    Modules to display Stock (Capital Stock)
    13 Posts 4 Posters 12.5k Views 4 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @qqqqqqqq
      @qqqqqqqq
      first module
                  module: 'MMM-Stock',
                  position: 'top_right',
                      companies: ['MSFT', 'GOOG', 'ORCL', 'FB'],
                      currency: 'gbp'
      second module: you have to rename the folder to stocks, as you mentioned the directory and the js file and inside the js file the name has to be the same.
      third: create an issue on github and ask if he creates a list as config option
      Q 1 Reply Last reply
      Reply Quote 2
      • Q
        qqqqqqqq @strawberry 3.141
        @strawberry-3.141
        I’ve already tried this. Did it work for you?
        • strawberry 3.141S
          @qqqqqqqq yes its working for me, but its not documented in the readme that you have to install npm install request in the module directory
          • Q
            @strawberry-3.141
            @strawberry-3.141 said in Modules to display Stock (Capital Stock):
            Do i have to run that command? From the modules folder?
            • strawberry 3.141S
              @qqqqqqqq cd ~/MagicMirror/modules/MMM-Stock then the command above
              The second module does also not tell about installing the request dependency
              • Q
                qqqqqqqq
                The first module works, maybe I was doing something wrong. :/
                Does it take forever to load for you too?
                • Q
                  What do I make of this?
                  pi@raspberrypi:~/MagicMirror/modules $ npm install request
                  /home/pi/MagicMirror/modules
                  `-- request@2.79.0
                    +-- aws-sign2@0.6.0
                    +-- aws4@1.6.0
                    +-- caseless@0.11.0
                    +-- combined-stream@1.0.5
                    | `-- delayed-stream@1.0.0
                    +-- extend@3.0.0
                    +-- forever-agent@0.6.1
                    +-- form-data@2.1.2
                    | `-- asynckit@0.4.0
                    +-- har-validator@2.0.6
                    | +-- chalk@1.1.3
                    | | +-- ansi-styles@2.2.1
                    | | +-- escape-string-regexp@1.0.5
                    | | +-- has-ansi@2.0.0
                    | | | `-- ansi-regex@2.1.1
                    | | +-- strip-ansi@3.0.1
                    | | `-- supports-color@2.0.0
                    | +-- commander@2.9.0
                    | | `-- graceful-readlink@1.0.1
                    | +-- is-my-json-valid@2.15.0
                    | | +-- generate-function@2.0.0
                    | | +-- generate-object-property@1.2.0
                    | | | `-- is-property@1.0.2
                    | | +-- jsonpointer@4.0.1
                    | | `-- xtend@4.0.1
                    | `-- pinkie-promise@2.0.1
                    |   `-- pinkie@2.0.4
                    +-- hawk@3.1.3
                    | +-- boom@2.10.1
                    | +-- cryptiles@2.0.5
                    | +-- hoek@2.16.3
                    | `-- sntp@1.0.9
                    +-- http-signature@1.1.1
                    | +-- assert-plus@0.2.0
                    | +-- jsprim@1.3.1
                    | | +-- extsprintf@1.0.2
                    | | +-- json-schema@0.2.3
                    | | `-- verror@1.3.6
                    | `-- sshpk@1.10.2
                    |   +-- asn1@0.2.3
                    |   +-- assert-plus@1.0.0
                    |   +-- bcrypt-pbkdf@1.0.1
                    |   +-- dashdash@1.14.1
                    |   | `-- assert-plus@1.0.0
                    |   +-- ecc-jsbn@0.1.1
                    |   +-- getpass@0.1.6
                    |   +-- jodid25519@1.0.2
                    |   +-- jsbn@0.1.1
                    |   `-- tweetnacl@0.14.5
                    +-- is-typedarray@1.0.0
                    +-- isstream@0.1.2
                    +-- json-stringify-safe@5.0.1
                    +-- mime-types@2.1.14
                    | `-- mime-db@1.26.0
                    +-- oauth-sign@0.8.2
                    +-- qs@6.3.1
                    +-- stringstream@0.0.5
                    +-- tough-cookie@2.3.2
                    | `-- punycode@1.4.1
                    +-- tunnel-agent@0.4.3
                    `-- uuid@3.0.1
                  npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
                  npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/package.json'
                  npm WARN modules No description
                  npm WARN modules No repository field.
                  npm WARN modules No README data
                  npm WARN modules No license field.
                  strawberry 3.141S Y 2 Replies Last reply
                  • strawberry 3.141S
                    @qqqqqqqq you can ignore these warnings
                    • Y
                      Yurick
                      3rd module with google finance works for me just fine, all you need it to find the correct ticker. For currency try “CURRENCY:EURUSD”, for commodities unfortunately you will need to find some substitute. You can try “NYSEARCA: USO” or “NYSEARCA: BNO” in case of crude oil.
                      • Y
                        yawns Moderator @qqqqqqqq
                        @qqqqqqqq
                        You are in the modules base folder, but you need to change into the specific module folder instead
                        • Q
                          qqqqqqqq @Yurick
                          @Yurick
                          3rd works for me too. And, thanks for your help, I’ve added currency in in too.
                          I got it to display it as static list by modifying the .js file as below. I’ve modified the line 26 from this
                                  var wrapper = document.createElement("marquee");
                          to this
                          And line 62
                          from
                                              divider.innerHTML = '  •  ';
                          to
                                              divider.innerHTML = '<br>';
                          • Q
                            qqqqqqqq
                            This is how they look right now.
                            Can someone please help me change the font style/size, since they look a little big compared to the others.
                            how do I change the brightness of a specific module?
                            I know, both has to be done using the custom.css but how?
