    MMM-Swipe - Sensor
    10 Posts 4 Posters 6.2k Views 3 Watching
      sero
      This looks great! Thanks for sharing the module @mochman :)
      How do you plan to integrate the sensors in the housing of your mirror? I guess it’s not possible to cover them with glass or plastic, right?
      • mochmanM Offline
        mochman Module Developer
        No, but I did test it behind a mesh speaker screen. They work just fine behind that, so I’ll just mount them where I mount the speakers.
        • MitchfarinoM Offline
          Mitchfarino Module Developer
          Could you post the finished “product” wired up?
          Just wanting to visualise how it would look.
          Fantastic work by the way, I’m now this could be used in stead of the PIR sensor to activate and deactivate the monitor.
          Or even instead of the camera/ facial recognition module to switch between profiles!
          mochmanM 1 Reply Last reply Reply Quote 0
          • mochmanM Offline
            mochman Module Developer @Mitchfarino
            @Mitchfarino I will once I do wire everything up. I’m in the middle of a move, so when I get settled into my new place I can start building.
            MitchfarinoM 1 Reply Last reply Reply Quote 0
              Mitchfarino Module Developer @mochman
              @mochman Great! Look forward to seeing it.
              I’ve just ordered some sensors, so waiting on them to arrive.
              Thanks for the module, it’s great!
                Mitchfarino Module Developer @Mitchfarino
                KirAsh4K 1 Reply Last reply Reply Quote 0
                • KirAsh4K Offline
                  KirAsh4 Moderator @Mitchfarino
                    Mitchfarino Module Developer @KirAsh4
                      Completely noob question, will I have to solder this in?
                      • mochmanM Offline
                        You don’t have to, if you just want to use a jumper cable like this one:
                        It should connect the raspberry pi to the sonic device.
