    Help with config file
    5 Posts 3 Posters 2.6k Views 3 Watching
      sullivnc
      Can anyone tell me what I did wrong with my config file? Anywhere you see ### is where I removed personal data.
      var config = {
              port: 8080,
              language: "en",
              timeFormat: 12,
              units: "imperial",
                              module: "clock",
                              position: "top_left'"
                                      timeFormat: 12,
                                      displaySeconds: true,
                                      showPeriod: true,
                                      showDate: true,
                                      displayType: "digital",
                                      timezone: "America/New_York",
                                                      symbol: "calendar-check-o ",
                                                      url: "###"
                              module: "compliments",
                              position: "lower_third"
                              module: "currentweather",
                                      locationID: "###",  //ID from http://www.openweathermap.org
                                      appid: "###",
                                      roundTemp: true,
                                      showPeriod: true,
                                      showPeriodUpper: true,
                                     showHumidity: true,
                              module: "weatherforecast",
                              header: "Weather Forecast",
                                      appid: "###",
                                      roundTemp: true,
                                      showRainAmount: true,
                                      colored: trtue,
                              module: "newsfeed",
                              position: "bottom_bar",
                                      feeds: [
                                                      title: "The Atlantic",
                                                      url: "https://www.theatlantic.com/feed/best-of/",
                                                      title: "BBC World",
                                                     url: "feeds.bbci.co.uk/news/world/rss.xml",
                                      showSourceTitle: true,
                                      showPublishDate: true,
                                      showDescription: true,
      AlvingerA 1 Reply Last reply Reply Quote 0
      • AlvingerA Offline
        Alvinger @sullivnc
        @sullivnc
        There is a curly brace missing in the config field of the clock module.
        • cowboysdudeC Offline
          Like this :)
                                  module: "clock",
                                          timeFormat: 12,
                                          showPeriod: true,
                                          showDate: true,
          • AlvingerA Offline
            Alvinger
            The position line for the clock module is also wrong, it should be like this:
            I recommend that you use a lint tool (e.g. eslint) to do syntax checking. It will find most of the errors.
              sullivnc
              Thanks guys, appreciate the help.
