    Display what would you buy?
    26 Posts 6 Posters 19.6k Views 5 Watching
    • W
      wizz
      Ok that wold work for me to.
      Have to check as it is hard do find the separate parts that i need.
      @ottobot do you got some links for me on Aliexpress that you think wold be good for my project?
        broberg Project Sponsor
        https://www.proshop.se/Bildskaerm/Neovo-17-Bildskaerm-C-17P-Svart-3-ms-/2496928?utm_source=prisjakt&utm_medium=cpc&utm_campaign=pricesite
        Buying bigger things outside the EU you will have to pay toll and taxes on it. Not worth it.
        Or Try finding a used monitor with hdmi on www.blocket.se
        The small ones usually are dirt cheap!
        The LED monitors often has a stronger light output/contrast are therefor better suited for a magicmirror, but a normal tft/ccfl screen works also. It’s more up to the lighttransmissin of your mirror in the end.
        • W
          wizz
          @broberg That i know and the thing is that i want the mirror to be only seven centimeters thick as the location where it will hang it on the wall don´t let me have a thicker frame so this is why i try to find the best solution.
          B 1 Reply Last reply
            broberg Project Sponsor @wizz
            @wizz okey, so a maximum depth of 5cm for the screen then? what is the maximum width and height for the screen?
            And about the color of the frame, it should not be an issue, if it is, just use some “eltejp” or black vinyl, or just paint it black.
            • W
              wizz
              @broberg thats right and the width maximum is 40 - 42 cm and height is 80 - 85cm it will hang in my kitchen beside the door on a small wall where i also got the kitchen cabinet whit a door that have to be possible to open so it is a small area i have.
              B 2 Replies Last reply
                @wizz Okey, so how about this one then :
                https://www.dustinhome.se/product/5010887463/gw2470h?ssel=false&utm_campaign=prisjakt&utm_source=prisjakt.nu&utm_medium=pricecompare&utm_content=5637146247
                51mm thick, 553mm wide and 329mm high.
                Turn it on it’s side and you get 329mm wide and 553mm high.
                And it will cost you the same (or less if we count the toll costs) as the aliexpress 17.3 lcd panel
                  @wizz or maybe this one :
                  https://www.webhallen.com/se-sv/datorer_och_tillbehor/215664-aoc_e2476vwm6_236-1ms-vga_hdmi-vesa&atcl=external:ref
                  41mm deep, 558mm by 335mm
                  And it was cheaper still :D
                  • W
                    wizz
                    @broberg Thanks for the links will try to get by Webhallen today on my way home from work :)
                    • W
                      wizz
                      @broberg what do you think about this? https://www.netonnet.se/art/dator/bildskarm/23-24tum/aoc-e2470swda/220402.8903/
                      I can not find how deep it is?
                        @wizz neither can I the manufacturer doesn’t even specify it. But it doesn’t have a hdmi input, so it would need an adapter.
                        • W
                          wizz
                          @broberg Yes i found out that to so it will not be that one.
                          • W
                            wizz
                            @broberg got a Benq to a nice price at Inet.se they had one for 20% lower price than the regular 1199:-
                              @wizz nice :D I scored my 24" monitor at the black friday sale this winter for 950sek
                              • W
                                wizz
                                @broberg later on tonight will see if it fits where i want it or if i have to change the plan. :)
