    MMM-NFL
    19 Posts 2 Posters 10.7k Views 2 Watching
      I took and old laptop and installed MM on it today. It’s not going to be a mirror. It’s going to be a gift to my son-in-law who is an avid NFL football fan and he is totally into Fantasy Football as well. So, the only module running will be MMM-NFL (for now) and I have a question or two (for now). I already installed the module and it seems fine showing the last games of the post-season 2016 and the final of the SuperBowl.
      Do I have to install MMM-voice in order to show the windows below? Or is there a way to have multiple windows open without voice commands? For example, I’d like to have all the statistics windows open at the same time. If MMM-voice has to be installed then I hope the laptop microphone will work.
      Thank you for any help you can give me
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @Mykle1
        @Mykle1 without any modifications this is only possible with mmm-voice
        Mykle1M 3 Replies Last reply Reply Quote 1
          Mykle1 Project Sponsor Module Developer @strawberry 3.141
          @strawberry-3.141 said in MMM-NFL:
          Ok, then I will give MMM-voice a try. Thanks
            @strawberry-3.141
            MM shows a little white microphone in the bottom left of the screen with the word ERROR next to it
            run bash dependencies.sh in ~/MagicMirror/modules/MMM-voice/installers directory, to install all dependencies.
            This command would not work for me on the laptop so I manually installed these dependencies in the /MagicMirror/modules/MMM-voice/installers directory:
            SphinxBase :heavy_check_mark:
            PocketSphinx :heavy_check_mark:
            A microphone - I tested the microphone of the laptop and it is working. I recorded a test file. :heavy_check_mark:
            npm - already installed :heavy_check_mark:
            PocketSphinx-continuous :heavy_check_mark:
            lmtool :heavy_check_mark:
            Do I have to also install these? If so, how would I find them? Google search?
            Packages: bison libasound2-dev autoconf automake libtool python-dev swig python-pip
            microphone REQUIRED Id of microphone shown in the installer.
            I did not see and Id for the microphone.
              @strawberry-3.141
              This was in my terminal when I closed MM
              MMM-voice: Checking files.
              MMM-voice: Generating dictionairy and language model.
              MMM-voice: Saved words.json successfully.
              MMM-voice: Starting pocketsphinx.
              (node:1892) DeprecationWarning: Calling an asynchronous function without callbac
              k is deprecated.
              k is deprecated.
              k is deprecated.
              k is deprecated.
              k is deprecated.
              k is deprecated.
                @Mykle1 never tried to install it on a non linux system
                  Ok,then lets start off simply, if you don’t mind
                  Are these part of the dependencies installed by the bash command?
                    @Mykle1 yes it’s the first step in the installer, when I remember correctly (half a year ago) those were needed to install pocketsphinx and sphinxbase
                      Ok, then theoretically, I should be able to find and install each one individually in the /MagicMirror/modules/MMM-voice/installers directory. I will follow the order of the installations from the dependencies.sh file.
                      The problem is with sudo (I think) based on this:
                      [STEP 1/6] Installing Packages
                      dependencies.sh: line 36: sudo: command not found
                      [STEP 1/6] Installing Packages | Failed
                      Pop@Pop-CQ57-Laptop MINGW32 ~/MagicMirror/modules/MMM-voice/installers (master)
                      Anyway, I’ll keep trying
                        Mykle1 Project Sponsor Module Developer @Mykle1
                        Oh well, I don’t think this is gonna happen. The libasound2-dev file, from what I can tell, is designed for the ALSA sound component that the Pi uses. My poor son-in-law. He doesn’t get a MMM-NFL laptop.
                          I just chatted with cowboysdude. Apparently, he installed ubuntu on a computer and was able to get MMM-voice to work that way. I’m going to try that. Wish me luck
                            Installed uBuntu and was able to successfully install MMM-NFL and MMM-voice and the dependencies as directed.
                            This was at the end of the dependencies installation for MMM-voice
                            [INFO] Possible Audio Devices to set in config.js
                             0 [SB             ]: HDA-Intel - HDA ATI SB
                                                  HDA ATI SB at 0xf0440000 irq 16
                            pop@NFL:~/MagicMirror/modules/MMM-voice/installers$
                            Please tell me what to put in the config for Microphone
                              @Mykle1 try microphone: 0
                                try microphone: 0
                                Fantastic!
                                And as of this very moment, I can confirm that an old Compaq Presario CQ57 laptop, with a fresh install of uBuntu 16.04 LTS, is running MagicMirror 2 without a hitch. And, more importantly, it’s running MMM-NFL and MMM-Voice for voice control of the module. Voice control was the important factor for me as it’s the only way to access almost all of the features on MMM-NFL As a super deluxe and surprising added benefit to the whole thing, MMM-Voice recognized, and is using, the built-in microphone of the laptop.
                                Now that I have them both running on a linux machine, can I ask some more questions?
                                Is there a way to have multiple/or all Statistics windows open at the same time?
                                Anyway, thanks for the modules. Very cool!
                                  @Mykle1 you can only show one top 5 once, but you can switch between them without needing to close the other one first
                                    Yes, I had already discovered that by trying, and I’m happy about that.
                                    Ok, next question. Is there a way to have the statistics window open in another region other than middle_center?
                                      @Mykle1 it’s not using any region for that it basically centers on your screen checkout the css class modal https://github.com/fewieden/MMM-NFL/blob/master/MMM-NFL.css#L51-L60 which can be overwritten in the custom.css
                                        Ok, thank you. Will do.
                                        I’m also going to install MMM-Soccer.
                                          @strawberry-3-141
                                          I added MMM-Soccer to the laptop. Very nice! Voice working!
                                          I also added several sports newsfeeds to keep the sports theme of the machine.
                                          My son-in-law is going to love this
