    Need help to install the first new module to the mirror ...
    8 Posts 4 Posters 4.0k Views 4 Watching
      MyMirror
      Re: [MMM-SystemStats (cpu temp/load](fre ram …))
      i’m really new to MagicMirror. May i ask for some help?
      I’ve got to mirror running in the basic version and i haven’t installed any other module yet.
      So my questions:
      What do i have to download, copy or … from here?
      Means : in which dir do i have to start what kind of command?
      And : with sudo or as normal “pi”?
      Where do i found the new module?
      And what/where do i have to customize something?
      I’ll think that this is a nice short and manageable module, or?
      And i hope, i can transfer these steps to other modules.
      Thanks for helping a newcomer!!
      • yawnsY Offline
        yawns Moderator
        Welcome to our community.
        The module has a very complete readme, please take a look here:
        https://github.com/BenRoe/MMM-SystemStats/blob/master/README.md
          MyMirror
          Thanks … i’ll read it :-)
            MyMirror @MyMirror
            @yawns
            First step - first Problem :-(
            When i install async i’ll get following:
            npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@-0.4.0 but none was installed.
            I’ve ignored this warning, and get new contend on my mirror.
            CPU Temp/System Load/Free RAM : all “fetching” but no content
            Where is my fault?
            Greets
            slametpsS 1 Reply Last reply Reply Quote 0
            • slametpsS Offline
              slametps @MyMirror
              @MyMirror said in Need help to install the first new module to the mirror ...:
              @yawns
              Where is my fault?
              Greets
              all you have to do before run the module:
              // Navigate to the new MMM-SystemStats folder and install the node dependencies.
              npm install
              // restart mm
              regards,
              Slamet PS
                MyMirror @slametps
                @slametps
                Yes, thanks - the error has gone.
                So i have to do npm install once and as a first step for every new module
                But i didn’t have any values for CPU, RAM and Load …
                Do you have an idea?
                • slametpsS Offline
                  slametps @MyMirror
                  @slametps
                  Not every module required npm install. Pls refer to each module documentation.
                  Please execute the following commands on your raspi shell (refer to node_helper.js of MMM-SystemStats):
                  /opt/vc/bin/vcgencmd measure_temp
                  cat /proc/loadavg
                  free | awk '/^Mem:/ {print $4*100/$2}'
                  all commands output something? If there are, pls check the mm-log or browser console-log.
                  regards,
                  Slamet PS
                  • cowboysdudeC Offline
                    I have found that I need to slow down and read the entire readme… many modules require “npm install”… that right there is more than 1/2 of the errors ;)
                    I’m so glad you came to ask for help! I know it’s hard to do at times… I know myself I have an extremely difficult time asking for help…
                    BUT just remember when you’re new at this go slow… take your time :) If you get into trouble just ask. HUGE suggestion… when you have a working config.js you should make a copy of it before you change anything in it… that way if you get into trouble you have a backup that you know works!
                    Easy in a terminal window:
                    ~MagicMirror/config
                    cp config.js config.bak
                    That’s all there is to it! :) Then you’re safe!
