Listen for calender on port 5005
3 Posts 2 Posters 1.7k Views 2 Watching
    Axelito
    Hi everybody,
    I am running a MM on my Raspi3 and an old Notebook LCD. Everything is working fine except a small problem with the calendar module: I would like to implement my own calendar from an .ics hosted by my synology server. Since now it does not work, I think because of port 5005 used by my server. Is there a way to use my own .ics file this way?
    Thank you in advance!
      paviro Admin
      http://server.local:5005/calendar.ics?
      – The Doctor
        Axelito
        @paviro Thanks a lot! I actually tried your solution before but it did not work. After your post I was sure it had to work somehow and I was able to solve my problem. My mistake was to leave out / to wrongly implement username and password.
        With http://username:password@server.local:5005/calendar.ics everything is working perfectly fine.
