MMM-NFL
19 Posts 2 Posters 9.2k Views 2 Watching
    I took and old laptop and installed MM on it today. It’s not going to be a mirror. It’s going to be a gift to my son-in-law who is an avid NFL football fan and he is totally into Fantasy Football as well. So, the only module running will be MMM-NFL (for now) and I have a question or two (for now). I already installed the module and it seems fine showing the last games of the post-season 2016 and the final of the SuperBowl.
    Do I have to install MMM-voice in order to show the windows below? Or is there a way to have multiple windows open without voice commands? For example, I’d like to have all the statistics windows open at the same time. If MMM-voice has to be installed then I hope the laptop microphone will work.
    Thank you for any help you can give me
    S 1 Reply Last reply Mar 2, 2017, 3:46 PM Reply Quote 0
      strawberry 3.141 Project Sponsor Module Developer @Mykle1
      @Mykle1 without any modifications this is only possible with mmm-voice
      M 3 Replies Last reply Mar 2, 2017, 4:42 PM Reply Quote 1
        Mykle1 Project Sponsor Module Developer @strawberry 3.141
        @strawberry-3.141 said in MMM-NFL:
        Ok, then I will give MMM-voice a try. Thanks
          @strawberry-3.141
          MM shows a little white microphone in the bottom left of the screen with the word ERROR next to it
          run bash dependencies.sh in ~/MagicMirror/modules/MMM-voice/installers directory, to install all dependencies.
          This command would not work for me on the laptop so I manually installed these dependencies in the /MagicMirror/modules/MMM-voice/installers directory:
          SphinxBase :heavy_check_mark:
          PocketSphinx :heavy_check_mark:
          A microphone - I tested the microphone of the laptop and it is working. I recorded a test file. :heavy_check_mark:
          npm - already installed :heavy_check_mark:
          PocketSphinx-continuous :heavy_check_mark:
          lmtool :heavy_check_mark:
          Do I have to also install these? If so, how would I find them? Google search?
          Packages: bison libasound2-dev autoconf automake libtool python-dev swig python-pip
          microphone REQUIRED Id of microphone shown in the installer.
          I did not see and Id for the microphone.
            @strawberry-3.141
            This was in my terminal when I closed MM
            MMM-voice: Checking files.
            MMM-voice: Generating dictionairy and language model.
            MMM-voice: Saved words.json successfully.
            MMM-voice: Starting pocketsphinx.
            (node:1892) DeprecationWarning: Calling an asynchronous function without callbac
            k is deprecated.
            k is deprecated.
            k is deprecated.
            k is deprecated.
            k is deprecated.
            k is deprecated.
            S 1 Reply Last reply Mar 2, 2017, 6:47 PM Reply Quote 0
              @Mykle1 never tried to install it on a non linux system
              M 1 Reply Last reply Mar 2, 2017, 8:38 PM Reply Quote 0
                Ok,then lets start off simply, if you don’t mind
                Are these part of the dependencies installed by the bash command?
                S 1 Reply Last reply Mar 2, 2017, 8:46 PM Reply Quote 0
                  @Mykle1 yes it’s the first step in the installer, when I remember correctly (half a year ago) those were needed to install pocketsphinx and sphinxbase
                  M 1 Reply Last reply Mar 2, 2017, 11:38 PM Reply Quote 0
                    Ok, then theoretically, I should be able to find and install each one individually in the /MagicMirror/modules/MMM-voice/installers directory. I will follow the order of the installations from the dependencies.sh file.
                    The problem is with sudo (I think) based on this:
                    [STEP 1/6] Installing Packages
                    dependencies.sh: line 36: sudo: command not found
                    [STEP 1/6] Installing Packages | Failed
                    Pop@Pop-CQ57-Laptop MINGW32 ~/MagicMirror/modules/MMM-voice/installers (master)
                    Anyway, I’ll keep trying
                    M 1 Reply Last reply Mar 3, 2017, 12:11 AM Reply Quote 0
                      Mykle1 Project Sponsor Module Developer @Mykle1
                      Oh well, I don’t think this is gonna happen. The libasound2-dev file, from what I can tell, is designed for the ALSA sound component that the Pi uses. My poor son-in-law. He doesn’t get a MMM-NFL laptop.
                      M 1 Reply Last reply Mar 3, 2017, 12:49 AM Reply Quote 0
