    MMM-Traffic config error
    9 Posts 3 Posters 5.3k Views 4 Watching
      bocapie
      Hello I am new to Magic Mirror.
      I can get my mirror to work with the
      default modules. I am running his
      example config. with my api key from
      google. I am making sure all my settings
      match in the MMM-Traffic.js file.
      If I could see someone else working
      config file. I could see where I am
      going wrong. Thank in advance
      for the help.
      • L
        lolobyte @bocapie
        @bocapie
        Hi, that’s a part of my config.js with the trafic module for you as an example.
                                "module": "MMM-Traffic",
                                "position": "top_left",
                                "header": "YourHeaderName",
                                "classes": "bright small",
                                "config": {
                                        "api_key": "xxxxxxxxxYourApiKeyxxxxxxxxxx",
                                        "mode": "driving",
                                        "language": "de",
                                        "show_summary": "true",
                                        "origin": "YourStartLocation",
                                        "destination": "YourDestinationLocation",
                                        "arrival_time": "0700",
                                        "route_name": "YourRouteName",
                                        "changeColor": true,
                                        "showGreen": false,
                                        "limitYellow": 5,
                                        "limitRed": 20,
                                        "traffic_model": "pessimistic",
                                        "interval": 120000
          bocapie
          Thank you for that I figured out where I messed up. It loads now but, just says loading commute… now.
            bocapie
            Quick question on apikey and origin,destination. Do I need to put them in both the config.js and module MMM-Traffic.js file?
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @bocapie
              @bocapie no only in the config file.
              Everything you put in the config file will overwrite the values in the module
                bocapie @strawberry 3.141
                @strawberry-3.141 okay, I ran a npm start dev and get a error
                Error: ENOENT, open "/home/pi/MagicMirror/node_modules/dev/package.json
                • strawberry 3.141S
                  @bocapie you are in the wrong directory do cd ~/MagicMirror first
                    @strawberry-3.141 Yes I am in that directory.
                      bocapie
                      I think i figured it out. Debug says my node is out of date.
