calendar: different spaces between symbol and text when different sources used
7 Posts 2 Posters 3.6k Views 1 Watching
    strizl
    Hi all!
    First of all thanks to Michael and his helping hands for the great magicmirror project. I really love it and I think it’s all together a technical and optical highlight!
    I have some little troubles with the calendar module. It’s not a real bug - it’s more an optical and design problem:
    The first calender I added is a public Apple iCloud calendar from my account (webcal://p13-calendars.icloud.com/published/…) named “Familie”
    The second one is an iCalendar feed from the university I attend (http://portal.fh-campuswien.ac.at/calendar/feed/…) named “FH Campus Wien”
    Everything is working fine and I get the correct appointments. But the iCloud calender has beginning blanks. Please take a look at the attached screenshots.
    0_1486390341425_upload-7b1f47a0-b16c-449b-bead-d634412031ca
    The interessting thing is, with every refresh or browser restart there are sometimes more, sometimes less blanks. I don’t know where they are comming from. They are not in the appointment created in iCloud or iPhone. I also created a second calender on iCloud, but the result is the same.
    Does anyone have any ideas? What can I look for?
    Please take a look at my config:
    Platform: Pi Zero
    Node Version [ 0.12.13 or later ]: 4.2.1
    MagicMirror Version [ V1 / V2-Beta ]: v2
    Browser: Chromium Version 51.0.2704.91 Built on Ubuntu 14.04, running on Raspbian 8.0
    Thanks a lot!!
    Kind regards,
    Dominik
      broberg Project Sponsor
      I’m wondering, since the lower calender has a “full” title, is it a spacing issue?
      I.e when there is a long title it is force to take up all space and when it’s a short title it gets more space?
        strizl
        Hi broberg!
        100 points!! - great work - you’re absolutly right!
        Thank you!!
        I added an appointment with the same text - pls take a look:
        0_1486403997611_upload-7b23495a-dbd4-4e53-9659-be875ca2b366
        Any idea how I can fix this? Maybe editing a css-File with “alignment-left”?
        Thanks a lot!
        Kind regards,
        Dominik
          Try adding
          .calendar .symbol {width: 20px;}
          .calender .time {width: 50px;}
          To the custom.css
            strizl
            Do you mean this way?
             body {
            Sadly it’s not working this way…
            Any other idea?
            Thanks a lot for your time, broberg!!
            Kind regards,
            Dominik
            B 1 Reply Last reply Feb 6, 2017, 7:18 PM Reply Quote 0
              broberg Project Sponsor @strizl
              @strizl no, not inside the body {}
              you could try increasing the size to see a more clear effect
                strizl
                Hi broberg!
                Thanks again for your help!
                It’s working now. It was only due to the vnc viewer connection - this caused a space or resolution error. On the TFT screen everything’s fine!
                But good to know where I can play with the CSS options…
                Thanks again and kind regards,
                Dominik
