this?
                            It’s not the simplest of features is it!
                            Hoping someone can help me here :/
                            R 1 Reply Last reply
                              roramirez Core Contributors @Mitchfarino
                              @Mitchfarino Are you sure?, Can you show the config/config.js ?
                              There some logs when did you run and access it?
                                I’m just at work at the moment, so I’ll post my config when I get home.
                                When I leave it as it originally was in the config, the mirror loads but I can’t get MMM-RemoteControl to work as it gives me the permission error
                                Then when I replace it with [] it fails to load the mirror and tells me to create a config.js file
                                • T
                                  twosix
                                  The remoter control module is not working for me to any extent, when I whitelist the IPs for my school’s wifi (following the HowToWhitelistIP thread’s directions) in every way stated, I get the “this device is not allowed to access…” message. Then, when I allow all IPs access I get the “cannot get remote/html” message. Any help would be great! Thanks!
                                  • rudibaraniR
                                    rudibarani Project Sponsor @mochman
                                    Hi @mochman,
                                    I was wondering, if the whitelist could be used to limit the access to different MM sub-sites? I would like to have the MM screen itself open to a larger set of IP addresses but would like to lock down the MMM-RemoteControl & MMM-AdminInterface sites and limit access to my own devices.
                                    Any idea how to achieve this?
                                    Thanks for your advice!
                                    • cowboysdudeC
                                      It helps to read a little…
                                      http://searchsecurity.techtarget.com/definition/application-whitelisting
                                      +| ipWhitelist | The list of IPs from which you are allowed to access the MagicMirror². The default value is ["127.0.0.1", "::ffff:127.0.0.1", "::1"]. It is possible to specify IPs with subnet masks (["127.0.0.1", "127.0.0.1/24"]) or define ip ranges (["127.0.0.1", ["192.168.0.1", "192.168.0.100"]]). Set [] to allow all IP addresses. For more information about how configure this directive see the follow post ipWhitelist HowTo |
                                      rudibaraniR R 2 Replies Last reply
                                      Reply Quote 2
                                      • rudibaraniR
                                        rudibarani Project Sponsor @cowboysdude
                                        @cowboysdude Thanks for your reply. My white Lists work fine for the MM2 screen. I was looking for a way to separately limit access to the sites generated by the Remote Control and Admin interface module. Any ideas?
                                        • cowboysdudeC
                                          cowboysdude Module Developer @rudibarani
                                          @rudibarani said in ipWhitelist HowTo:
                                          Honestly the best thing to do is ask the creator of those modules ;) I don’t do the ipWhitelist.
                                            roblocksrocks @cowboysdude
                                            @cowboysdude Maybe you’ll be able to help, I’ve tried doing [ ], I’ve tried whitelesting all IPs as shown in here, and the only thing I have been able to get to work is whitelisting specific IPV4 and IPV6 addresses. That was fine because my most used devices have static IPs anyway however the issue comes now that I have port forwarding and am trying to open it up to any IP (I am aware of the security ramifications)
                                            • 2 / 5
