    Compliments not displaying
    Scheduled Pinned Locked Moved Solved Development
    17 Posts 5 Posters 13.7k Views 5 Watching
    • L Offline
      l1613532
      Compliments not working for me either. On Raspberry Pi Zero W running Jesse Lite. Used Wieber’s guide to get it running (https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero).
      By default 'compliments" file does not output to the MM although all other default modules working.
      @cowboysdude : the default config.js is set up the way you described and it still does not work.
      Also edited config.js to place config: { compliments… and manually install compliments similar to what @jin has done but still no output on the MM.
      No errors or crashes and the later modules after compliments still work.
      • cowboysdudeC Offline
        You guys would need to post your entire config.js file minus any KEYS you have in there…
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @jin
          @jin you either have to escape your single quote inside the string or use double quotes
          evening: [
            'Wasn\'t the sunset beautiful?',
            'You look nice!'
          evening: [
            "Wasn't the sunset beautiful?",
            'You look nice!'
            jin @cowboysdude
            thanks for the replys guys
            @cowboysdude it still doesnt show any compliments
            /* Magic Mirror Config Sample
            * MIT Licensed.
            var config = {
            	port: 8080,
            	language: 'en',
            	timeFormat: 24,
            	units: 'metric',
            			module: 'alert',
            			module: "updatenotification",
            			position: "top_bar"
            			module: 'clock',
            			position: 'top_left'
            			module: 'calendar',
            			header: 'UK Holidays',
            			position: 'top_left',
            						symbol: 'calendar-check-o ',
            						url: 'webcal://www.calendarlabs.com/templates/ical/UK-Holidays.ics'
            						url: 'https://calendar.google.com/calendar/ical/private/basic.ics'
            			module: 'compliments',
            			position: 'bottom_center',
            				updateInterval: 30000,
            				compliments: {
            					morning: [
            					'Good morning, sunshine!'
            					afternoon: [
            					'Looking good today!'
            					evening: [
            					'You look nice!'
            			module: 'currentweather',
            			position: 'top_right',
            				locationID: '2643741',  //ID from http://www.openweathermap.org
            				appid: 'removed'
            			module: 'weatherforecast',
            			header: 'Weather Forecast',
            				appid: 'removed'
            			module: 'newsfeed',
            			position: 'bottom_bar',
            				feeds: [
            						title: "BBC News",
            						url: "http://newsrss.bbc.co.uk/rss/newsonline_uk_edition/front_page/rss.xml"
            				showSourceTitle: true,
            				showPublishDate: true
            this is the whole config file.
              @jin the config looks good, I’m receiving the compliments with this. Can you check for errors in the electron console (npm start dev)? and the terminal?
              L J 2 Replies Last reply Reply Quote 0
              • L Offline
                l1613532 @strawberry 3.141
                @strawberry-3.141
                This is the log file when I run: npm start dev
                1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’, ‘dev’ ]
                2 info using npm@2.14.7
                3 info using node@v4.2.1
                4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
                5 info prestart magicmirror@2.1.0
                6 info start magicmirror@2.1.0
                7 verbose unsafe-perm in lifecycle true
                8 info magicmirror@2.1.0 Failed to exec start script
                9 verbose stack Error: magicmirror@2.1.0 start: electron js/electron.js "dev"
                9 verbose stack spawn ENOENT
                9 verbose stack at ChildProcess. (/usr/local/lib/node_modules/npm/lib/utils/spawn.js:17:16)
                9 verbose stack at emitTwo (events.js:87:13)
                9 verbose stack at ChildProcess.emit (events.js:172:7)
                9 verbose stack at maybeClose (internal/child_process.js:818:16)
                9 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
                10 verbose pkgid magicmirror@2.1.0
                11 verbose cwd /home/pi/MagicMirror
                12 error Linux 4.4.50+
                13 error argv “/usr/local/bin/node” “/usr/local/bin/npm” “start” “dev”
                14 error node v4.2.1
                15 error npm v2.14.7
                16 error file sh
                17 error code ELIFECYCLE
                18 error errno ENOENT
                19 error syscall spawn
                20 error magicmirror@2.1.0 start: electron js/electron.js "dev"
                20 error spawn ENOENT
                21 error Failed at the magicmirror@2.1.0 start script ‘electron js/electron.js “dev”’.
                21 error This is most likely a problem with the magicmirror package,
                21 error not with npm itself.
                21 error Tell the author that this fails on your system:
                21 error electron js/electron.js “dev”
                21 error You can get their info via:
                21 error npm owner ls magicmirror
                21 error There is likely additional logging output above.
                22 verbose exit [ 1, true ]
                sorry, I’m also new to programming. Any ideas for next step?
                  jin @strawberry 3.141
                  @strawberry-3.141 all i get when i run npm start dev is
                  > magicmirror@2.1.0 start /home/pi/MagicMirror
                  no log file or anything
                  • L Offline
                    l1613532
                    Probably not a coincidence, but both @jin and I are using raspberry pi zero ‘W’ with midori as our browser.
                    • L Offline
                      l1613532 @l1613532
                      and we are both running jesse lite
                        strawberry 3.141 Project Sponsor Module Developer @l1613532
                        @l1613532 in the start method of the compliments.js file is an es6 arrow function which isn’t supported by the midori browser. But that doesn’t explain your error from the logs
                        • L Offline
                          @strawberry-3.141 said in Compliments not displaying:
                          es6 arrow function
                          Can you describe this es6 arrow function at the start of compliments.js and what I can manually replace it with that will be supported by Midori?
                          • L Offline
                            l1613532
                            Found the answer! Thank you to @strawberry-3-141 for pointing me in the right direction.
                            in the compliments.js file (found in /MagicMirror/modules/default/compliments folder), change:
                            	if (this.config.remoteFile != null) {
                            		this.complimentFile((response) => {
                            			this.config.compliments = JSON.parse(response);
                            to:
                                                    function(response){
                            For all those using Midori browser (which appears to be the only browser which runs MM2 on Pi Zero), this will be an ongoing problem for certain modules that use es6 arrow functions. See https://github.com/MichMich/MagicMirror/issues/694 for more info.
                              @l1613532 this code isn’t working properly, you have to do
                                var self = this;
                                  function(response){
                                    self.config.compliments = JSON.parse(response);
                              J 1 Reply Last reply Reply Quote 2
                                jin
                                Seeing the solution after a couple of long shifts is a nice surprise.
                                Great work l1613532 and strawberry 3.141.
                                  jacobmar1ey @strawberry 3.141
                                    var self = this;
                                      function(response){
                                  Tank you so much for this response. My Zero (non-W) was also suddenly not displaying compliments as well and I was trying to figure it out all week!
