Pm2 dont start my scripts on startup
i install the pm2 to run the magicmirror on startup.
If i manually run pm2 start mm.sh,the magicmirror start working,but it doesn´t do it on startup
Im on a R pi3 -
@theusu5k What said when you run ?
pm2 list -
same problem I have
@michael24h
and what ispm2 logs mmsaying? -
That all, after pm2 show mm
pm2 logs mm
This is my log pm2
2017-03-03 17:07:49: Starting execution sequence in -fork mode- for app name:mm id:0
2017-03-03 17:07:49: App name:mm id:0 online
2017-03-04 14:31:00: Stopping app:mm id:0
2017-03-04 14:31:01: App [mm] with id [0] and pid [1239], exited with code [0] via signal [SIGINT]
2017-03-04 14:31:01: pid=1239 msg=process killed
2017-03-04 14:31:01: Starting execution sequence in -fork mode- for app name:mm id:0
2017-03-04 14:31:01: App name:mm id:0 online
2017-03-04 14:32:40: Stopping app:mm id:0
2017-03-04 14:32:40: App [mm] with id [0] and pid [32472], exited with code [0] via signal [SIGINT]
2017-03-04 14:32:40: pid=32472 msg=process killed
2017-03-04 14:32:40: Starting execution sequence in -fork mode- for app name:mm id:0
2017-03-04 14:32:40: App name:mm id:0 online
2017-03-04 14:34:13: Stopping app:mm id:0
2017-03-04 14:34:14: App [mm] with id [0] and pid [32720], exited with code [0] via signal [SIGINT]
2017-03-04 14:34:14: pid=32720 msg=process killed
2017-03-04 14:34:14: Starting execution sequence in -fork mode- for app name:mm id:0
2017-03-04 14:34:14: App name:mm id:0 online
2017-03-06 14:49:55: ===============================================================================
2017-03-06 14:49:55: — New PM2 Daemon started ----------------------------------------------------
2017-03-06 14:49:55: Time : Mon Mar 06 2017 14:49:55 GMT+0000 (UTC)
2017-03-06 14:49:55: PM2 version : 2.4.2
2017-03-06 14:49:55: Node.js version : 6.10.0
2017-03-06 14:49:55: Current arch : arm
2017-03-06 14:49:55: PM2 home : /home/pi/.pm2
2017-03-06 14:49:55: PM2 PID file : /home/pi/.pm2/pm2.pid
2017-03-06 14:49:55: RPC socket file : /home/pi/.pm2/rpc.sock
2017-03-06 14:49:55: BUS socket file : /home/pi/.pm2/pub.sock
2017-03-06 14:49:55: Application log path : /home/pi/.pm2/logs
2017-03-06 14:49:55: Process dump file : /home/pi/.pm2/dump.pm2
2017-03-06 14:49:55: Concurrent actions : 2
2017-03-06 14:49:55: SIGTERM timeout : 1600
2017-03-06 14:49:56: Starting execution sequence in -fork mode- for app name:mm id:0
2017-03-06 14:49:56: App name:mm id:0 online
2017-03-06 15:07:51: Stopping app:mm id:0
2017-03-06 15:07:51: App [mm] with id [0] and pid [1137], exited with code [0] via signal [SIGINT]
2017-03-06 15:07:51: pid=1137 msg=process killed
2017-03-06 15:07:51: Starting execution sequence in -fork mode- for app name:mm id:0
2017-03-06 15:07:51: App name:mm id:0 online -
ok, please run
pm2 logs mm --lines 50
MagicMirror found an error, maybe due to a broken module or missing dependencies. -
@roramirez said in Pm2 dont start my scripts on startup:
pm2 listnothing,if i manually run it,it appears
@yawns said in Pm2 dont start my scripts on startup:
/home/pi/.pm2/logs/mm-error-0.log last 50 lines:
0|mm | at Module.load (module.js:473:32)
0|mm | at tryModuleLoad (module.js:432:12)
0|mm | at Function.Module._load (module.js:424:3)
0|mm | at Module.require (module.js:483:17)
0|mm | at require (internal/module.js:20:19)
0|mm | at Object. (/home/pi/MagicMirror/modules/magic-mirror-voice/node_modules/java/lib/nodeJavaBridge.js:21:16)
0|mm | at Module._compile (module.js:556:32)
0|mm | at Object.Module._extensions…js (module.js:565:10)
0|mm | ERROR! Could not find main module js file.
0|mm | Error: Module version mismatch. Expected 50, got 48.
0|mm | at Error (native)
0|mm | at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
0|mm | at Object.Module._extensions…node (module.js:583:18)
0|mm | at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
0|mm | at Module.require (module.js:483:17)[STREAMING] Now streaming realtime logs for [mm] process
